New lightweight 120 hp engine?
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by SpainCub, Mar 13, 2013.
Tags:
  1. Mar 21, 2013 #21
    DangerZone
    DangerZone
    DangerZone
    Sep 5, 2011
    2,107
    370
    Zagreb HR
    Yes, you are right about the exact angle, I was talking about the optical illusion that we have watching from the side. What I meant is that many Ducatis seem to have an angle greater than 90 degrees and closer to a 100 degree angle. There were Moto Guzzis in the past with 120 degree V angle but most of the modern V motors for motorcycles need a smaller angle for compactness.
    Good find. ;)
    So, it is a V2 Morini based but a new concept and crankcase, what other changes have they made? The gearbox is out and a PSRU seems to be a part of the motor case. Is there a diagram showing how they made the PSRU?
    I don't see the phrase 'monopolized by a single German brand called Beemer' offending, is it supposed to be? :D
  2. Mar 21, 2013 #22
    nerobro
    nerobro
    nerobro
    Nov 6, 2011
    1,109
    312
    Northern Illinois
    Your brain is weird. :)
  3. Mar 21, 2013 #23
    autoreply
    autoreply
    autoreply
    Moderator
    Jul 8, 2009
    10,732
    2,542
    Rotterdam, Netherlands
    After a good Pelinkovac you'll understand ;-)
  4. Jul 22, 2014 #24
    Jan Olieslagers
    Jan Olieslagers
    Jan Olieslagers
    May 28, 2014
    134
    19
    Haacht, Belgium
    I visited the factory recently, and was given a shiny glossy brochure (but the text is in Italian only). It pleases me that no power figure is claimed, neither is any timeline given for market release. That sounds like a conservative approach, and that is what I like. Some design aspects are strange to me, and I wonder if they confirm a relation to motorbike engines, or not:
    -) 4 valves per cylinder, with 2 overhead cams for each cylinder
    -) each cylinder has its own distribution chain (chain!) and these are on each side of the cylinders: one "before", one "behind"
    -) each cylinder has two spark plugs, one in the exact centre, the other tucked away at the side - which makes it look like an afterthought
    A few figures/facts from the brochure:
    twin cylinder 90 degrees 4 stroke
    1223 ccm total displacement
    one oil pump "sucking" and two "blowing" - actually three sections on a single pump body
    cartridge oil filter plus a "net" ("mesh"?) oil filter
    integrated reduction gear 1 : 2,95
    friction clutch (under reserve of translation: originally it reads "ruota libera con frizione")
    three-phase alternator 435 watt (but no indication of voltage, 12V= seems likely)
    One thing is unclear to me, that's the fuel system: one picture mentions "iniettori" which I would translate as "injectors" but elsewhere there is mention of a "secondary circuit" with a carburettor.
  5. Jul 22, 2014 #25
    Jan Olieslagers
    Jan Olieslagers
    Jan Olieslagers
    May 28, 2014
    134
    19
    Haacht, Belgium
    Another thing that's unclear as yet: what options are there for attaching auxiliary power clients, i.e. vacuum pump (for gyroscopic instruments), second alternator (to be IFR compliant), hydraulic prop governor, ... ?
  6. Jul 22, 2014 #26
    12,975
    4,919
    Are we still talking about 120HP at 176 lbs? That sounds remarkably close to the new D-Motor LF39 (six cylinder).
    Han, if you ever get the chance, I'd be interested in seeing you travel to the D-Motor plant in Deerlijk, Belgium (about 110 km from your hometown) and report on your impressions.
    Bruce :)
  7. Jul 22, 2014 #27
    JamesG
    JamesG
    JamesG
    Feb 10, 2011
    2,408
    754
    Um... no. The Suzuki 650 and 1000cc v-twins were designed for a family of bikes to compete with Ducati, hence the same basic engine architecture for the SV-650, TL-1000R/S. Later used with EFI for later marks of the SV and the DLs. I doubt it was ever conceived of by the company as having aircraft application.
  8. Jul 22, 2014 #28
    Xanadrone
    Xanadrone
    Xanadrone
    Nov 24, 2011
    195
    43
    Bucharest Romania
    All the actual Moto Morini engines are V-twins with an 87 degrees angle between the cylinders.
    I've tested one of them (the Scrambler) in june 2009 and they are extremely torquey from low revs, with almost no vibes - although the motorcycle itself had some weird habits with those motocross-style tyres.
    The mileage was not so great (over 7 l/100 km in normal use, also nearby 30 mpg I guess) - a comparable Beemer Boxer is 20% less thirsty and the Rotax-designed BMW parralel-twins are incredibly economical - but, all in all, I think it would make a good starting base for an aero-conversion.
  9. Jul 22, 2014 #29
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,672
    433
    Flint, Mi, USA
    Yeah, that's what gives Harleys that buh-thoom buh-thoom buh-thoom sound. That noise is like a religion for some Harley riders.
    IIRC when auto manufacturers came out with the inline-5 they found it had the same perfectly balanced operation as an inline-6 but was only slightly heavier than an inline-4 because the crank didn't need to be nearly as heavy as a 6 needs.
    I love the radial Caminez engine, but I'm not sure if they ever really solved the issue of wear on the cam lobes.
  10. Jul 23, 2014 #30
    JamesG
    JamesG
    JamesG
    Feb 10, 2011
    2,408
    754
    Potato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato PotatoPotato Potato crunch!
    :nervous:
  11. Jul 23, 2014 #31
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,505
    3,856
    Australian
    Yeah, nah, not close to being true.
  12. Jul 23, 2014 #32
    12,975
    4,919
    That engine sounds somewhat starchy. ;)
    cheapracer and akwrencher like this.
  13. Aug 10, 2014 #33
    kangus
    kangus
    kangus
    Aug 2, 2012
    11
    1
    Park Valley, Utah
    bmcj likes this.
  14. Aug 10, 2014 #34
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,505
    3,856
    Australian
    There is a thread on it here somewhere.
    When these things come across your path that seem to good to be true, it's because they really are too good to be true (specific to aircraft).
  15. Aug 10, 2014 #35
    autoreply
    autoreply
    autoreply
    Moderator
    Jul 8, 2009
    10,732
    2,542
    What's the running weight with everything installed? Anything below 250 lbs and I'm sold (that's Powertec V8 territory)
  16. Aug 20, 2014 #36
    kangus
    kangus
    kangus
    Aug 2, 2012
    11
    1
    Park Valley, Utah
    [TD="class: postbody vtop"]California company reinvents the rotary engine | Fox News 71% less mass - meaning a 1 liter engine would only weigh 25 pounds Reduced RPM - 1750 rpm for the same power as 3500 rpm - prop speed perfect 60% increase in torque - prop perfect, planes fly on torque not hp. Simplified serviceability by 80% - 13 moving parts! Honda: L13B 98hp/88ft-lb @ 6000rpm engine weight ~ 135 pounds 1.5 liter engine 6 inches wide by 12 inches in diameter: 39.2 pounds, 1750 RPM, 140 Ft-Lb torque @100 hp. This would be the ideal aircraft engine: we are currently flying with engines designed in the 1930's due in part to simplicity, the KISS method for single engine private aircraft is a perfect fit for this engine unless Bombardier gets a hold of it, then the price goes to $40K. Even if it only gets the same mileage as a normal gas engine the size and weight and RPM issues make it a perfect aircraft engine. I wonder how/if the engine would handle a prop? [/TD]
  17. Aug 20, 2014 #37
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    3,018
    2,015
    BDU, BJC
    Particularly the ones that exist in space, but not time. :)
  18. Aug 20, 2014 #38
    Brian Clayton
    Brian Clayton
    Brian Clayton
    Dec 7, 2012
    1,042
    529
    Ivey, Ga and Centerville,Tn
    I keep seeing this engine pop up, and while I have not seen the specs..... I would guess its a 8,000 rpm+ engine with 40psi+ of boost. Now I am not a engineer, but longevity aside....a PRSU might be a little troublesome. Not to mention a 400hp engine would burn through fuel like nobodies business.
    dougwanderson likes this.
  19. Aug 20, 2014 #39
    akwrencher
    akwrencher
    akwrencher
    Oct 16, 2012
    1,116
    402
    Gustavus, AK
    140lb*ft of torque at 1750 rpm is only 46.6 hp. Airplanes do not fly on torque. They fly on thrust produced by the prop, which is a product of work performed by the engine, which is what hp is. HP and Torque are just opposite sides of a math equation, really. Torque times rpm divided by 5252 = HP. Can't have one without the other.
    Cute little engine though. Wonder how well it will hold up, assuming it ever goes into production.
  20. Aug 20, 2014 #40
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    3,018
    2,015
    BDU, BJC
    Power is work performed over a period of time (which I'm sure is what you meant); hence the wisecrack above. But we all know they don't fly on torque or power or thrust--it's money that keeps them aloft, right? I mean, you hear all this stuff about circulation theory and lift... OK, sorry to drag us off topic--back to the engines.
    spaschke, nerobro and akwrencher like this.
