When laying the sheets of fabric on the wing, are the edges of the sheets overlapped, or are they butted together?
If overlapped, by how much?
Thanks,
JC
Thanks,
JC
You beat me to it!From pg. 19-6 of the plans:
"...(the lower wing skin is) two plies of unidirectional UND, each joint is butted not overlapped."
Not overlapped due to the obvious re: layup callout.
From pg. 19-7 of the plans:
" STEP 8 - Top Skin. Follow the instructions in step six with the following exceptions: Before..."
"...(the upper skin) has a third unidirectional, installed before the top BID reinforcement. This third UND ply extends from..."
In general, UND has very little strength or contribution to stiffness in layups across the long axis of the fabric (<5% of along-axis). I don't recall figuring in any contribution from cross-axis fibers on UND prepreg, but that work was circa 1989, so I hope that someone with more recent/deeper wet layup design methodology use can weigh in.
Should have mentioned that... not sure if anyone has bitten off making the plans searchable, but it's pretty easy to check TOC and enjoy the late '70's vibe while browsing for the layup info. Also note that the Moldless Composite Sandwich Aircraft Construction general text on stuff like BID versus UND use, etc. is also covered in Section 1, Chapter 3 of the LongEZ plans.OT but I will put in a pitch for the free Open-EZ plans and builder's manual available in the "Open-ez" topic at www.canardzone.com
The top layers are the same as the bottom except for a third layer that goes on at zero degrees the length of the wing, but not over the aileron cut out area and the length of the wing. I think this was to make it easier to balance the ailerons. The plans call for a 3/8" dia. steel rod in the Friese nose of the ailerons for balance. Lots of builders (including me) use a 7/16" dia. one to make balancing easier.Good build thread. Right wing - bottom skin layup
Well, the aero can be as good, but it will require a minimum of about 3 more pounds of filler And more skill to avoid having wings with facets.I'm pretty sure that Rutan used UND in the wing skins specifically to avoid overlaps, that one would have to make if using BID. That would ruin aerodynamics.
Rob
