I dont understand posters on this forum. All this yakking about a more reliable way to shut off the engine when in fact there are plenty of unresolved issues that have to be addressed before they will ever run.
Someone has to make a high voltage injector driver so that the injectors can be operated. Non trivial. What about the engine controller ? An engine controller for a gas engine will usually not have adequate time resolution for the injection system since this involved injection into the cylinder for a very short time period. Not like a port injector spraying against the intake valve before it opens.
The engines and parts for the engines are totally unsupported in the US. No access to OEM or aftermarket parts. I hope those attempting this have a pal in Germany or one of the other markets where parts can be obtained. You will find that the cost of courier fees has gone way up during the pandemic. A simple injection pump, for instance will cost between $200-400 just to cover courier fees from Europe to the US. I would not want to know what this means for importing complete engines, for example.
Many of the engines have been out of production long enough that one would be looking for a remanufactured engine because engines from the field would all have far too many miles on them and the remanufactured engine is usually bare. So needing intake and exhaust manifolds, turbo, complete fuel system and filters etc. Add starter, alternator, water pump and whatever else is needed. Less expensive than Continental and Lycoming but definitely not cheap...
Im not at all against diesels, I was living just 30 miles from Speyer when the smart engine was being developed as an airplane engine and I saw the smart diesel demonstrated there in 2003, but that was nearly 20 years ago. About the only diesels we have seen in the US were the VW based ones, many of them subject to the emissions cheating recall, thus gone forever. And as discussed, VW never deviated from the cast iron block for this market, despite having aluminum block engines in Europe.
