My opinion, after reading the therad:
Nice build. Not perfect, but good enough for test. Covering with modeling heat shrinkable covering film will reveal the structure, so tiny longerons over the geodetic structure will help to get streamlined body and covering will be easier to apply.
Covering geodetic structure with a solid skin (plywood) is nonsence. If stucture is covered with solid skin, one need just to prevet its buckling by placing ribs (fuselage formers) and longerons at apropriate distances each to other. Geodetic structure resist both bending and torsional loads on the fuselage. Why then covering it with a solid skin, that will accept that loads instead. Even if one say that both (geodetic structure and solid skin together) will be stronger than each of them alone, hence greater combined strength, it is very hard to calculate loads and stress in such structure and do proper dimensioning of them.
Vickers Wellington WW2 bomber was geodetic structure, covered with fabric over some longitudinal (non structural) strips.
Mosquito, also WW2 bomber, was wooden, but solid sandwich skin (plywood/balsa/plywood) with sparse longerons and just a few load accepting fuselage formers.
I believe that geodetic structure is too complicated and brings no benefit in comparision to other more used technologies to build wooden aeroplanes.
Mitja
