New rotorcraft concepts
EzyBuildWing
Sep 23, 2009
643
Sydney NSW Australia
Littlewing tractor-Autogyro with an MZ-201 60 HP and a simple overhead control-stick (like Cierva C-30 had) and a large diameter propeller, would be super-awesome.
henryk
Mar 8, 2010
7,412
krakow,poland
coaxial adds unnecessary complexity and loss.
=auer coaxial CR rotors have different diameters,
but we get gearless,REACTIONless drive system !!!
=CRFLIGHT principe=the electric motor works as Differential Reductor=NO beavals (?),
only + sliding contacts on the stator !
=with mechanic Diff. Reductor we gain circa 30 % more thrust.
EzyBuildWing
Sep 23, 2009
643
Post #159 15 kG thrust from 0.96 kW battery power !
This is awesome! That's about 30 lbs of static thrust per HP.
So a 600 lb MTOW heli would require about 20 HP to hover?
If yes, bring it on!
henryk
Mar 8, 2010
7,412
krakow,poland
=Specific Thrust is function of propeller Disc Loading...
iff you have the same DL=15 kG/m^2 (i.e. 20*1 m^2=20 m^2) you can achive 300 kG
of thrust force.
-in auer KASPERWING (20 HP) we have 80 kG of thrust...(D=1.3 m)
Sockmonkey
Apr 24, 2014
2,345
Flint, Mi, USA
Coaxial systems are typically envisioned to recover swirl loses, but at low disk loading swirl loses are very small. From "Fundamentals of Helicopter Dynamics" by C. Venkatesan, page 23 - typical single rotor helicopter has about 1% swirl loss - there is not too much to recover. From the same book - non uniform inflow is responsible with 5-7% loses.
From "Principles of helicopter aerodynamics" by J Gordon Leishman, page 101, non-separated coaxial has 41% increase in induced power vs separate rotors.
So my opinion is - coaxial adds unnecessary complexity and loss. It's better to use a single rotor and straightening vanes to get rid of the torque.
They do have side advantage of opposing gyroscopic forces, which may be desireable.
henryk
Mar 8, 2010
7,412
krakow,poland
of thrust force.
=low disc loading (15 kG/m^2) =16 kG/kW !!!=
Erik Snyman
Oct 9, 2019
132
X2 hybrid =
"Interestingly, most of the power goes to the pusher prop at high speeds, and very little goes to the main rotor. "
-auer,much simpler solution=
-my Fellow was invented new type of rotorcraft=autogyro with conter rotating
rotors drived all flying time=with max power in VTOL regime and low power
in cruise regime.
=the electric energy is generated with starter/generator maschine drived via IC motor.(for long time fly).
this motor drives conter rotating propellers for thrust (high speed,low rotor drag).
BTW=specific thrust is 3-15 kG/kW (95 kG/qm and 12 kG/qm)
Hello Henryk. This is the system I was looking for info on.
Thanks,
Erik.
henryk
Mar 8, 2010
7,412
krakow,poland
Thanks,
Erik.
-look e-mail...
PS=for involving 3-mode system
1=heli mode take off/landing,
2=classic autogyro mode,
2= semi-autogyro mode with permament rotors drive (reactionless)
we must construct passive change in AoA rotor blades...
(or hand adjusted)
=the bigger RPM, the greater AoA.
Riggerrob
Sep 9, 2014
2,954
Canada
Anyone know if it ever flew? Looks a work of Art!!!!
As for the blue swastika in an white circle on the rudder ... Please remember that Finns, Estonians, Lithuanians, Bhuddists and Sioux used swastikas as good luck charms for a good thousand years befor ethe symbol was hijacked by Adolf Hitler and his ill-fated band of German National Socialists.
Also remember that the Norse runic alphabetic was popular in Scandinavia, Ukraine, Russia, etc. for more than a thousand years before it was hijacked by Nazis, Azov Brigade, etc.
