challenger_II
That is the general idea of my suggestion.
Share it here. It seems to be totally on topic. Here are my most recent drafts. One edition with central wheels and another with more know trigear.I have been working for a while on a design that is very close to the goals of this thread (trailerable LAR LSA) but just slightly outside the OP’s goals (7’6” width folded, 2.1 AR.)
I made the decision to go with a fuselage pod below the wing in order to make ingress/egress easier, make the landing gear simpler and stronger, and to provide better visibility for training purposes. The recent turn in the conversation made me think it might be appropriate here.
I don’t want to hijack the thread if this is too far afield. Would there be interest in my posting the three-view here?
Opinion (general): Any hoped-for visibility at low grazing angles through glazing may prove quite disappointing, especially if it is impractical to put dark, matte material in the illuminated part of the nearby interior. Also, pilot sightlines should include the need to put instruments in a convenient spot.
If you are refering that the angle between line of vision and plane of window needs to be not shallow (for example values larger than 30 degrees) i understand your point of view. The chance to glare in the glazing gets bigger at shallow angles.Opinion (general): Any hoped-for visibility at low grazing angles through glazing may prove quite disappointing, especially if it is impractical to put dark, matte material in the illuminated part of the nearby interior. Also, pilot sightlines should include the need to put instruments in a convenient spot.
... Placement of instruments is best in neighborhood of normal line of sight while flying, but i have seen a lot of weird locations of instruments. As long as you can be happy yourself it is ok for me.
I guess soon you will post "I TOLD YOU"The design seems like it will have poor yaw control, immediate control of yaw without an immediate roll response is necessary for takeoff when only the nosewheel is in contact with the ground - the ”winglets” will probably be ok when you are clear of the ground but Nostradamus can see a problem.
Looks like you have been working on this idea for some time. Impressive. Looks like ideal for reconnaissance (spelling??).Here is the podded LSA I've been working on. Side doors and side stick for easy access. Rear seat elevated 6" above the front for forward visibility for both pilots. Solo from the front. Gear sized for 10fps decent rate. Sized for 80-120HP motors.
Well, if you do use the "Cri-Cri" canopy, it could look very slick (all transparent) and the yaw stability may be OK, with your winglet/rudder at about the same distance back as the "Cri-Cri" (and you have 2)By the way ... here is my first attempt to have the pod only at the upperside. I admit ... it is not a beauty.
View might be better. Looks are less.
