Metal primer paint
Discussion in 'Finishing Techniques' started by ZENO, Mar 2, 2006.
  1. Mar 2, 2006 #1
    ZENO
    ZENO
    ZENO
    Feb 22, 2006
    56
    0
    New England
    Hey, I'm looking for something to primer metal parts without going to zinc chromate.
    I want something for the frame that I can shoot myself from hvlp and not a 2 part paint, but is good to stick fabric on.
    Does such a thing exists?
    ZENO
  2. Mar 2, 2006 #2
    Craig
    Craig
    Craig
    Jan 30, 2003
    543
    0
    Jupiter, Florida
    Metal Primer
    Zeno, I've had the best success with PolyFiber's two-part epoxy. Yes, it is two part, but very user friendly. Comes in green or yellow (yucky color!)
    The problem with most other paints is that the MEK and toluene in the fabric adhesive and coatings will soften the underlying paint - something you really DON'T want to happen!
    The elevator that I recently made and covered for a friend was primed with a supposed "epoxy" two-part paint. We installed it after priming, to check fit, etc. Got some grease on it from the hinge pins.
    Well, I went to wipe it down with MEK prior to starting covering - the stuff wiped right off! He was kinda PO'd when I told him to sandblast the whole thing, and prime it correctly, but I told him he would be even more PO'd when the fabric peeled off while flying.
    Use a good quality primer, and test it for compatibility.
  3. Mar 3, 2006 #3
    Captain_John
    Captain_John
    Captain_John
    Feb 4, 2003
    699
    1
    KPYM
    Hey ZENO!
    I really like DuPont VariPrime. It too is a 2 part paint, but not an epoxy. It has no "kick" time and a 24 hour (I think) potlife.
    I am looking into the DuPont Nason line also. You can get them at CarQuest, Rainbow Paint Supply and Allied in Brockton, MA.
    :D CJ
  4. Mar 3, 2006 #4
    jumpinjan
    jumpinjan
    jumpinjan
    Oct 4, 2004
    313
    6
    Dayton OH
    The main player here is epoxy primer and just about no other material that provides the superior mechanical hold and sealing properties to not just metal, but most all surfaces. Epoxy does not have the toxic activator (isocynates), so you don't need a full body suit & fresh air supply (just a respirator) so this makes it very easy & safe for the do-it-yourselfer. Just about all the solvent based primers (including the rattle cans of zinc chromate) will liquify when fabric cement is applied, as mentioned.
    Capt John - I'm not sure, but I think VariPrime is solvent based. There are 2 containers, but it is not an activator/hardener polymer, it is 1) a vehicle (solvent based resin) and 2) an acid (phosphate acid). I'm pretty sure about that.
    Jan
  5. Mar 3, 2006 #5
    ZENO
    ZENO
    ZENO
    Feb 22, 2006
    56
    0
    New England
    Primer
    I love this site. Thanks guys.
    I think I'll go with Craig in door #1.
    Lots of hardware that doesn't have fabric hanging on it I can go with rattle can Zinc. On the wings, the wing bows and the top wing inboard wing bows will have to go with the Poly fiber.
    Ya gotta do what ya gotta do!
  6. Mar 3, 2006 #6
    Craig
    Craig
    Craig
    Jan 30, 2003
    543
    0
    Jupiter, Florida
    Fabric
    Capt. John has one of those plastic planes - no fabric to glue on, heat shrink, etc. He can use the VariPrime - which is what the MEK was cleaning off those steel tubes the other weekend!
    One of these days he'll get a real airplane. 4130 tube. Fabric covered. No lid over his head. Bugs in his teeth 'cause he'll be smiling so much!
    At least he won't freeze in the winter flying like I do.
