New aircraft - love it
13,249
Now I wonder... with that small wing within easy reach of the pilot (notice he has his hand out on the wing), how likely is his arm and hand to degrade the lift curve of that wing and affect the flight characteristics?
DaveK
Apr 21, 2007
344
Northern California
This reminds me of a surfing magazine. Lots of still shots that look incredible, but what you don't know is the next 5 frames after those stills shows the guy wiping out. But they never show those.
Aircar
Banned
Feb 20, 2010
3,567
Melbourne Australia
I think that it is quite an acheivement in simple technical terms --the aircraft looks quite stable and obviously leaves the water of it's own accord and, presumably returned to it in one piece . The flight duration under power is unknown and might not be so much but basically it functions much as expected within at least a very restricted envelope to date -- give them sone credit for getting to the first step (and let's hope thay put some sort of aerodynamic enclosure around the pilot --having the propblast in his face with likely being wet as well doesn't sound like a lot of fun.
4trade
Nov 1, 2010
527
Lahti/Finland
If you calculate weight/ inch of wing, it will show how small that hand affect is for overall disturb. His hand is on a root, that is very turbulent area already. It can´t affect much.
Designer have pretty much of design experience, and they have already 35 orders, so it might come at final shape and ready for production fast.
autoreply
Moderator
Jul 7, 2009
10,732
Rotterdam, Netherlands
The reason I'm not very confident in this is; why wouldn't they show more of the first flight. They have met and will continue to meet a lot of skepticism and they must be aware of that. No better way to shut all that down then by showing a larger portion of the flight, even if it's just a short hop.
I can think of but a single reason not to do so, you really don't want people to see what happened next. We've seen too many overhyped and over PR-ed products in aviation all ready.
Until they show a video of a flight lasting over 5 minutes, showing start, landing and some gentle stalls, I put this on my "vaporware" list.
The pitch oscillations BBerson noted are fairly large too...
ultralajt
May 9, 2009
1,568
Slovenia
Autoreply, If I take of from water with help of speedboat towing, then release from tow and fly using ground effect, I also would not show take of.. ;)
Head in the clouds
Mar 11, 2012
1,983
I think it'd be a pitch sensitive machine in any case, it's pretty much the same as the Ligeti Stratos in many respects and whenever I saw that flying it regularly jinked around in pitch.
Also that was the first Flynano flight presumably so the pilot really didn't have any feel for it in the first few seconds.
I've performed and also watched a number of first-of-type flights, and I'd like to say that mine were very smooth but I know they weren't and neither were the ones I watched. In fact even in proven designs first flights tend to be a bit shaky so I'm looking forward to seeing the next few - after they repair the damage of course...
Lead Brick
May 15, 2012
70
Nether Regions
Hummm...just seeing couple seconds of flight, looked to me like the CG was a tad too aft. But, yeah, I would have liked to seen it settle back on the water.
Aircar
Banned
Feb 20, 2010
3,567
Melbourne Australia
Surely if they had been towed by a speedboat and cast off as alluded to there would be a boat wake visible ? I agree it is not encouraging to see no actual lift off or touch down --the Terrafugia videos tend to omit those bits as well (or might omit those that do not look good -- fewer landings than takeoffs is generally not considered a good thing ..)
As Allan notes the similarity to the Stratos is quite high --the thrust line is higher which makes for more stability under power but can be dangerous if power is lost (the Winton Sportsman case might be familiar to Allan --with a Htvc of only 0.15 it HAD to have a far aft Cg and high thrust moment to even trim in level flight but if turned,- power off would wrap into a self energizing spiral ) --the Stratos had a nose down thrust moment from the inflow over the strake in front of the ducted prop -the 'custer channel wing effect' which required more flap deflection on the front wing but also made it sensitive to power application --the crosswind case with the front wing sweep was the critical one . With the Flynano taking off on water the crosswind situation is avoided for now - opening up the flight envelope will tell .
Head in the clouds
Mar 11, 2012
1,983
No update to the Flynano website for nearly 18 months, since its one little hop (sans landing). Last they said was that the winter was about to freeze their test patch over but they'd be all go again as soon as it thawed which I guess should have been around March/April, eight months ago. So is this another project that's collected lots of deposits and is now dead in the water?
We have a fella in Oz who claims to be the designated Oz distributor and when questioned he indicated that production dates are 'still on target'.
Does anyone know anything else?
