Lower budget engine options for a low budget UL
Armilite
Sep 5, 2011
3,674
AMES, IA USA
Rotax 912 A/F/UL From Rotax operators manual
Max rpm = 5800
75% power = 86% rpm (5000)
55% power = 74% rpm (4300)
Use your tach and published engine data to set 75% power.View attachment 102884
Dude, for these Honda/Clones there is No published Data! A few months ago you was against turning them 5000-5500rpm when I suggested it, now you say use Published data from a different Type of Engine that says 5800rpm. You're comparing a 460cc Single Engine to a Certified 1211.6cc Engine.
There MAX Continuous Rating hasn't been established. So No, we can't use the 912 or your VW Engine Data, you have to use the Engine in Question.
n3puppy
Jun 25, 2019
286
A Small V Twin making just 50hp at 5000rpm could turn a 46" x 16 Direct Drive.
Some people can use published data to develop general guidelines.
Some people use online calculators for specific data.
Previous suggestion was that a [email protected] industrial engine could swing a 46x16 direct drive prop
Per often quoted online calculator for a 46x16 prop
100% power = 50hp = 5000 rpm
75% power = 37.5 hp = 4543 rpm
4543 rpm = 91% rpm NOT 75% rpm
Prop load on any engine will follow similar patterns
It is about how props work - NOT engines
Any engine build for aircraft use should keep these parameters in mind
Cruise HP - 75% Takeoff rating (heat load )
Cruise RPM - 90% take off rating (mechanical reliability)
simflyer
Sep 24, 2015
238
Moravia
View attachment 102904View attachment 102905
RPM over 4500 are too high and time of small V-Twins - reasonable power is up to 40hp, without higher compression. Bigblocks are heavy.
Armilite
Sep 5, 2011
3,674
AMES, IA USA
Until a Continuous [email protected] rating is figured out for these Engines, you're just throwing Numbers at a wall.
For Part 103:
At [email protected]:
46" x 16 (CF.822), 2 Blade 5000rpm 77F
246.70 lbs req 50.008 hp
Est Speed (75.7 mph).
At 75% hp: 50 x 75% = 37.5hp
46" x 16 (CF.822), 2 Blade 4543rpm 77F
203.66 lbs req 37.511 hp
Est Speed (68.8 mph).
At 75% rpm: 5000rpm x 75% = 3750rpm
46" x 16 (CF.822), 2 Blade 3750rpm 77F
138.77 lbs req 21.097 hp
Est Speed (56.8 mph).
At 84% rpm: 5000rpm x 84% = 4200rpm
46" x 16 (CF.822), 2 Blade 4200rpm 77F
174.07 lbs req 29.640 hp
Est Speed (63.6 mph). Part 103 Max Speed 63.3mph
50hp x 12.4cc = 620cc Van Guard 627 V Twin.
45hp x 12.4cc = 558cc
40hp x 12.4cc = 496cc 500 Clone
35hp x 12.4cc = 434cc 440 Clone
30hp x 12.4cc = 372cc GX390
28hp x 12.4cc = 347.2cc
26hp x 12.4cc = 322.4cc
GX270 (77mm x 58mm) 270.1cc / 12.4 = 21.8hp. The GX270 with 1 in PTO Shaft is the Smallest useful Engine if Big Bored.
BB (87mm x 58mm) 344.9cc / 12.4 = 27.8hp
BB (85mm x 58mm) 329.2cc / 12.4 = 26.5hp
BB (83mm x 58mm) 313.9cc / 12.4 = 25.3hp Rotax 277UL Dynoed 25.4hp.
BB (81mm x 58mm) 298.9cc / 12.4 = 24.1hp
n3puppy
Jun 25, 2019
286
Like I said, take off at 5000rpm 2-3 Min, then throttle back to 75% Power. 5000 x 75% = 3750rpm! You don't have a hp Gauge, you have a Tach! 5000 x 80% = 4000rpm, 5000 x 85% = 4250rpm. 5000 x 90% = 4500rpm.
You are right - until these engines are actually tested with a prop or wood bar dyno - we are simply developing general guidelines based on typical aircraft parameters.
Likewise, without testing, saying every industrial 4 stroke engine ever built can reliably produce 1hp /12.4 cc in aircraft use is just throwing numbers at the wall.
But I am glad you finally agree -
75% power does not equal 75% rpm
In fact, as shown on multiple charts and calculator
75% RPM = approximately 45% power
Per your numbers
5000 rpm = 50hp. ...100% power = 100% rpm
4543 rpm = 37.5 hp. ...75% power = 91% RPM
4200 rpm = 29.6hp. ...59% power = 84% RRM
3750 rpm = 21.1 hp ...42% power = 75% RPM
8,812
Just found this on the Loncin site. They make v twins up to 803cc. If Briggs stops making engines, they are an avenue to explore. It's likely that this PTO is the same for similar size industrials. They also have a 1 3/8 straight shaft option.
