nestofdragons
Had some time to test a idea. I was a bit worried about my 14% thick wing. Especially about the elements of the spar that needed to pass under and over the pilots legs. And i wanted to give the pilot enough room for his feet. Not all pilots have small feet like me (eur: 42, usa: 9).
So i went back to thinking about thicker airfoil. But this time only for the center section. Later i will test with a even smaller section at higher thickess (half of center section).
Here are the pictures.
Thickness center section goes from 14 to 22 in center. Front glazing not done yet.
More internal space to make retracting front wheel possible. Pilot still can see sideways over wing.
The canopy is a lot smaller that pure 14% thickness wing of course. I still like the looks of the fatter wing.
In this picture you can see where i am currently planning to place spars. There are three lines visible. Just forget the most rearwards line. Those two first lines are supposed to be spars. I will connect them in such a way they will become a very rigid structure. Front leading edge D-tube will be not as strong as possible due to the glazing in the leading edge. This spar-structure should help to keep it all very rigid.
The picture above gives a bit of a idea how much of the leading edge needs to be transparent for good view on the airfield while landing.
This picture gives a idea of the transit from 14 to 22% thickness.
