my project progressing
Dewey Vicknair
Aug 25, 2019
41
Is there glass on the inside of the fuselage? If not, the foam isn't a core, it's a form. What is the design?
Lendo
Feb 6, 2013
935
Brisbane
If there is no Skin on the inside, than the outside is just a skin that takes all the loads. Carbon will helps with Stiffness, but not necessarily with overall strength, such as a composite would provide. The foam separates skins (in most cases) providing stiffness and strength by allowing the skins to share loads and the foam helps transfer those loads from inner skin to outer skin. That's why the foam needs some compression strength to allow that load transfer, also for impact resistance.
George
sming
Apr 10, 2019
258
Great job, you are moving fast! Some comments/thoughts on your hurdles would be nice! So we can learn from your mistakes ;)
Aviacs
Oct 21, 2019
382
Neat processes!
Is this a school project?
Where is the build taking place?
smt
