Hello everyone. Working on designing new tail for my Skyboy. New tail should get a little longer, will be a little higher and not so "flexible" as original 200mm x 2mm 2024T3 tail tube.
One of the options can look like pictures below. Only 2 airplanes I found with this kind of 3-tube tail. Wondering if there is more airplanes out there with tail build this way. Would like to know how they made all connections and stabilizer attachments.
Another question about elevator control. Original design is using aluminum tube installed inside of tail tube on rollers. You can see this system on pictures below. If new tail will be moved up, something will needs to be changed for elevator control. But not sure how. Thanks in advance!
