I would not be me if i did not try to place a pilot on his belly in a low aspect ratio. I just took my latest wingshape and tried to see how a pilot would fit in. I have to admit ... he fits in nicely! only needs a small canopy. I could make him fit in ever completely but he would then have to be totally flat in wing. And i want to give him some better comfort.
Major disadvantage now is that the engine which i always put in front of the wing in the previous proposals is right in the way of his view. I could place the engine higher, but that would create a pitch down moment which the elevons might not compensate due to short moment arm.
At this moment i just draw it without engine or prop. And than it hit me. ****, would it not be great to make it electric and put a few engines on the trailing edge like in the BWB-designs of NASA. Or maybe a few engines along the leading edge. If placed at trailing edge, CG could be be corrected by placing batteries in front of CG. I admit ...it would create a very spread out weight. I would prefer engines at front. Maybe something like in Cri-Cri but then electric.
Would it be possible to create it as a glider with starter help? Or ... would it be possible to create it as hangglider whatso ever??? Yep, i drew one with his legs out like in the Horten HXa glider. If glide ratio would be good enough ... why not???
Largest change in my proposal is the use of more conventional elevons instead of my split V-tail. Reason for this change: if i would really consider it as a hangglider, it needs to be very light. The need for extra reinforcements in the wing to keep the wingtips rigid enough to handle the split V-tail would add a lot of weight.
Enough talk ... here are the drafts.
In the last draft there are two lines. One is the horizontal line parallel to the main line of the root airfoil. The other is at 15 degrees of that line and shows that the legs would be possible to use when landing at 15 degrees.
