Not quite so structural foams?
RSD
May 19, 2019
211
To get started and learn/practice carbon fibre layups etc I'm going to make a new centre console for my boat. It probably doesn't need the "structural" foams that are used in homebuilt aircraft, and because I'm only going to need a couple of sheets and road transport for sheets is very expensive here in Australia I'm looking for a cheap readily available foam - something that I can get from somewhere other than a specialty composites supplier. Any suggestions?
I've seen mentioned on here "pink foam" that you get from Lowe's or Home Depot - what type of foam is that? We don't have those stores here unfortunately :-(
RSD
May 19, 2019
211
and I might be tempted to put some Graphene into it to see what it is like...
RSD
May 19, 2019
211
Voidhawk9
Mar 26, 2012
421
Timaru, NZ
Cheers! I've heard bad things about polystyrene being melted by resins - is that only certain resins?
Extruded polystyrene is used as the core for the wings in Rutan canards, as one example. Using epoxy - I am not sure of compatibility with all resins.
and has anyone used this sort of stuff before - I think it is often called PVC Sign Board. It is foamed PVC - https://www.bunnings.com.au/suntuf-1200-x-900-x-6mm-white-pvc-foam-sheet_p1010819
Should work, though a smooth surface as it describes isn't ideal for bonding, you may need to sand or remove the face.
5,596
The "pink" foam is by Owens Corning (brand name "Foamular") and the blue foam is by Dow (brand name "Styrofoam"). The generic label for both is "Extruded Polystyrene," or "XPS." It is sometimes confused with "Expanded Polystyrene" or EPS. EPS is the weak stuff that looks like a lot of tiny balls squeezed together to make a sheet (or a cheap cooler for beer). XPS is quite a bit tougher. Don't use EPS, use only XPS.
One thing that causes confusion, at least in the US, is that the general public uses the term "styrofoam" to refer to the beady white foam used to make cheap coolers, coffee cups, etc. These are really made of EPS foam.
If you tell the folks at the home supply place that you want XPS, that might work.
AdrianS
Jul 5, 2014
578
Australia
I've used that stuff. It's way denser than I'd use as a core - I was gluing disks of it into polypipe (with blue solvent glue) for a hydroponics project.
It's a great hobby material - you can cut it with a handsaw or jigsaw, heat bend it with a hot air gun, glue it with pipe glue - it's the perfect companion for polypipe.
RSD
May 19, 2019
211
Many thanks for all the replies. Went to Bunnings (our version of Home Depot) tonight and while looking in aisles for the other products I stumbled across some XPS tucked away on the top shelf that I don't think the staff even knew was there - its not on their website either. Price is reasonable, comes in 1200 x 600 sheets (4' x 2') in thicknesses of 30 and 50mm (1.25" and 2").
How well does a router work with XPS?
8,812
Use a very sharp bit. I'd be tempted to try touching up a new one with my finest diamond stone. You may need to turn the speed down. If you melt it over the blade, pick the globs off then soak the blade in acetone to remove the rest.
7,480
Pink foam is a very fine grained Owens-Cornings polystyrene foam. It hot wire cuts and laminates just as nicely as Dow's light blue polystyrene foam insulation sheet. I use them interchangeably for tooling but use neither for airframe laminates.
I stick to the old advice of using Dow blue flotation billet for airframe parts. It hotwires nicely, is lower density than the foam insulation boards and has bigger cell sizes, but makes tough airplane parts. The process for making it was known at one time to not contain any silicones, while there was concern about other styrene foams having silicones in their processes. As thermal insulation, silicones are no big deal, but in bonding of composites to it, even tiny amounts of silicone in the foam can contribute to debonding.
Do not get me wrong - Dow and Owens foam polystyrene insulation boards may be just fine, but at one time the direction from Rutan Aircraft Factory was to use flotation billet from Dow and be happy.
Now if you are going to make a structure where the foam matters not to it, you could use anything for the form and be happy. You could even make the foam shape into a mold by putting a stretchelon film over the foam.
Good luck dealing with the supply variance issues there.
7,480
This is expanded bead foam - white coffee cup foam. In my shop this is tooling only. It is noticeably softer and less cohesive (it crumbles easily) than extruded foams. I did manufacture the male molds for my fuselage using it as I could get the sizes I wanted and it hotwires and sands nicely. I would NOT leave this stuff in a laminated part of anything I wanted to hold together for long. It can come from many sources and has unknown silicone presence in its manufacture.
7,480
Polyester and Vinylester resins will melt any polystyrene foam. Gasoline, any solvent that works as a lacquer thinner or contains styrene monomer will dissolve polystyrene. Styrene foams should not be used in tanks. Gas and diesel have components that will diffuse through fiberglass is small but sufficient quantitities to reduce foam to small puddles of solid polystyrene in the low spots. I have seen this in an accident teardown...
Epoxy only on all polystyrene foams. Want to make a tank for anything beyond water, like gasoline, diesel, Jet A, or oil? Use fuel safe foams like PU or PVC. In the Rutan Long Ez and Defiant, fuel tanks were the strakes of the main wing and made of epoxy and PVC foams.
The outer wings, canard, tip sails, etc were all separate structures from the fuel tanks and hotwire cut from blue flotation billet, and work just fine.
7,480
Hmm. Ran the calc, and that is 12 pcf, or about double the density we usually use in Divinycel PVC foam. It might take a bit more effort to cut and machine it. I do not know if silicones are present, so you may have some debond risk with it. That is one of the nice things about Divinycel - it is made for use in aerospace structures and is specifically clean of anything that might interfere with bonding.
8,286
The movie special effects people use something called "green death foam", which is a typical Hollywood FX nickname.
In the real world, the stuff is also called "floral foam" and it is sold (here in USA) as small blocks of foam for florists to stick flower stems into, to make a small display. They put candy skewers and other things into it, to make an attractive presentation. Most Craft and Hobby stores here sell it, Walmart and many others here.
Find a local flower shop or floral display maker and see if they have it, it is medium green in color, very light, and very rigid. Very fine "grained". Probably not as good for a "real" aircraft structure because it will fracture more easily than the common aircraft foams. Also, podiatrists (foot doctors) use this material to make a mold of your feet, they have you step onto a block of this, and it leaves a perfect impression of your foot, arch, etc.
The "green death" name comes from the fact that when you sand it, it creates a very fine and highly irritating dust, so the Hollywood guys making monsters and movie props and such get covered with that dust and have to be sent through a car wash afterward :)
So absolutely wear a dust mask, eye protection, etc. But epoxy resins should not melt or soften it, and it will surely work for a non-critical part. They come in smaller blocks, which means you may have to glue a few of them together to make the size you need. But you won't have to buy a huge expensive block either.
7,480
Hi ! I want photo of this process if possible.
This is thread drift, so I will be brief. Sorry the film photos I have do not show much. Read this for a summary of the process, then feel free to .
https://www.homebuiltairplanes.com/forums/threads/foam-less-molds.3792/page-2#post-27332
https://www.homebuiltairplanes.com/forums/threads/female-plug-mold.2436/#post-14728
https://www.homebuiltairplanes.com/forums/threads/thickness-percentage-for-composite.5464/#post-42551, go down to post 20.
That is probably enough...
SVSUSteve
Aug 20, 2007
3,904
Evansville, Indiana
I imagine someone else already pointed it out but one of the major things you have to be aware of is that polystyrene dissolves if you expose it to a lot of common solvents including gasoline (avgas or mogas). This has caused at least one crash I am aware of where a fuel leak caused the wing to fail in flight.
However, it does have an advantage that if you need to make a compound curve but just need the "skin" (for example, something non-structural like decorative trim). You make the core out of cheap styrofoam and once the epoxy has cured, you take a bottle of nail polish remover (acetone) and pour it on the exposed bit of the core. You can then pour and scoop out the resulting goop.
EDIT: Yup, Billski pointed it out. Mea culpa for not reading further down first.
