1.02 psi on all surface, Vacuum infused fiberglass, 0.37mm thick (for hand lamination it shell be ~0.5mm) 3" width :
Deflection = 0.19" RF: 1.20
2 plies, spaced 6"
Similar again = 0.42" RF: 0.98
2.4" single ply :
0.072" RF: 2.35
So for single ply fiberglass, only last one can be seen viable for such high load.
With Carbon fibre, 450gsm, biax, 0/90 laminas, 0.48mm (0.02" same as bilion pvc ribs 2024 skin) thick: at 2.4" :
Deflection 0.0128" RF :10
At 4"
deflection 0.116" RF: 2.6
And for 3.6", same as in Cri-Cri
Deflection 0.074" And RF: 3.9
Final - same as last one, but laminas at 45/-45 degree
Rf:4.8, deflection 0.125"
My conclusion - it can be viable using CF. For FG - you need a trilion ribs
And for 50/50 resin to fiber deflections will be lower..
Billski - could you analytically run an example with Radius plate ? R= 31", 16" arc length, loaded at 1.02 psi at front, and 0.6 psi at back.. On FEA, i am getting much better results than flat plate.
Cored at 24", uncored at 6" two plies.
