lightweight batteries
Discussion in 'Instruments / Avionics / Electrical System' started by battman, Oct 18, 2010.
  1. Oct 18, 2010 #1
    battman
    battman
    battman
    Sep 12, 2010
    11
    0
    tallahassee fl
    I am curious what battery size people are using, and the weight of such.
    Reason; would a battery weighing 1 1/2 to 3 lbs. be of interest ???
    I am looking for testers on different aircraft - especially rotorcraft- to show reliability and improved performance.
    ( deposit refundable when returned )
    Andy
    lithiumMoto
      File size:
      74.3 KB
      319
  2. Oct 18, 2010 #2
    11,727
    3,321
    How many amps does it have? The iron lithium batteries are pretty cool compared to the burn hazard of LiPo. Does the battery come with a balance charger?
  3. Oct 18, 2010 #3
    battman
    battman
    battman
    Sep 12, 2010
    11
    0
    tallahassee fl
    amps are variable depending on what your starter needs
    no charger needed
  4. Oct 19, 2010 #4
    Robby
    Robby
    Robby
    Apr 8, 2010
    123
    3
    Texas
    'amps are variable depending on what your starter needs' ??!!??
    Of course they are, but that's like saying the circuit only pulls what it needs !!!
    I can put 8 D-cells together and get 12V but it sure won't spin a starter because there isn't enough amps !!
    Are you saying the amps are variable depending on the size of the battery used ??
    If so, fine, but what is the max amperage output of the various
    batteries ?
    If there is only the one size, then what is its max amperage
    output ??
  5. Oct 19, 2010 #5
    battman
    battman
    battman
    Sep 12, 2010
    11
    0
    tallahassee fl
    I can put together a 200A, 300A, 400A, 500A, etc.... pack
    unless u want the xtra capacity beyond what the starter requires....
    It's a choice u have.
  6. Oct 19, 2010 #6
    Robby
    Robby
    Robby
    Apr 8, 2010
    123
    3
    Texas
    Ah, that's better - Thank You
  7. Oct 22, 2010 #7
    millerperf
    millerperf
    millerperf
    Oct 8, 2010
    19
    0
    st cloud florida
    whats the price warranty!12v 24v ?will it recharge with alternator?will it start my turbine allision t63-720 or is it just go for small engine i might try one on my new 150fi yamaha engine thanks mark
  8. Apr 21, 2011 #8
    battman
    battman
    battman
    Sep 12, 2010
    11
    0
    tallahassee fl
  9. Mar 19, 2017 #9
    Daleandee
    Daleandee
    Daleandee
    Sep 11, 2015
    902
    564
    SC
  10. Mar 20, 2017 #10
    6,446
    2,287
    Any idea exactly what technology those Aerovoltz batteries use? I checked their site but could not find anything more specific than "lithium." My understanding is that the newer technology lithium iron phosphate (LiFePO 4) batteries are much less likely to have this sort of runaway reaction.
    Xanadrone likes this.
  11. Mar 20, 2017 #11
    Xanadrone
    Xanadrone
    Xanadrone
    Nov 24, 2011
    195
    43
    Bucharest Romania
    Yes, the latest LiFePo4 technology already allows a good "energetic density" at more abordable prices than the Li-Ion ones and without the risk of firecrackers - ex:
    https://www.ev-power.eu/LiFePO4-special-cells/Lithium-Iron-LiFePO4-Battery-Cell-LFP-3-2V-72AH.html
    That means 0,230 kWh for 1.75 kg weight and 90 USD (without taxes) - say 4 lbs per unit including connectors.
    Practically speaking, for an [ultra]light E-experimental plane, a pack of 15 would assure 3,5 kWh at 48V (13S for RC-freaks ;) ) and a max. discharge rate of 360 amps (5C), weighting 27 kgs (60 lbs) and for "just" about 1.5K USD.
    Two such packs (7 kWh, 54kgs/120lbs) methinks would be just fine for a small one place E-bimotor to fly one hour at 50-60% power - and even double for a glider-style aircraft with good L/D.
    An unlimited number of other combinations would certainly be possible for those unhappy with just 14-15 kW onboard (18-20 HP), such as the use of only one pack for take-off E-power boost and/or emergency use, along with a small IC engine for the level flight. Or other hybrid/small generator solutions etc. etc.
    Btw, the favourable evolution of battery tech seems to be accelerating, and this made me not only sketch, but also calculate a few versions of some viable, simple and most of all affordable E-microlight. One without cross-country attributes for sure (for the time being at least), but perfect for cheapo leisure flights because the +2,000 recharge cycles of the new LiFePo4's would compensate rapidly the batteries cost.
    So, I'll be back soon with the final version (3-views + performance estimations) for your precious aid - meaning constructive criticism, with or without 437 posts about some wrong angle of the winglets - luckilly it doesn't have any. :gig:
    blane.c likes this.
