PagoBay
Excerpt --
April 1, 2021 – After years of hard work and advocacy by EAA, the FAA has published draft guidance to implement an optional task-based Phase I program for Experimental Amateur-Built (E-AB) aircraft. Under the program, once an aircraft completes a flight test plan that meets FAA standards, Phase I is complete. The standard 25- or 40-hour flight test period for Phase I will remain an option for all E-AB, and Experimental Light-Sport (E-LSA) continues to carry a 5-hour test period.
The program is part of an upcoming update to Advisory Circular (AC) 90-89B.
The Advisory Circular is in draft form and comments will be accepted through April 29. Please note that the relevant language on Task-Based Phase I is housed in Chapter 1, Section 1 of the draft. The rest of the document contains advisory information on flight testing and is not part of the task-based program requirements.
www.eaa.org
Task-Based Phase I to Revolutionize Flight Testing
