News from Daniel Dalby
b7gwap
Sep 1, 2014
277
UT
I love Dalby’s work, but what is reacting drag/anti-drag loads on the wing here? Just the pivot mechanism for the “wingerons?” The single rectangular beam for the empennage makes me a little nervous too, but I’m sure Dalby sized it sufficiently.
Cute little thing.
Jay Kempf
Curmudgeon in Training (CIT)
Apr 13, 2009
4,008
Warren, VT USA
Probably a long tube with sleeves over it. Seems a bit minimal. Plus that tail has no support against rudder fluttering. But with a free wing you can't really wire brace. Think this one needs a bit more thought. If it has flown well, I take it all back :)
Daleandee
Sep 11, 2015
1,142
SC
I like it.
Obviously this is just a concept drawing as there are still things to be figured out as others have mentioned already. I don't even see a spot for the glass panel ... 🧐
5,013
There are wires from the strut attach point on the wings to a spot under the seat, they are probably there to take drag loads. Maybe he plans some for the tail, too.
I'm all for saving weight, but I think he should splurge and include a left main gear. ;)
7,547
Daniel Dalby's monoplane designs typically have single struts with drag/anti-drag wires and all-moving wings that rotate in incidence for roll control. They are also typically of largely rectangular aluminum tube and gusset construction with foam ribs. Here's a photo of a Cubchel to show the system.
5,013
About those wingerons: It is interesting. Are there planes with higher wing loadings that have taken that approach? Maybe it becomes impractical at some point for structural reasons or control pressures get too high (pitching moments at various AoAs, etc).
3,285
The American Flea Triplane used the lower/rearmost wings as wingerons. In that particular application they were said to be death traps if you weren’t paying enough attention in the pattern. I’ve seen a letter from a past manufacturer of kits urging the current owner of all the drawings (and two projects) to never, ever try flying one. High praise for the design from the guy who used to sell them!
I bet stall progression is an unpredictable mess on Dalby’s designs, unless some exceptionally forgiving airfoil exists for them.
erkki67
Feb 18, 2010
2,169
The flea is no death trap, at least not since 1936, before that year, yes the flea had some design flaws which cost some pilots lives, but the flaws where corrected in 1936, it got spin and stall proove. No other type got such a good safety record since, not even the Storch!
regarding the wingerons of Dalby, I haven’t heard of any accidents of his concepts either, but you might have more informations regarding his constructions than I have, can you give me the sources of your craints?
3,285
Different Flea. I’m talking about an airplane completely unrelated to anything Mignet did.
The bottom wings pivot as ailerons. Because of the amount of stagger on the wings I imagine if you apply any aileron at the stall the airplane will probably want to pitch up further. Seems like a bunch of these American Fleas were produced but none ever flew much, if at all. They were like the BD-5 of the thirties.
7,547
Correct, while trying to capitalize on the "Flea" names associated with inexpensive light aircraft in the 1930s, and I believe initially promoted by some of the same investors who supported the short-lived American Mignet Aircraft Corp, the TC-1/Fleaship had nothing to do with Mignet at all.
That said, I don't think the all-moving bottom wings were likely the issue, or at least there is nothing inherently wrong with the concept. As long at the wings were adequately strong, and adequately stiff in torsion, and rigged with each wing getting a couple of degrees more incidence than the one below it it, the aircraft should have stalled progressively (top wing first) and with lateral control maintained throughout.
