About 3.5hrs in the tent.
Cut the lightning holes in all the rear wing ribs and flanged them. Used my router with a peice of plywood screwed to it as my hole cutter with 1/4" holes and a bolt as my pivot point in the tooling holes.
First hole I cut the center hole to the larger hole dimensions so that rib was scrap..
After finishing I cut out a replacement rib blank and bent it over the forming blocks. I had my ghetto hole cutter set to the smallest hole size so cut it first...... however it was only supposed to have the 2 larger holes cut in it so reinforcement could be riveted to it on the fuel bay..
so in the end I have 1 extra rib(I still flanged it so it is a good completed rib) and one scrap rib.
Flanging with the dies was easy just using a rubber mallet. I was just careful to keep them square and hold pressure down on the male die once started to prevent it bouncing, I didnt just wail away at it with the mallet but more controlled hits mostly centered to start, then finished off around the parameter once down mostly formed.
On the zenith forum someone posted yesterday having issues with his ribs being warped after hand flanging(not using a die) so I payed close attention to mine to see the difference.
You can see it is stretched some but snaps back straight when the edge flanges are held at 90° so I think it is ok.
All in all, not bad for an evening after work
Total time spent building: 37.5 hours
Total Cost: $8276
Airplane + consumables + project specific costs: $5340
Tools, etc.. I will keep for future projects: $2936
