Right you are! I'm ready now for Jeopardy! "I'll take azeotropes for 500"Maybe not simple:
Azeotrope
This just in: As the temperature of the E10+water mixture decreases (in storage, in your plane fuel tank, presumably also in your carburetor throat), the ability of the mixture to hold water does decrease.
From this document: https://www.epa.gov/sites/default/files/2015-09/documents/waterphs.pdf
So, if your airplane fuel tank filled with E10 is at 70F before flight and you take a fuel sample from the sump, you might find zero water. Still, there could be up to 0.525% water (by volume) in that fuel and it wouldn't separate out (it would virtually all separate out and be visible in your fuel sample if the fuel were gasoline instead of E10). If you have 10 gallons in your tank, there could be up to 40 teaspoons (0.83 cups, about 200ml) of "dissolved" water in the E10.
Now, if we lower the fuel temperature (in the tank on a cold day at altitude, or in the carb) to 20 deg F (carb throat temps are often that low), the E10 mix can only hold about 0.35% water (by volume). At that temp, one third of the water that was in "solution" will separate out, or about a quarter of a cup in your 10 gal tank (that showed zero water when you "sumped" it). That's enough water to fill up a carb bowl or, as ice, occlude a carb throat (without any added atmospheric water, add that in as another factor toward ice formation). I am NOT saying it does that, I am saying that we can sump all we want before takeoff and if there's E10 in the tank and it could get colder at any time, then we could have water, and maybe ice, issues.
Good information. One time I had a throttle cable break. I made the runway by a few feet. At the time I never thought about using the primer to get a little extra power.That is the danger of using high methanol content fuel......if your fuel is on the verge of phase separation (when the water/methanol mix drops out of solution), you will have a mixture of water and methanol that will not support combustion sitting in the bottom of your carburetor due to cooling as you climb higher leading to an engine stoppage.
I would suggest that a good test to see how close you are to phase separation is to take a sample of fuel, and add perhaps 1% water, and see what happens.
Fuel injection and Throttle bodies will not suffer from the potential engine stoppage as there is no float chamber to collect the nonburnable mixture. With carburetors if you suspect your engine failure is down to water in the carb' pump the throttle (if you have an accelerator pump) to clear the water mix, or use the primer to provide an uncontaminated fuel supply. It might just get you to the field.
OTOH, while carburetors without float bowls (Posa, RevFlow, AeroInjector, and other slide carbs with a needle valve to dribble fuel) don't have a float bowl to collect water, they also lack the fuel 'buffer" that a float bowl provides. So, if the fuel develops vapor bubbles in the fuel line (which ethanol blends are more prone to than gasoline or 100LL), then the engine will, at least momentarily, stumble as each bubble reaches the needle valve. These "burps" are a known issue. Even though they might not significantly reduce total power, they can mask other issues. Folks have taken off with an engine "burping" because they are used to it, then they lose power entirely at some point because, on that day, the rough running was due to something more serious.Fuel injection and Throttle bodies will not suffer from the potential engine stoppage as there is no float chamber to collect the nonburnable mixture.
Pops:
That might have worked if you had broken the mixture cable. Adding more fuel when the throttle cable breaks should give you less power as the mixture will go very rich when you add fuel from any source - especially the rather large volume delivered by primers.
Of course, the correct answer is to fly a diesel so you don't have carb heat/ice/contamination/mixture problems
Quick comment: Methanol is not Ethanol... Methanol is quite corrosive and has a max specification as natural yeast metabolite existing in trace quantities of 0.5% per ASTM D4806 fuel ethanol specification. In practice, quantities are <0.1%, 0.05% is a general expectation for methanol, near the lower end of GC accurate detection. It's used in racing, but those engines may see a only few minutes of run-time before a complete tear down, like the top-fuel dragsters as example.That is the danger of using high methanol content fuel......if your fuel is on the verge of phase separation (when the water/methanol mix drops out of solution), you will have a mixture of water and methanol that will not support combustion sitting in the bottom of your carburetor due to cooling as you climb higher leading to an engine stoppage.
I've run M85 extensively in street and race cars for a few years when it was available here at a cardlock, winter and summer. Problems encountered were hardening of some rubber hoses, swelling of others and hard cold starting in winter. Otherwise no other issues. Plugged the car in in winter and changed the hoses to methanol resistant ones. No draining of fuel, no water problems. Allowed super high boost pressures and no ignition retard, making impressive hp figures. Probably have around 40,000km running the stuff in total on several different turbo cars. Fuel economy wasn't good but I was legging it most of the time too.Quick comment: Methanol is not Ethanol... Methanol is quite corrosive and has a max specification as natural yeast metabolite existing in trace quantities of 0.5% per ASTM D4806 fuel ethanol specification. In practice, quantities are <0.1%, 0.05% is a general expectation for methanol, near the lower end of GC accurate detection. It's used in racing, but those engines may see a only few minutes of run-time before a complete tear down, like the top-fuel dragsters as example.
The actual % is rarely that high here in the Midwest. It varies with time of year (due to the average temperature fluctuations). Typically, terminals offer high ethanol blends from 50 to 75%. It depends on where it's going to be sold. As to the octane, ethanol is an octane enhancer, and a 10% blend will give a 3 to 5 point increase. It takes 83 octane neat unleaded up to 87. It takes 91 octane neat premium up to 94. I think the highest octane we posted for a blend recipe was 104, but I don't remember the ethanol % (I'm retired, so the memory is going!). The thing about adding ethanol is that it effects the vapor pressure as well, so you see a drop in fuel economy due to increased evaporation (keep your tanks full to minimize that). Also, it has a strong affinity for water vapor, and entrained water in your fuel, so there's chances for phase change dropping water into your tank, or pulling water/sediment into your fuel line. Check those fuel filters!What octane is the E85 you guys are talking about?
Not a lot, but 10% ethanol raises RVP about one pound. If you run off the bottom half of the tank, you get a lot of moisture in through the vent, which condenses, drops into the tank, and can be brought into suspension by the ethanol. Water doesn't burn, so the wet fuel gives less power, meaning more is needed to compensate. We got grief all the time from drivers claiming less MPG. On the other hand, their fuel systems were cleaner than a hound's tooth...I hope the evaporation rate in a closed but vented tank isn't high enough to perceive a drop in fuel economy from the time you fill it to using it.
I find lots of folks theorizing about water separating with alcohol fuels. You need a lot of water in the fuel before this will happen and it's not going to happen under normal circumstances with a fuel tank and small vent. In Canada, people used to add little bottles of methanol to take up any water in the gasoline to prevent that water from freezing in the lines supposedly. We'll that almost never happened so they were wasting their money however the theory is sound. Alcohol absorbs the water and allows it to be carried through the system. In any normal quantities, you will notice no difference in engine performance.
We use water/ methanol injection (ADI) on Reno race planes where the ADI rate may reach over 25% of the fuel flow rate (12.5% water). They run just fine.
I've run M85 a lot in a climate where OAT can change up to 20C in an hour and go down to over -40C in winter. This would have resulted in high condensation rates inside the tank IF there was saturated air inside. Never had any water issues. Engines never skipped a beat.
This is a pleasant and welcome surprise to me seeing curiosity and exploration in alternative fuels on this forum. Many of the post made are technically pretty close, enough within "Ozark Math" that the points made are absolutely valid, e.g: concepts of increased cooling (That's from higher latent heat of vaporization versus gasoline), the fuel mileage observations on non-optimized engines (not taking advantage of effective ~116 octane with higher compression), the fact it will clean a dirty system, it will affect rubber not formulated to handle it, etc.
A couple comments for clarity, and disclosure: I'm in this biofuels industry serving as Technical Director for my employer. There was somewhere above mentioned similar to "Ethanol does not mix in gasoline because its polar opposite to petroleum gasoline". That's 100% in error. Not all alcohols, but Ethanol is what's called a polar-covalent compound. Ethanol is 100% miscible into covalent hydrocarbon gasoline, at any concentration. Ethanol being polar-covalent means its also 100% miscible in water at any concentration (why melting ice in your scotch and water does not separate into layers you notice while sipping it.). Something not typical in industry, but common in the gallon gas can of lawn mower fuel sitting for a few years is "phase separation". E-XX (say E-10) retail gasoline will absolutely have the ability to absorb water. It's part of why gas lines aren't freezing in the winter from water ice. The tiny bit of water you may see when you check tanks and gascolator on pre-flight would not be found running an ethanol fuel because it will be dissolved into the fuel...BUT it can only hold so much polar water before rejection by the covalent hydrocarbon. The ethanol/water will phase separate and settle below the hydrocarbon. Phase separated fuel should never be used in an internal combustion engine.
The only time I've ever seen microbiological activity in tanks has been in fuel storage hydrocarbon gas tanks, diesel, etc.. If tanks are not sumped regulary just like you do on pre-flight, the water that condenses or infiltrates from somewhere will develop into a substantial layer (Think fuel tanks on a ship... water added as fuel is consumed for ballast as an example). This water layer on the bottom is where microorganisms will get a foot-hold.
Very happy to discuss, offer opinion, etc as desired on this topic. Be Safe and Well - Phil
Hi Phil,
My information came from a talk a petrochemical engineer gave at a joint SME/ASM meeting in Grand Rapids, MI whew - some 10-12 years or so ago. I had my personal experience using E-85 to clean the fuel system of a chain saw and seeing the oil separate from suspension in the unused fuel remaining in a milk jug. I asked of this and it was he that went into the whole phase change & polar charge - organic chemistry realm that most of us had not dealt with since high school/college chemistry. If something was stated wrong - or - interpreted improperly - I certainly do appreciate any discourse on your part. I enjoy learning.
I owned several different businesses over the past 40+ years in metalworking, manufacturing and mining. My neighbor operates a dry marine service. I also worked more recently for a few years in a materials consulting lab. I have seen the results of microbiological activity in fuel on a number of occasions. Some personal - in gasoline and diesel fuel systems and one from my neighbor on a boat. While at the lab, we had a marine surveyor who was dealing with a boat that had an effected fuel system. It entered discussion with my boss as he had brought us the most vivid example of anaerobic pitting I will likely ever see - a stainless steel propeller shaft from a twin screw boat that had been moored in mud against the river bank. The pits were so severe that the shaft broke from fatigue and a portion of shaft and the prop were lost. I still have the scrap part of that shaft. I'd like to see the prop and piece of shaft that are lying on the bottom of Lake Michigan.
As I mentioned earlier, I've watched for this and in the past 10+ years of using E85 in cars and boats I've seen maybe 3 cases of actual phase separation. All three were in boats that were docked full time and left to sit for months. I've never seen it in an automobile. Even in the deep South where we see very high humidity.
Another thing- "pump" E85 is not very consistent, with it showing between e70 and e90. This is fine for most applications. However for highly tuned turbo cars we mixed our own from verified E100 and 87oct pump gas.
I would likely do the same for an aircraft, although one fitted with a flex fuel sensor making the fuel and timing corrections would likely work just fine.
