New Alice Starts Taxi Testing
addaon
Feb 24, 2008
2,293
Kanab, UT
Over 500 A water-cooled charging cables are standard, they end up thinner (but still hefty) — see the 250 kW Tesla chargers for an example.
Electric cars have cells that prioritize energy density over power density. That’s not yet an option for aircraft, and is always a tradeoff. In general the discharge and charge cycles of a cell are very symmetric — if you can discharge faster (lower internal resistance) you can also charge faster.
See previous analysis for best guesses on flight duration.
11,368
I am fully aware that there is probably a whole other set of problems to deal with, but after just reading about how much of a charging station would need to be built at every airport in the carrier's route system, and how long it might really take to recharge the batteries, and how many charge cycles the batteries may provide before replacement..... the idea of a swappable chemical fuel cell on a quick disconnect "bomb rack" under the airplane is starting to make a lot more sense to me. An environmentally reasonable fuel cell made out of seaweed and Cap'n Crunch and peanut butter may just be available before the magic battery.
rv6ejguy
Jun 26, 2012
4,915
Calgary, Alberta, Canada
I've been reading about multiple electric aircraft recently so I don't recall which airplane it was applicable to but they stated about 1/2 hour to charge per hour of flight. For short flights like most of these are actually capable of, that doesn't seem like it would affect typical commuter turn around times too much.
5,058
To build a little on that:
Admittedly my work plane seats just shy of 200 but for that many it’s all we can do to get turned around at the gate in an hour and it’s generally unloading/grooming/loading that drives that time. When the plane is parked it’s typically hooked up to ground power so the action of plugging in right away is already there, we’d just need a beefier cable for that if we were to charge a whole airplane.
There are still problems IMO with making an electric airliner work, but I just want to point out that plugging it in isn’t one of them. Folks need to pick a different hill to die on.
11,368
The charging numbers that have been posted on this thread are up into the megawatts. Airliners and short haul commuters are usually based at regional/national size airports, where there are literally dozens (or here in LA hundreds) of aircraft operating at one time.
So it seems to me that the electric airline system would pretty much have to include a nuclear powerplant innstalled at any airport where there are X number of aircraft in operation. Otherwise everyone's lights would dim in the city surrounding the airport whenever an airplane needs to be charged.
I'm a big fan of nukes as one of the more viable solutions to our energy problem, so I don't mind the idea at all. But putting a nuke plant at an airport would become an expensive hill that a lot of environmentalists and politicians would try to die on.
rv6ejguy
Jun 26, 2012
4,915
That will be an issue anywhere where sufficient numbers of EVs of all types show up to charge. In the early days here, a handful of 10-19 seat aircraft like this won't tax the grid too much but that will soon change as most places have neither the generation nor transmission infrastructure in place to support widespread charging of of EVs. This is already happening in CA where only 3% of the cars are electric. When you start talking about 1MW/hr. + batteries, that becomes significant really fast.
rv6ejguy
Jun 26, 2012
4,915
Looking at Flight Aware, it doesn't appear that Alice has made any more flights after the maiden flight nearly 6 weeks ago. That would be strange for a test aircraft unless something serious showed up on that first flight requiring extensive modification or that it was just a milestone flight required to unlock more seed money or increase company valuation.
Voidhawk9
Mar 26, 2012
800
Timaru, NZ
They're still charging the batteries back up. 🤓
