Low-powered, four-seat homebuilts?
Discussion in 'General Experimental Aviation Questions' started by cluttonfred, Nov 20, 2019.
  1. Dec 5, 2019 #61
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,111
    251
    AMES, IA USA
    My Bad default was set at 1000 lbs.
    Buyer’s Guide Search: 200HP 3-5 SEAT, 1500 LBS USEFUL LOAD. ONLY GIVES YOU 150HP / 200HP CHOICE.
    Found 52 Results: 1200+ LBS ARE MARKED. MAX 200HP, COULD BE LESS!
    Design Status Kit Price Cruise Speed Build Time Useful Load Compare
    AeroCanard FG $34,900 205 1400 950
    AeroCanard RG $44,000 210 1700 850
    AeroCanard SB $29,500 200 1500 900
    AeroCanard SX $39,500 205 1400 950
    Aerocat TR $122,000 201 700 1350
    Aerocat TRX $140,000 185 700 1125
    AirCam (Gen 3) $143,780 75 1200 790
    BD-4B $ 190 1500 1250
    BD-4C $29,844 200 1100 1150
    Bearhawk (plans)$ 130 2000 1300
    Breezy R.L.U.-1 $ 80 1500 502
    BushCaddy L160 $24,500 115 1200 1152
    BushCaddy L162 Max $38,943 125 1200 1400
    BushCaddy L164 $33,000 125 1200 1300
    C.P. 1320-Saphire $ 167 3000 885
    C.P. 60 Super Diamant $ 155 3500 755
    Catalina $23,408 75 800 600
    Comp Air 3 $33,391 145 1500 1050
    Comp Air 4 $36,295 155 1000 1200
    Cozy Mark IV $ 185 2500 1000
    Defiant $ 1297
    Dyke Delta JD II $ 180 2500 870
    Four Winds 192 $48,000 200 1240
    FX 300 $
    H-1 Wolf/Wolf $124,900 210 2000 1000
    Harrier $ 100 800 565
    Jabiru J400 $46,900 138 600 820
    Jabiru J430 $46,900 138 600 740
    KIS TR-4 Cruiser $ 165 1200
    L 7 $ 125 4200 600
    Lafayette 4S Revolution $56,228 178 975 934
    Levitation 4 $40,000 120 2000 1132
    Magnum $26,990 130 750 800
    Pelican $19,900 86 1500 993
    Sea Storm Z4 $47,913 144 700 1122
    Sling 4 $36,310 138 1000 1012
    Sling TSi $53,297 167 1400 1014
    Sportsman 2+2 $23,000 124 2800 1120
    SQ-2000 $55,000 215 1200 1000
    STOL CH 801 $24,990 105 750 1050
    STOL CH 801-HD $29,890 105 750 900
    Storm 400 $28,822 170 507 800
    Storm 500 $30,093 172 507 1023
    Supercruiser $47,000 115 1200 1200
    Tundra $50,766 118 1000 1075
    Velocity Elite RG $51,450 210 1700 1000
    Velocity SE-FG $33,000 184 1600 1000
    Velocity SE-RG $42,000 200 1800 1000
    Velocity SUV $49,250 175 1500 1015
    Velocity V-Twin $110,000 207 1200 1200
    Wichawk $ 127 2000 720
    Zodiac CH 640 $38,990 150 1250 1053
  2. Dec 5, 2019 #62
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,111
    251
    AMES, IA USA
    Buyer’s Guide Search 150 HP 3-5 SEAT, 1300 LBS USEFUL LOAD.
    Found 15 Results:
    FX 300 $
  3. Dec 5, 2019 #63
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,111
    251
    AMES, IA USA
    These BUSH CADDY's L160 - L164 look hard to beat! L-164 has the Highest Useful Load.
    L-160 MTOW 2250 lbs = 1020.6 kg / 10 kg = 102.1 kw = 136.9 hp. They say 125 hp to 180 hp.
    L-164 MTOW 2650 lbs = 1202.0 kg / 10 kg = 122.2 kw = 163.9 hp. They say 160 hp to 250 hp.
    BUSH CADDY L160 - 1.jpg BUSH CADDY L160 - 2.jpg BUSH CADDY L164 - 1.jpg BUSH CADDY L164 - 2.jpg
  4. Dec 5, 2019 #64
    pfarber
    pfarber
    pfarber
    Feb 21, 2019
    395
    26
    Pennsylvania
    BD-4C is the answer you are looking for.
    Make sure you get the C varient
    [​IMG]
    BJC likes this.
