We're shooting to have things ready for a flight around this weekend. After a number of engine runs and taxiing all over the airport, we've been seeing some vibrations we want to deal with. Last week been ticking off the boxes. Re-checked the prop and dialed the blades in a little to get angles down within 0.1 degrees, they were previously set with a bubble level and were within about 0.5 degrees. Also modified our port side exhaust hangers a bit to better control some of the range of motion on the exit tube. And then over the weekend we've borrowed a dynavibe to work on getting accurate numbers so we can quantify the changes we're making. At this point we're down to trying the method of adding some weights to the prop hub under where the spinner cover will go. To look right, we don't have a big spinner, so we are really limited, the weight needed will be fairly substantial compared to those who can put a few bolts on their flywheel.
I'm not expecting to get us diamond glass smooth, especially right off the bat, but based on the experiences of some other Verner users, we should be able to get it pretty decent from here.
We shall see!
