LS3 - Supercharged
Discussion in 'Chevy' started by TXFlyGuy, Dec 6, 2017.
  1. Dec 6, 2017 #1
    TXFlyGuy
    TXFlyGuy
    TXFlyGuy
    Apr 26, 2012
    1,551
    456
    Republic of Texas
    For those needing (wanting) more power, GM Performance Parts offers the LS3 (LSA) in a supercharged package.
    450 hp @ 4250 rpm.
    500 hp @ 4800 rpm.
    That should be enough.
  2. Dec 6, 2017 #2
    Voidhawk9
    Voidhawk9
    Voidhawk9
    Mar 26, 2012
    267
    151
    Timaru, NZ
    More interesting, IMHO, would be turbo-normalization.
    Those numbers are not much higher than the LS376/480, which lacks the weight and complexity of the supercharger.
  3. Dec 8, 2017 #3
    TXFlyGuy
    TXFlyGuy
    TXFlyGuy
    Apr 26, 2012
    1,551
    456
    Republic of Texas
    Turbo would not be an option with the exhaust setup. Yes, our LS376/480 did 430 hp @ 4500 rpm.
    A supercharger would be nice cruising at FL180.
    As we like to cruise in the teens, an O2 tank is being added, plus a cockpit heater!
  4. Dec 8, 2017 #4
    jac
    jac
    jac
    May 18, 2013
    74
    9
    Gore, Southland New Zealand
    Supercharger should remove any concerns you have/had about short exhaust stacks as well.
  5. Dec 8, 2017 #5
    11,933
    3,417
    You just need two blower speeds like the real thing.
  6. Dec 8, 2017 #6
    TXFlyGuy
    TXFlyGuy
    TXFlyGuy
    Apr 26, 2012
    1,551
    456
    Republic of Texas
    At FL210, they run in low blower, burning 1 gallon per minute. At FL240 and above, they go into high blower. This will consume about 2 gallons per minute.
    As it turns out, the LS3 Supercharged GM Performance Motor is too heavy, by about 100 pounds.
  7. Dec 8, 2017 #7
    11,933
    3,417
    Yea but go the extra 10,000 ft and reap the true airspeed or pull it back and go for range. RVSM P-51. Wave at passengers.
    Voidhawk9 likes this.
  8. Dec 8, 2017 #8
    Voidhawk9
    Voidhawk9
    Voidhawk9
    Mar 26, 2012
    267
    151
    Timaru, NZ
    Ah, I forgot to consider it in your setup. If I arrange my rads right, I will have room to 'upgrade' later to a twin-turbo setup, should I have the budget and madness to do so. :whistle:
    Are you using automotive-style heating? I'm planning to use a heat exchanger fed off the radiator inlet plenum, P-51 style. Varying the flow through the heat exchanger will vary the heat. Should have decent pressure to flow plenty of air, too.
    This just made my day. :gig:
  9. Aug 9, 2018 #9
    dsigned
    dsigned
    dsigned
    Aug 8, 2018
    87
    11
    Illinois as of 08/12/2018
    I wonder if a centrifugal blower would be lighter?
  10. Aug 9, 2018 #10
    7,235
    2,069
    A suitable manifold is a standard part of a turbo conversion. The Supercharged LS3 may need no internal mods for a turbo conversion.
