Miata
wiloows5050
Jul 28, 2007
304
Elk Grove Ca
Has anyone heard of or seen plans for a conversioin of a Miata engine for homebuilt use? I'm trying to find a light weight engine 100 -150 hp to hang on my Fokker DVII project.
jumpinjan
Oct 3, 2004
313
Dayton OH
You need a light weight engine in your Fok D.VII??? The original 185hp BMW is about 650 lbs, maybe more. With that weight budget, you could use a 300ci Ford I6 truck engine & some lead bars? Am I wrong?
Jan
wiloows5050
Jul 28, 2007
304
Elk Grove Ca
The total gross weight of the DVII is around 500 - 550 lbs. I'm looking at an engine under 200 lbs.
jumpinjan
Oct 3, 2004
313
Dayton OH
Oh, you're building a Baslee 80% Fok D7 too? One of my friends is using a belt-drive VW in his D7 and another friend is thinking of using the grear-drive Geo in his D7. I think its a Geo 4-cylinder version.
Jan
PS I don't think you can build one at 550, think more like 600-700
wiloows5050
Jul 28, 2007
304
Elk Grove Ca
Your probably right about the weight. I'm planning on using an airtrike redrive. I'm looking at a earlier 90's miada to try and cut the weight.
Canadian_JOY
Nov 26, 2007
8
Canada
Why a Miata engine? That inline, liquid cooled 4 cyl engine is not in any way light. I could see you going to a Mazda rotary for this project in order to save weight, but not an in-line 4 with associated heavy cooling.
Of note, a Corvair engine will be about 230lbs installed. That might be a better alternative, and will make a very honest 100hp.
jumpinjan
Oct 3, 2004
313
Dayton OH
To keep the Fokker's original appearance as much as possible, he wants an inline engine and not the opposed engines (and he needs to run a gearbox).
Jan
