[QUOTE="pantdino, post: 575696, member: 96632"\
1) The LS3 engine makes 350 ft-lb torque at 2000 rpm and 430 at 4500. So while Titan's suggested cure for the excess power issue is to never exceed 3600 rpm, it seems to me that if torque needs to be limited to 263, then at
NO ENGINE SPEED IS IT SAFE TO USE WOT.[/QUOTE]
Let's be really clear on something. That torque and power curve you see, represents the engine output at exactly one air pressure, humidity, and temperature. By far, the most important is ambient air pressure. Usually the torque and thus power curve are corrected and published to 29.92 In Hg, 59 F, 50% humidity. Even if your dyno was in sight of the beach at Kitty Hawk NC, your engine would be a few feet above Mean Sea Level. We lose roughly 1" of manifold pressure for every 1000' altitude.
If the engine breathed exactly the same at all rpm, the torque curve would be absolutely flat. It is not flat because as rpm goes up, several things get worse:
- Friction losses from moving the engine internals get increase at the square of speed;
- Friction losses from moving air in the manifolds and past the valves increase at the square of speed;
- Inertia effects of the air (lag in response) in the manifolds increase.
We can not do much about the first two, but we can adjust valve timing, play with manifold runner lengths, etc to tune the system for fat torque curves and set the peak torque where we want it. Yeah, peak torque is most likely at the place where the breathing is closest to perfect.
The really big thing going on is that the air pressure in the manifold largely determines how much fresh air in the combustion chamber for each firing, and that largely sets power, yeah, just how the breathing is set up influences this some too, but usually having lower manifold pressure for whatever reason scales down the torque curve, with more loss at higher rpm than at low.
With a given engine, engine torque primarily changes with manifold pressure. As a first order approximation, if you were running 4500 rpm, you could expect 263 lb-ft at 29.92*263/450 = 18.3 in Hg. You can get this manifold pressure down low by closing the throttle, or when you get above 12000 feet. If you tried to climb with a fixed throttle position, that held 18.3" at sea level, and held that throttle position to 12,000 feet, you would have about 10.7" Hg manifold pressure when you got there and only about 160 lb-ft of torque. The throttle valve takes whatever ambient pressure is and reduces by some fraction based upon the opening of the valve.
So if you set the governor to hold 4500 rpm, and your airport is at sea level, and then you set throttle to make 18.3", and commence climb, you could hold 263 lb-ft by nudging the throttle to keep the intake manifold at 18.3" as you climb. And you will be somewhere near 225 HP the whole time.
2) Since it takes more torque to produce the same hp at lower rpm than a higher one, this would seem to reinforce my perception that the gearbox will be less stressed if you spin the engine and gearbox faster at a lower throttle setting than slower at a higher throttle setting.
Do you have a guess what MP pressure an engine will be making only the amount of torque we can feed into it?
Does feeding 15" to an engine equate to "half throttle", and therefore half the output? I suspect the relationship is more complex than that.
Sort of... Yes, you could make 225 HP by running 263 lb-ft and 4500 rpm (and 18.3" Hg) or you could make the same 225 HP at 5252 rpm and 225 lb-ft and most likely a little more manifold pressure at that rpm.
For a first order approximation, you could look at WOT sea level torque at any particular rpm and scale torques to figure the fraction 29.92 in Hg you would need there...
Scaling is a pretty rough estimator, which is why I suggested a run or three, measuring torque, rpm, manifold pressures, and running up to some torque (263 lb-ft might be a good place to limit things) and find your limiting manifold pressure for each rpm you are flying. Each Eiffel Club size has its own torque vs rpm curve, so you can run each club over a range of manifold pressures, recording rpm at each setting, and get a pretty good idea of what your engine is doing...
The reason for all this annoying testing is that your intake and exhaust system is not the same as the one used on Chevrolet's dynos. So even if you could get a bunch of engine torque/ engine rpm/manifold pressure dyno operation points from Chevrolet, you would be guessing. Many folks running a V-8 in a Mustang look alike have short pipes, just like the Merlins and Allisons did, and they cost you some power. Hmm. Since you are ready to fly, perhaps you could instrument the engine mount to give you prop torque in real time, and divide by your PSRU gear ratio. Then you could very directly set throttle based upon prop torque.
I have reinstalled the governor on the new gearbox, and there are no visible fines in the oil after a couple of ground runs followed by oil changes before installing the governor. The minimal pitch adjustment has been made to provide 16.5" MAP at 2000 rpm, the idea being that if the governor fails you still have enough thrust to get home.
I hope that you have a flyable prop pitch there - you definitely want to fly at that power setting and establish your airpseed and sink rates, and find what range of airspeeds you can hold altitude. You may not be able to get home, but instead be able to pick where you will set it down. Having a glide cone 20 miles in radius is 16 times as much ground area for a landing than a glide cone that is only 5 miles in radius.
Being as you are not going to put in a dedicated inline oil filter for oil going to the governor, I suggest that you consider the partial flow filtering scheme we had mentioned. This will not prevent silting the hub and/or control valves nor prevent contaminating the bearings and gears, but it will reduce the rate at which these things happen, with the intent of giving you more time to catch the problem and fix it before having a major inflight issue.
Good luck.
