Light Weight VW
Discussion in 'Volkswagen' started by wanttobuild, Dec 29, 2016.
  1. Jan 23, 2017 #21
    7,380
    6,322
    All factory VW Type 1 blocks are magnesium. There are some after market aluminum Type 1 blocks that weights 17 pounds heavier.
  2. Jan 23, 2017 #22
    7,380
    6,322
    Sand blasting the cooling fins helps with the cooling by adding more surface area.
    bmcj likes this.
  3. Jan 23, 2017 #23
    7,380
    6,322
    A 32 hp 1/2 VW can be built down to about 87 lbs. Would that work for your application ?
  4. Jan 23, 2017 #24
    12,486
    2,524
    Yes. But that also takes a bunch of modification. I would rather have a smooth four cylinder of similar weight.
    The crankshaft Casler uses is heavily modified and welded. I figure welding a new crank from scratch might be as much work. Drilling the existing VW crank isn't possible because the pins overlap.
  5. Jan 23, 2017 #25
    7,380
    6,322
    You are correct. Building a cut case 1/2 VW engine is a lot of modification. I have built one. Cut the crank, welded the weights that I bought from Casler, etc. I would never built another, I would buy one built by Scott Casler and be happy. Considering all the machine work and time, Scott's engines are a good buy.
  6. Jan 23, 2017 #26
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,216
    1,438
    Marion, Ohio
    Would a surplus 4A032 work?
    From this web site:
    Keep in mind that the specs you will find on this are for the military. Mil Spec is 6hp, but it is 32 cu so you might get 12-15hp. Stock weight is 110 lb, but there is a lot of dead weight you could remove.
    Saturn Surplus has them for $749.95.
  7. Jan 23, 2017 #27
    litemite
    litemite
    litemite
    Dec 5, 2007
    27
    7
    Beloit, Wisconsin. USA
    About the full VW on the Hummel. Teds words to me was he had taken an angle grinder to he crank "to make it look more like an aircraft crank". He did say it was very time consuming. He is a retired "shop teacher" and lives in Arizona. I can well imagine that he had quite a time with density altitude in the Phoenix area, and that was his drive to move from the 1/2 VW to the full engine. I, myself, am building a WindWagon but using Hummel plans to do the mechanical mods that Morry did to make the HummelBird.
  8. Jan 23, 2017 #28
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    I got kind of excited the other day when these folks said the case they make is 18lbs lighter than an aluminum one. I'm not sure if it's as light as a magnesium one though.
    They've got some reasonably priced engine kits and long blocks in my opinion. They don't talk much about cam grinds but it seems they could fix a person up with just about any combo you wanted.
    http://www.scatvw.com/long-block-engine/
  9. Jan 23, 2017 #29
    11,916
    3,413
    Airplane cranks are hollow for constant speed props. They stopped making solid mostly to stop making two different cranks.
  10. Jan 23, 2017 #30
    7,380
    6,322
    That is a magnesium case engine. What you see in the picture in the ad will weigh 116 lbs. Very had to beat the stock cam in the type 1 VW engine when using a straight drive prop.
    They list 1.25 ratio rocker arms. Not good for a straight drive aero VW engine. It will cost you HP below 3000/3200 rpm. In building a straight drive VW engine, you are building for torque at prop speeds NOT an auto high rpm hotrod engine. They also list light weight cam lifter, also not needed in a VW Aero engine. Same for heavy valve springs.
  11. Jan 23, 2017 #31
    12,486
    2,524
    No. The 84 cu.in. would work but needs to be lighter also.
    I think the VW is more supported.
  12. Jan 23, 2017 #32
    12,486
    2,524
    I was referring to the 1" bored lightening holes in the main shaft and crank pins.
  13. Jan 23, 2017 #33
    11,916
    3,413
    Yep they stopped that too
  14. Jan 23, 2017 #34
    12,486
    2,524
    A solid crank is cheaper. But a larger tubular crank is much stronger for the same weight.
  15. Jan 24, 2017 #35
    7,380
    6,322
    This is a Teledyne engine in Kevin's Mini-Max. Kevin is an old friend of mine at a field about 50 miles south of me. He put over a thousand hours on that MM airframe with a 1/2 VW and then put the Teledyne engine on to see how it would fly the MM. Nice little engine. Love his oil cooler.
    https://www.youtube.com/watch?v=cj0hdymXfOg
    cheapracer and fly2kads like this.
  16. Jan 24, 2017 #36
    12,486
    2,524
    The climb angle was shallow, but not bad for 32cu.in. (525cc)
    Are you sure that was only 32 cu.in.? (Maybe 42?)
    My Honda V-twin is 40.8 cu.in. (670 c.c.)
  17. Jun 15, 2017 #37
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,111
    251
    AMES, IA USA
    I have weighed a 1200cc, 40 hp, a 1600 cc, and a 1835 and 1915 engine and they all weighted 116 lbs for the short block. Never going to remove 16 lbs so would have to develop more HP.
    2 pounds per hp could be done with a 2180 no-electric of 75 HP. Its just 2 lbs heaver than my 1835cc 60 HP. So I could change my 1835 to a 2180 and have a firewall forward weight of 143 lbs @ 75HP. Then that blows a hole in my 3 gph @ 80 mph cruise ( that is 26.6 mpg)
    But I don't want 75hp.
    I really just want 30hp in a low rpm smooth running four cylinder. A VW at 2100 rpm is really smooth. Much smoother than a A-65
    I think I can shoehorn a 100 pound VW into and ultralight. 100 pounds plus 154 pounds airframe = 254 pounds
    Quote
    I know this is an older post, but Why don't you just build a Half VW Big Bore using the Best Light Weight Racing Parts if you only need 30hp? Any Engine can be Balanced to run Smooth. If you use Ecotrons EFI or Meagsquirt EFI you can have a better Starting, Smoother running Engine with a better GPH. There was a 2 Cylinder VW Type Engine made in I think Brazil or Aregentia also. Maneesium Case's are lighter than Aluminium Case's. There are VW Engines & Parts 3D Modeled on the Web Free to download, you could take the Spec's off and make a Custom Billet Case that Bolts together.
    But a Rotax 2 Stroke, 277 or 377 built right with all the Engine Mods(Coatings and a Tuned Pipe) out today is still your Cheapest and Lightest Option for a Part 103 Ultralight. I just saw a Rotax 377 Single Ignition with Gear Drive for $800 on Craigslist in Texas the other day. A Rotax 277UL/377UL is the same as a Skidoo 277 & 377/380 made up to around 2008. Almost all Skidoo 2 Stroke Engines 93+ have Provision 8 Case's. Only the (277, 380F, 440F Till 2008), (503F Till 2003) were made into the 2000's.
  18. Jun 15, 2017 #38
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,111
    251
    AMES, IA USA
    They made a 4 Cylinder 084(45hp for plane use at a higher rpm than Stock, was rated 20hp at 10,000ft) an 042 4 Cylinder about half the HP so probably 21-22HP for plane use, an a 032 probably about 12-14hp, all of these Miliatry Genarator Engines are HP rated at 10,000ft. Only the 084 has ever been Dynoed that I know of making 45-46hp but at Higher than Stock rpms. The 084 is to heavy for 99.9% of the Part 103's out there. There 1000+hr Engines if you keep the rpms down for what they were designed for. Only the 084 has had many Mods done to it by a guy named Less Smute I think and he died a few years ago I think. If I remember correctly these engines had weak Rods & Rod Bolts if you try to push them to hard over the Stock rpms.
    Per the Peak Flow/HP Calc at 90%: http://www.mk5cortinaestate.co.uk/calculator3.php
    32ci at 3300rpms = 18hp
    42ci at 3300rpms = 24hp
    84ci at 3300rpms = 48hp
    32ci at 3600rpms = 20hp
    42ci at 3600rpms = 26hp
    84ci at 3600rpms = 53hp
    Per the Peak Flow/HP Calc at 100%: http://www.mk5cortinaestate.co.uk/calculator3.php
    32ci at 3300rpms = 20hp
    42ci at 3300rpms = 27hp
    84ci at 3300rpms = 53hp
    32ci at 3600rpms = 22hp
    42ci at 3600rpms = 29hp
    84ci at 3600rpms = 58hp
  19. Jun 15, 2017 #39
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,111
    251
    AMES, IA USA
    What specs would you change on this 1.2L Engine?
  20. Jun 15, 2017 #40
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    3,111
    251
    AMES, IA USA
    Some Stock VW CAM SPECS.
