Minimax wings on an Affordaplane
Discussion in 'General Experimental Aviation Questions' started by kirbylee, Nov 11, 2019.
  1. Nov 24, 2019 #21
    GeorgeG
    GeorgeG
    GeorgeG
    Jan 8, 2019
    16
    0
    Tracy, CA, USA
    And, FWIW, the aoi of the A-plane is 1.1*
  2. Nov 24, 2019 #22
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,748
    3,358
    Las Cruces, NM
    Also FWIW a second set of eyes agrees with your math. ...if it's a 54" chord.
    mullacharjak likes this.
  3. Nov 24, 2019 #23
    kirbylee
    kirbylee
    kirbylee
    Mar 28, 2019
    75
    8
    Ok, you guys lost me. FWIW, Aoi, 1.1*? I have no idea what that means.
  4. Nov 24, 2019 #24
    kirbylee
    kirbylee
    kirbylee
    Mar 28, 2019
    75
    8
    Yes, cord is 54".
  5. Nov 24, 2019 #25
    Bille Floyd
    Bille Floyd
    Bille Floyd
    Sep 26, 2019
    105
    42
    FWIW = For What It's Worth
    AOI = Angle of Incidence
    Bille
  6. Nov 25, 2019 #26
    kirbylee
    kirbylee
    kirbylee
    Mar 28, 2019
    75
    8
  7. Dec 6, 2019 #27
    kirbylee
    kirbylee
    kirbylee
    Mar 28, 2019
    75
    8
    For the minimax wing to be at the same height as the affordaplane I have to make the attatch point 3 1/2 " above the tube.
    I'm having a hard time doing that without adding alot of weight. Would it make any difference if the mm wing was three inches lower. I think there is still plenty of head room.
  8. Dec 6, 2019 #28
    mullacharjak
    mullacharjak
    mullacharjak
    Nov 5, 2010
    117
    29
    Peshawar Pakistan
    kirbylee
    You got me interested in the affordaplane! Can you post some pictures of your fuselage.Is it per the plans?
    More than a few are flying.I think it is catching on.
  9. Dec 6, 2019 #29
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,748
    3,358
    Las Cruces, NM
    If you're happy with the head room I don't see why it would be a problem. But I think you could raise them 2" without adding much weight or hassle.
  10. Dec 6, 2019 #30
    mullacharjak
    mullacharjak
    mullacharjak
    Nov 5, 2010
    117
    29
    Peshawar Pakistan
    I think the Stewart Headwind wings would work very well on the Affordaplane.Thay are much easier to build than the minimax wings if someone decides to go from scratch.
  11. Dec 6, 2019 #31
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,891
    1,791
    Upper midwest in a house
    I would just build the whole Stewart Headwind as it's at least 10x better than the AP
    Topaz and mullacharjak like this.
  12. Dec 7, 2019 #32
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,748
    3,358
    Las Cruces, NM
    Do we have to go through this crap again? It's apples and oranges. The Headwind is also 10x more complicated and more expensive to build. Old fat guys don't like the yoga contortions you need to do to get into them. People who don't want to do any welding wouldn't want to build one. The spars for a set of Headwind wings cost almost as much as the fuselage of an AP. etc. etc.
  13. Dec 7, 2019 #33
    3,963
    1,165
    fuselage/engine weight distributions probably are different.....be very careful as to where you mount the wing and doing your weight and balance calculations.
  14. Dec 7, 2019 #34
    kirbylee
    kirbylee
    kirbylee
    Mar 28, 2019
    75
    8
    I have a few pictures I can post. I'm just not sure where to post them. Let me look.
  15. Dec 7, 2019 #35
    kirbylee
    kirbylee
    kirbylee
    Mar 28, 2019
    75
    8
    Here is a couple that turned out ok.
  16. Dec 7, 2019 #36
    mullacharjak
    mullacharjak
    mullacharjak
    Nov 5, 2010
    117
    29
    Peshawar Pakistan
    The LG seems a bit different.Looks like its based on the airbike LG.Looks good otherwise.
    I think it should be a very quickbuilding aircraft.
    With minimax wing it should have similiar flying qualities.I hope.Not that the affordaplane wing is any less,though.
  17. Dec 8, 2019 #37
    kirbylee
    kirbylee
    kirbylee
    Mar 28, 2019
    75
    8
    I got the idea of the landing gear from a picture of a challenger. I have to make another pair of brackets that attatches the legs. Those are a little off.
    If anyone needs a pair of wheels and tires, I'm going to sell those on the plane.
    I agree.
    proppastie likes this.
  18. Jan 7, 2020 #38
    kirbylee
    kirbylee
    kirbylee
    Mar 28, 2019
    75
    8
    Not much of a drawing but if you can make sense out of it, tell me if making the gussets as large as this is overkill. The reason they are so much higher than the original AF is because the MM wing attatch straps are at the very top of the spar. Thanks Lee
  19. Jan 7, 2020 #39
    mullacharjak
    mullacharjak
    mullacharjak
    Nov 5, 2010
    117
    29
    Peshawar Pakistan
    Looks good.The cross tube for the strut attach may have to go back a bit to stay inline with the front spar.
  20. Jan 9, 2020 #40
    GeorgeG
    GeorgeG
    GeorgeG
    Jan 8, 2019
    16
    0
    Tracy, CA, USA
    Lee, could you move the attach straps down, to the lower part of the spar?
