Minimalist Glider
Discussion in 'The light stuff area' started by erkki67, Feb 15, 2019.
  1. Feb 15, 2019 #1
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,181
    117
    The Platz Glider, from the thirties, wondering if this could be used for a bit more modern layout, pulled by the Fritz Ranger into the air?! :)
  2. Feb 15, 2019 #2
    jedi
    jedi
    jedi
    Aug 8, 2009
    1,662
    372
    Definately! Yes. There have been prior discussions on HBA and videos are posted of a similar configuration hang glider from many years ago (80s?). I was impressed.
    I do not know about the "Fritz Ranger". A google search only brought up the Vashon Ranger. I have seen it discussed here on HBA but do not know details.
  3. Feb 15, 2019 #3
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    4,491
    1,186
    Marion, Ohio
    Or is that a kite?
    I see at least 3 lines going off from the corners, attached to something on the ground.
  4. Feb 15, 2019 #4
    dew777
    dew777
    dew777
    Aug 7, 2017
    23
    8
    AZ
    I might be wrong but to me a "Hang-Glider" IS a kite ~ instead of a "string" pulling it to the ground the operator's gravity is what pulls the thing back toward earth.
    oriol likes this.
  5. Feb 15, 2019 #5
    dew777
    dew777
    dew777
    Aug 7, 2017
    23
    8
    AZ
    Ok, that was REALLY over-simplified. . . I know that modern hang-gliders have an air-foil (the battons force this shape into the dacron) that generates lift by forward motion.
  6. Feb 15, 2019 #6
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    2,378
    416
    capital district NY
    That kite looking thing looks like an opportunity for a bon fire, snaps, jagermeister. and "who wants to go up next"? "You want to go higher"?
  7. Feb 15, 2019 #7
    5,649
    1,831
    Not a kite.
    [video=youtube;9LVtc8l3Z5o]https://www.youtube.com/watch?v=9LVtc8l3Z5o[/video]
    pictsidhe and jedi like this.
  8. Feb 15, 2019 #8
    2,593
    1,439
    Someone on this forum built one, it was even in his avatar picture. I forget who it was, though.
  9. Feb 15, 2019 #9
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    4,491
    1,186
    Marion, Ohio
    Ah, yes!
    Much better view. Thanks, HW!
    Then what are they doing with those lines? Looks like a good opportunity for a "TWANG-KATHUMP".:shock:
  10. Feb 15, 2019 #10
    5,402
    4,391
    That is the Platz sail-wing glider, designed by Reinhold Platz who had designed many of the more famous WW1 aircraft for Fokker. He was one of the leading aircraft designers of his day I believe. Definitely NOT a backyard Bozo.
    The intent of the design was that Platz could roll it up into a hang-glider-like tube and transport it to the flying site by bicycle. This was so he could fly something that did not violate the Versailles Treaty.
    I built a free flight indoor model of it, using a small electric motor, and it flew acceptably.
    We already have several choices for a modern "minimalist glider", the Sandlin GOAT, BUG, and Marske Monarch among others.
  11. Feb 15, 2019 #11
    ypsilon
    ypsilon
    ypsilon
    Mar 1, 2016
    259
    71
    Austria
    I think you are referring to this gentleman.
  12. Feb 17, 2019 #12
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,181
    117
    But this bird uses the steering bar of a normal hanglider.
    The Platzglider was controlled by the two elevators directly.
    I’m wondering if the technology used on the sails of the windsurfers could be used for a new design of the Platz Glider?
  13. Feb 17, 2019 #13
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    North America, Earth, Milky Way Galaxy
    Hang gliders evolved away from loose sail to battens and airfoil shaped ribs for performance and safety. Back in the good old days of loose hang glider sails, pilots dreaded the "full luft dive", the first production models of the Weedhopper U/L also used an undefined sail, a shortcut that lead to several tragic accidents. Shaped battens or ribs to maintain the airfoil are in IMHO a absolute necessity.
    oriol likes this.
  14. Feb 18, 2019 #14
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,181
    117
    I'm not against shaped battens I think its even a great idea.
    So how would such a glider look a like with shaped battens and an airfoil similar to modern hang-glider, but with the simplicity of the Platz Glider?
  15. Feb 18, 2019 #15
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
    First off it shouldn't have a gap between the main wings, I also don't think too much of the hand held jib/canard arrangement. It would be a good project to construct a 1/4 scale R/C model to determine if it is an efficient flyer compared to other modern hang glider designs, my guess would be... no.
  16. Feb 18, 2019 #16
    Highflight
    Highflight
    Highflight
    Dec 20, 2010
    155
    25
  17. Feb 19, 2019 #17
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,181
    117
    So, how could this glider being improved in therms of performance and security referring to the modern hang gliders?
  18. Mar 22, 2019 at 4:44 PM #18
    ARP
    ARP
    ARP
    Nov 24, 2009
    300
    33
    Darenth, Kent / England
    As Tiger Tim says I use the picture as my avatar. This was not a copy of the Platz although it has a similar plan form. The basic concept was to use a sailboat type rig with a jib and mainsail enabling high angle of attack without stalling.This gave very slow flight with an aerofoil that was self generating having no battens. It was capable of soaring flight and far better than the Rogallo hang gliders of the day 1974/75.
    Some video of it flying is on Youtube.
    Tiger Tim likes this.
  19. Mar 22, 2019 at 5:08 PM #19
    ARP
    ARP
    ARP
    Nov 24, 2009
    300
    33
  20. Mar 22, 2019 at 5:44 PM #20
    dew777
    dew777
    dew777
    Aug 7, 2017
    23
    8
    AZ
    @ARP,
    I like that idea :) Did that design ever wind up in "public-domain" ? I'd be interested in seeing drawings of it.
