D Hillberg
Make a model for flight test ... Looks interesting
About right. A common .40 glow engine is about 1 hp.So a plane designed for 120hp would need to be limited to less than 1hp for the 1/5th scale model? or are there other aspects to consider as well? (or I am completely wrong....)
Acknowledged that this design demands compromises. Was planning to move the tail further back.Joined wing designs... UGH!
Much written about.
First are biplane issues. If the wings are stacked one above the other, you are trying to simultaneously make low pressure above the bottom wing and high pressure below the top wing - in the same space. No problem, put in at least 1 MAC of stagger and 1.5 MAC of wing separation, and things are better. Ugh.
Then we go and join the wings, and now the low pressure along the top of lower wing bleeds off high pressure from the bottom of the top wing. Ugh.
You can do the box wing thing with the upper slid back far enough to be the horizontal tail. Then the low pressure on the top of the bottom wing is the low pressure on the bottom of the horizontal tail. Trouble is you get a lot of wetted area in the join, the horizontal tail is big with a lot of wetted area too, and the tail arm is short, which when it gives you adequate horizontal tail volume, it tends to be short on pitch axis damping, and the large tail with a short arm requires big downward lift and thus a lot of induced drag increase. Then the pressures on the wing and the pressures on the tail become linked, which can make for difficult control. Ugh.
Then as a seaplane, the lower plane is deep in ground effect during takeoff and landing while the upper plane (however it is working) is also in ground effect, but not as deeply. Ugh.
In the end, you want the tail mounted further back and not aerodynamically coupled to the wing pressures. To bring the tail forward and couple things up compromises the heck out of lift, control, and damping. UGH.
Now if you just gotta have it, go for it. And make the lifting surfaces oversized, or you will not get it unstuck...
I was planning on a 1/4 scale. for no other reason than I thought it would make the calculations easier. I know this all has to do with Squared Cube Law in some way or another in that the dimensions of a model plane scale perfectly but the weight and horsepower do not. But I'm really glad you brought this up because my intent was to pursue the use of materials that would be a close approximation, at scale, for the real world construction materials. So is it safe to say that an SLA Amphibian that is permitted to weigh 1430 pounds total would translate to a model weighing in at 11.44 pounds?When building scale models for testing, I am curious how power is scaled.
A 1/5th(0.2) scale model is really 1/125th(0.008) the volume(and if scaled for weight mass as well?), correct? (scale cubed, aka in all 3 dimensions)
curious how that all works together, as I haven't done any modeling or even know what is available for realistic testing purposes (as opposed to just for fun)
Hi Dennis. I attempted a drive down Main Street via Google Maps but I was unable to find said prototype. Do you recall any additional information as to it's location? Was it in town, or down the way. Main street dead ends at one point to it may just be a matter of following it away from town for a while. What do you remember? If it's still there I'd like to see it. Edit. I went ahead and did as you suggested and wrote to the Chamber of Commerce. Hopefully it's still there and they cooperate. Even better if they have the designer's name. If I borrow anything from him I want to give him proper credit.There's a fellow in Henrietta Okla that built a Prototype of what I see in your picture . It sets on a pedistal on main street . You might call the Henrietta Chamber of Commerce and see if they can get you a picture of it . Don't know the guy personally but a couple of friends and I were returning home from an EAA Chapter meeting and stopped in a small cafe 40 or so years ago and this guy was having coffee late that evening and met him . He drew this craft on a napkin . We didn't take him too seriously but one day when passing through , I saw it there . Can't tell ya if it ever flew or not but was very interesting . He most probably has passed on by now as he was older at that time . It was definately his dream of flying .
Sounds like a plan. I'm going to have to be certain about these Cube Square calculations though.This is the absolute perfect case for sub-scale model testing, as has already been mentioned. You will have a fantastic experience building a 1/5 scale model, a fantastic experience troubleshooting all the little issues and getting it to fly. Then the results of the 1/5 scale model will tell you whether your idea was good enough to build a 1/3 scale model. If you can get the 1/3 scale model to fly well, with higher and higher weight, then you would be in the best position to determine if a full-scale prototype is worthwhile.
You just described my experience with the Sea-Era (Billski, Thanks for the input. Truly, I am not trying to reinvent the wheel where it comes to the construction. I've just been working things out in my head. Various ways of doing things in a manner that will serve the required function. what I am trying to do that is new is to have an amphibious aircraft, that is not so much amphibious as it is a true fusion of boat and airplane. I see a lot of amphibious aircraft designs, but none of them that truly serve a dual purpose as a boat. That's my inspiration and my design challenge. I want to be able to dive off the prow of my boat, swim around the backside and climb back up. Sit with my legs straddling the prow, and fish for perch dinner. Oh, gosh. It's late. Can't fly at night. No problem. Don't have to. Fold the wings back and speed back to the boat ramp over the waves. You get the idea.
Thurston says add the power loading and wing loading. The combined total should be around 25 for a sporty plane or 30 for the average four seater. The Cherokee 140 is 20 solo and 28 at gross.Airplane performance can be pretty well summed up, regardless of size, by looking at loadings and
It has been a long time since I went through his books, where does he say that?Thurston says add the power loading and wing loading. The combined total should be around 25 for a sporty plane or 30 for the average four seater. The Cherokee 140 is 20 solo and 28 at gross.
Hi there bosco . It was setting on the main street , not much more than 3 or 4 blocks off of 75 headed West , on the right hand side right next to the road . I don't think it would have been hard to see from the red light as you turn off of 75 . (if you knew where to look ) but would be hard to miss if on the main street . It was kind of a land mark and I'm sure it got alot of attention . I would almost bet that someone at the Chamber will be able to come up with a name for you . I get up that way regularly and I'll look and ask around . Will let ya know if I tag on to any info .Hi Dennis. I attempted a drive down Main Street via Google Maps but I was unable to find said prototype. Do you recall any additional information as to it's location? Was it in town, or down the way. Main street dead ends at one point to it may just be a matter of following it away from town for a while. What do you remember? If it's still there I'd like to see it. Edit. I went ahead and did as you suggested and wrote to the Chamber of Commerce. Hopefully it's still there and they cooperate. Even better if they have the designer's name. If I borrow anything from him I want to give him proper credit.
Thank you for sharing this video about Paul Weston's work. I 've seen a short clip of the "crash" but did not know the name of the plane nor it's creator. It was gratifying to hear Paul say that he had designed the delta hull with the intent of it being a lifting body. That's what I had intended when I came up with my design. Though to be certain, I don't know sucessful I was with that as I was only working intuitively in an attempt to offset energy losses that would otherwise be unproductive drag.You just described my experience with the Sea-Era () except I sit on the delta wing and lean back against the fuselage. The configuration is considerably different but the construction is very similar to what you describe. Sea Era wings disconnect and stow on the delta for trailer transport.
Paul has a lot of good ideas and did all the model testing VB suggests. He has several follow on design variations he would like to see someone develop and build.
Your configuration is interesting and useful. I know of one low span design study that would allow road transport without folding wings.
