Move along - nothing to see here
4,220
drstress. What a large amount of time spent on the web when you could have been building and sharing
More than likely all these web posts would need to be accomplished to design his plane.....posting with explanation does not really take much time......and there is probably so much more that has been done but is not posted. There has to be many thousands of decisions and compromises that need to be decided and you certainly will not see a discussion of all those decisions.
Mad MAC
Dec 9, 2004
533
Hamilton New Zealand
I would suggest considering the following points at concept level:
  • Separate high-lift devices from drag creation devices. We have all seen the reports of pilots stalling due to pulling the flaps up to shed drag with an engine failure, being able to shed drag without changing the stall speed reduces the pilot work load (noting that a centre line twin doesn't have half the control issues of a normal twin but it will still suffered the degraded climb rate issue). Also given the high climbs rates of a twin, speed brakes would allow a similar descent capacity.
  • Having some of the vertical fin area below the tail boom is like to increase the tail volume in clear air in a spin. Not withstanding the issues relating to control jamming due to a tail strike.
Mad MAC
Dec 9, 2004
533
"Separate high-lift devices from drag creation devices."
The practical version of this would look something like a single flap setting (probably what would otherwise be takeoff setting, i.e best lift) and drag being controlled by a speedbrake or spoiler of some form.
Nothing original required just pick and mix of existing design elements, cockpit integration maybe be a little bit harder.
ScaleBirdsPaul
Jul 6, 2015
37
Connecticut
How did you like working with VSPAero? I've dabbled in it a bit, and it seems pretty powerful for free software. I found the modeling interface frustrating though, particularly with fuselages. Thanks for the detailed writeup, very interesting read.
ScaleBirdsPaul
Jul 6, 2015
37
Connecticut
VSPAERO is very powerful for the price, that is, it is free.
Before you use VSPAERO, you need to have some understanding of CFD because the documentation is sparse. The primary thing I hoped to get from this thread is to attract VSPAERO users to help me, and everyone else with understanding how to use it.
Trying to extract stability derivatives from the VSPAERO output is frustrating. There have been several questions posed by people on the OpenVSP Google Group about nomenclature used in VSPAERO as it relates to nomenclature found in standard textbooks. There seems to be poor correlation. The programmers of VSPAERO seem to have been writers of great code, but used their own nomenclature that was convenient to express in FORTRAN or C++ or whatever.
I am sure the information is there, but VSPAERO just isn't user friendly to someone actually designing an airplane. This is what I want from this effort. Maybe we can figure this out for ourselves, outside of an academic environment. Please don't assume I have answers to the very real questions you have.
I typically do initial calcs by hand/spreadsheet and then supplement surface data from XLFR5 runs. Although XFLR5 is easy to use, you're limited in the geometry you can build, and I sometimes (often) get squirrely results. I was hoping VSPAero would be a more WYSIWYG software, but it sounds like that's not the case.
4,571
While we wait for someone to walk in with their VSPAERO drag results, I must admit up front I have nothing to offer in that regard. This info is a space filler until then. Honestly, since I last rode the OpenVSP horse, I’m waiting to see through your work if it is likely worth spending a lot of time for the results VSPAero will produce.
What follows may be of interest because:
a) It deals with aircraft drag
b) It contains actual values (well--estimates)
c) The project aircraft general configuration (the Beetlemaster) is similar to Airplane 5.
Background: The Beetlemaster idea is the product of a long running thread here on HBA. In general, it envisions a small, centerline twin aircaft powered by modified VW Type 1 engines of approx 80HP each driving fixed pitch props. Four different concepts emerged from four members who each had slightly different goals:
- Pops: (post 310) Strut-braced, 2 place tandem seat of primarily metal construction. 1500lb MTOW, 140 sq ft wing area, 34’ span (AR= 8.24)
-Autoreply: (post 309) Cantilever wing, 4 place, aerodynamically clean composite construction, ?1600 ? lb MTOW, 126 sq ft wing area, 46’ span (AR = 16.07)
- Vigilant1: Cantilever wing, 2 place, composite wing, 1600 lb MTOW, 126 sq ft wing, 35’ span (AR = 9.7)
- Jan Carlsson: Most similar to Pops’s design.
Drag Estimate:
Parasite drag: This estimate of my version of the Beetlemaster was performed via the method described by Raymer and Roncz for conceptual design purposes. Fuselage, tail, and wing drag is calculated by applying a skin friction factor (based on aircraft and construction type) to the wetted areas of the various structures above. After this, drag from particular additional items (landing gear, struts, a stopped prop, etc) are calculated based primarily on frontal area, and added to the previously computed skin friction drag. For my design:
- Wetted wing area (disregarding fuselage carry-through): 238.38 sq ft
- Wetted tail area: 62.57 sq ft
- Fuselage (incl tail booms): 158.7 sq ft
Total wetted area: 459.65 sq ft.
Skin Friction Coefficient Selected: .0058 Resultant equivalent flat plate drag area of above: 2.67 sq ft
For reference: Skin friction coefficient values for typical composite design: .0050 (Roncz, Raymer)
For typical metal design: Roncz: .0060 - .0065 Raymer: .0058
For typical rag and tube: .014 (Hiscocks)
Additional non-lift drag (equiv flat plate area):
-- Landing gear (Raymer, tricycle, leg and wheel fairings): .41 sqft
-- Stopped propeller (Raymer, fixed pitch, 2 blade, 54” dia, AR 8): 0.9 sq ft.
- Total non-lift effective flat-plate drag area
-- 2 engines running: 3.08 sq ft
-- 1 stopped propeller: 3.98 sq ft
Anticipated parasite drag values:
-- 70kts (climb), SL, two engines running: 51 lbs
-- 70 kts (climb), SL, 1 stopped prop: 66 lbs
-- 120 Kt cruise, 6000’ MSL, two engine running: 126 lbs
Induced drag
--– 1600 lbs, wing as above, SL 70 kt climb: 53 lbs
--– 1600 lbs, wing as above, 6000’ MSL, 120 kt cruise: 21 lbs
Thrust required for level flight, 1600 lbs:
SL, 70 kts, 2 engines: 104 lbs
SL, 70 kts, 1 stopped propeller: 119 lbs
120 kt cruise at 6000' MSL: 147 lbs
Anyway, for what it is worth. Comparing to VSPAERO values for a similar aircraft design would be interesting.
rhbelter
Mar 9, 2015
9
Carmel CA
6-16-19
Ahoy, Airplane 05,
To introduce myself, I’m a (seriously old) TailHook Naval Aviator, and Aero engineer:
The suggested tandem engine configuration discussed is a very good idea. Asymmetric thrust is ALWAYS a nasty thing in any airplane, and you really ought to try it in a swept wing airplane with LOTTSSAA thrust!!!
I had suggested a tandem engine configuration years ago in an article in the EAA Experimenter, as a sensible way to pursue the development of ‘alternate’ engines. Failure of ONE developmental engine in a hot airplane (with two) is less likely to be a serious ‘event’ than an occurrence with only ONE aboard. (virtually NO response or interest). ::: ‘MY developmental engine will never fail!!!’
I offer this consideration for the configuration of an airplane: A tandem engine airplane -w- an extension shaft and a tilt-wing, to make the landing gear reasonable. A tilt-wing is a ‘piece-of-cake’, but the shaft is quite willing to ‘shaft-you’.
The tilt-wing has been done before. The F8 Crusader was such, worked great. First ‘burner I’d flown, and my immediate thought was that I’m finally in an airplane which is NOT seriously underpowered. BTW, ‘FAST’ is not difficult, (but you do hit harder). And: 1000 MPH is fine sport.
The extension shaft is no casual thing. A comprehensive dynamic analysis is in order, along with appropriately measured results. The development of such is likely to be made much easier by using a clutch to de-couple the shaft during start.
For you Reno Go-Fast Sports Racer guys: Rules: … ‘Aircraft are to be powered by an internal combustion engine or engines totaling no more than 1000 cu in.’
I’ve not seen any talk of a tandem pair of 495 cu/in seriously hot engines installed in an appropriate (tilt-wing/extension shaft) airplane. The wetted surface of such would be very little greater than a single engine critter.
Enjoy /s/ Bob
I suggest that a well-done airplane like that would absolutely rule the Sport Racers, and scare the crap out of the unlimited guys.
Enjoy /s/ Bob
10,523
Unlimited is protected by their rules. The winning Sport category airplanes in recent years would finish eighth or ninth in the Unlimited Gold.
4,571
drstress,
Regarding Post 61: It looks like you've done the calculations by hand and included some values provided through the VSP Drag Buldup Workbook. Is that right?
100KT climb speed: Was this chosen as an estimated/anticipated cruise-climb airspeed for Airplane 05? It does seem faster than we'd expect for either Vx or Vy for a plane of this type.
I'd imagine that the most challenging performance case, and the one that might be expected to bound other other choices fro Airplane 05, will be single engine climb at MTOW and high density altitude. If so, modeling that situation at an early point may force useful adjustments to span, power, MTOW, etc. That is, assuming safe SE climb is a rigid requirement, it may be necessary to adjust the design to achieve that in some cases and accept compromises in other areas where it can be accommodated.
flyboy2160
May 25, 2014
332
california, USA
...We aren't going to solve the equation for the airplane neutral point. I even doubt there exists a closed-form solution....
This is an IT Peter SOLIDWORKS palantir error. They get people killed and lose spacecraft. You should never just push the CFD/FEA button and trust the answer. You always should have at least a partial closed form/hand calc. There are other methods besides Raymer's for guesstimating the stability.
4,571
I suppose I was mistaken to assume that safe single engine performance is a firm requirement for the design.
FWIW, lack of adequate single engine performance is, reportedly, why the Gemini project was abandoned by Zenith.
Marc Zeitlin
Dec 11, 2015
609
Tehachapi, CA
Yeah, that's why everything needs thoroughly tested before trusting anything.
"Guesstimating" is a good word for it. We are waiting for that closed-form solution you say we should try.
A 14 second search on google for "calculate airplane neutral point" turns up a stack of articles on doing exactly that - closed form neutral point location calculations - some of them from classes at small, unknown schools such as MIT or the University of Delft.
No need to wait. If you've got some airfoil and geometry data, you can determine the theoretical neutral point.
Marc Zeitlin
Dec 11, 2015
609
Tehachapi, CA
Calculating the neutral point is a very long way from doing a complete dynamic stability analysis (or complete static stability analysis for that matter).
You're right - it is. But the statement I was responding to was the one where you said this:
"...We aren't going to solve the equation for the airplane neutral point. I even doubt there exists a closed-form solution...."​
and then, in response to flyboy2160, you said:
"We are waiting for that closed-form solution you say we should try."​
So I pointed you to a closed form solution. Just talking about neutral points, as you were.
PiperCruisin
Jan 17, 2017
146
Idaho
I'll even do you one better. If you read through the course notes for AOE 3134 there is a solution to calculate the neutral point for an F-104. The solution runs through nine pages and even then Lutze (the professor) only claims it to be "an estimate".
I've done a fair bit of worrying about the neutral point and static margin. There is a lot of information in the equations. I've looked at dozens of sources for a good explanation. John Roncz's spreadsheets seems to provide a good calculation if you can find them. VSPaero seems to provide a reasonable estimate if you include the fuselage (included in Roncz's spreadsheet) which can have a significant impact.
Airplane Performance Stability and Control by Perkins and Hage seems to be where a lot of it originates. An oldy, but a goody.
As far as a closed form goes, it seems it would be a complicated equation. Usually, you probably solve for a couple cg locations or iterated to a location for neutral stability. Eventually you take your best "estimate" and move on. I've asked a lot of aero engineers about it and rarely got a good explanation. This probably explains why they spend years doing envelop expansion testing.
drstress
Aug 12, 2018
9
Constraint Analysis
We can now perform an analysis that will estimate the required horsepower for several different flight conditions.
The “Drag Buildup Workbook” gives us a method to estimate parasite drag for different flight conditions depending on speed, altitude, propeller scrubbing, etc.
There is an important omission in the calculations for the "Constraint Analysis". Put there on purpose to see what would happen. All of the calculations are simple "hand, closed-form" calculations any high school algebra student should easily follow. Since no one commented on any of them, I think either no one bothered to look through them or no one has the expertise to understand them.
Either way this is my last post. I'm sure the "good ole' boy" club will pointlessly blabber on and on about any and all of my attempts to bring a small amount of order to what has to be the most random assortment of opinions I have ever experienced.
Since I don't fit in to this culture, I will welcome it as a badge of honor to be exorcised from HBA.
