Loctite and acrrylic (bad)
Discussion in 'Workshop Tips and Secrets / Tools' started by FritzW, Nov 4, 2018.
  1. Nov 4, 2018 #21
    6,637
    2,525
    FritzW likes this.
  2. Nov 4, 2018 #22
    6,637
    2,525
    One only is used on an old Ford engine? :gig:
  3. Nov 4, 2018 #23
    Super Moderator Staff Member
    Oct 19, 2003
    6,158
    3,463
    Which materials you are dealing with dictate which other materials you can use.
    LocTite (cyanoacrilate) and many other solvents do terrible things to polycarbonate (Lexan is polycarbonate). I suspect that your cracked part is polycarbonate based upon the looks of the cracks with many branched cracks. I also suspect that the part that did not crack is PMMA. Check out the materials carefully before applying chemicals.
    Silicone sealers work great on PMMA if it is unstressed, and is standard process in certified airplane windows and windshields. If PMMA is highly stressed, silicone sealers can cause cracking during cure.
    Prevailing torque fasteners are your friend...
    Bill
  4. Nov 4, 2018 #24
    wanttobuild
    wanttobuild
    wanttobuild
    Jun 13, 2015
    649
    73
    kuttawa, ky
    This post contains inappropriate language and is a example that the OP vowed to clean up.
    This is also an example of biased moderator behavior here on HBA.
  5. Nov 4, 2018 #25
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    3,098
    2,136
    BDU, BJC
    Assuming these aren't supplied by a third party on this particular plane...
    The canopy that cracked is acrylic: https://www.sonexaircraft.com/eshop/cart.php?target=product&product_id=16457&category_id=297
    The windshield is polycarbonate: https://www.sonexaircraft.com/eshop/cart.php?target=product&product_id=16458&category_id=297
  6. Nov 4, 2018 #26
    Angusnofangus
    Angusnofangus
    Angusnofangus
    Sep 29, 2015
    336
    145
    Victoria, Canada
    Don't beat yourself up to bad about this. At the company I recently retired from, an OEM aircraft manufacturer, I was given a modification to do that involved Locktite, acrylic, and screw holes. I performed the mod as per the drawings by the company engineers, and guess what? The Locktite caused the acrylic to crack around the screw holes. We live and learn.
    Himat and FritzW like this.
  7. Nov 4, 2018 #27
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,749
    2,825
    Calgary, Alberta, Canada
    There are 2 types of silicones- acedic and "neutral". The latter emits alcohol or ketones when curing. Different possible reactions with certain metals and other materials. I'd also mention that Pro-seal should not be used on acrylics but I saw the Raptor guys gluing their transparencies on with it- on a pressurized aircraft no less.
    BTW, in the old days, flat head or countersunk screws were used on thousands of RV canopies and work just fine if you follow the factory recommendations. 15 years later, mine is still mint. We use nylocs to keep the screws from falling out.
    MadRocketScientist likes this.
  8. Nov 4, 2018 #28
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    The windshield and canopy were both supplied by Sonex, so will the new canopy. ...the more I think about it, the more I think I remember a warning about using Loctite. Oh well, it's too late now (as I pound my head against the wall)
    20181103_105015_resized_1.jpg 20181103_105112_resized.jpg I've seen the 'feather' looking fractures before but I've never seen them turn black.
  9. Nov 4, 2018 #29
    6,637
    2,525
    After a bit of looking it appears that Loctight also sells what they cal Dri-loc. It's the pre-applied thread locker that is common on the tips of OEM replacement bolts. I can find MSDS and product sheets, but no price listed. Is this something that HBA&DIY can do/afford?
  10. Nov 4, 2018 #30
    12,656
    2,586
    It is probably a combination of chemical and strain . A drop of chemical might dry with no effect if not under pressure.
  11. Nov 4, 2018 #31
    Daleandee
    Daleandee
    Daleandee
    Sep 11, 2015
    922
    580
    SC
    As understand it ... you are correct.
    Dale
    N319WF
  12. Nov 4, 2018 #32
    Sep 18, 2008
    5,020
    2,188
    The Loctite might have caused some of it, but I agree that overtightening countersunk hardware is going to crack acrylic. It will even crack Lexan; I learned that the hard way. When you use too much pressure, or countersunk stuff that won't allow any movement at all, you're going to get cracking due to thermal stresses. When I replaced my Jodel's Lexan windshield I drilled the holes versize and used nylon washers under the screw heads so that the thing could expand and contract at will. It didn't crack any more, but then I made a new canopy cover out of nice new vinyl, and new vinyl still has solvents in it that attack Lexan and cause crazing. The crazing (very fine cracks) occurred along the bend in the windshield where the stresses put tensile loading on the outside. This was in a hot climate, and that probably figured into the outgassing issue as well. The old cover had been made of a silvered nylon that kept the sun and moisture off but still breathed. Couldn't find any more of that stuff. Vinyl, being impermeable, will trap the gases against the windshield.
  13. Nov 4, 2018 #33
    Sep 18, 2008
    5,020
    2,188
    I have used both acidic silicone and PRC on acrylic, with no adverse reactions. The aluminum structure around a windshield doesn't care for the acid, though. It can suffer corrosion pitting. Avionics guys often won't use it to seal antennae bases for that reason.
  14. Nov 4, 2018 #34
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    The screws were tightened correctly. Just enough so the washer wouldn't easily spin by hand. ie. just enough to keep the canopy from rattling on the screw.
    The screws weren't over tightened.
    The screws were torqued correctly.
    The screws weren't over torqued.
    The amount of tightness on the screws was appropriate for the application and materials.
    (just getting a few responses typed out so I can save time with a 'cut and paste' every time someone says the screws were over tightened)
    ...did I mention that the screws weren't over tightened.
    Angusnofangus likes this.
  15. Nov 4, 2018 #35
    7,349
    2,117
    Fritz, you didn't by any chance, overtighten the screws, did you? ;)
    Edit, Sorry, just realised that 3 pages into this thread, I have only waffled about solvent stress cracking and that cyano is known for it with acrylic I have missed the obvious, unlike most others...
    FritzW likes this.
  16. Nov 4, 2018 #36
    narfi
    narfi
    narfi
    Feb 23, 2016
    788
    397
    Alaska
    I wish I could say that everytime I screwed something up.....
    Himat, FritzW and pictsidhe like this.
  17. Nov 5, 2018 #37
    Himat
    Himat
    Himat
    May 5, 2011
    2,858
    668
    Norway
    Quite probably yes.
    I can’t find the reference but the police in at least one European country found out this the hard way. Their riot control shields were made from some clear plastic, acrylic I think. Excellent strong and impact resistant shields until the rioters did throw butyric acid or something on the police. At next impact the shields shattered!
    ScaleBirdsScott likes this.
  18. Nov 5, 2018 #38
    6,637
    2,525
    This thread got me searching for some Loctite Dri-loc. The idea of self applied 'dry' type thread lock seemed like an idea that needed some followup. Seems Loctite isn't interested in sales below the tanker level of this stuff. At least the impression the few sites I found left. I don't like the price on request method of doing business..........
    I did find a similar product that one can actually buy: Vibra-tite VC-3
    https://www.google.com/url?sa=t&rct...ll_sheet.pdf&usg=AOvVaw3UhaKkfSFryLK7VdGze7JV
    https://www.google.com/url?sa=t&rct.../213_tds.pdf&usg=AOvVaw10eW9cIcUArwIWpSe4wo4y
    Never used this but it looks promising for some applications. Anyone have any real world experience they care to share?
  19. Nov 5, 2018 #39
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    ...well ...this is embarrassing ...right on the canopy page, in bold letters
    20181105_112505_resized.jpg I probably read that note a dozen times :emb:
    Norman likes this.
  20. Nov 5, 2018 #40
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,561
    536
    I think I've used that stuff on one or two jobs. Can't remember any problems, but then I don't know if we would have run into problems anyway. It's been a long time, so the memories are vague. Since then I've also used nylon insert locking stuff and also square cone washers. All seemed to work, but I still don't know if proper torquing wouldn't have been enough in the first place. I suspect that's not the case with the acrylic canopy if subjected to large temperature range, but I don't know.
