LEXLD94SE
Discussion in 'Member Project Logs' started by steveair2, Apr 28, 2016.
  1. Dec 17, 2017 #21
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today Jim made some good progress on the seat, then we finished welding the top of the cabin section.
    We glued some poster board together and started mocking up the windshield section.
    nzdavmo, Joe Fisher, Pilotjkl and 5 others like this.
  2. Feb 5, 2018 #22
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we installed the seat support structure. Jim found a nice little foot switch for our grinder. This grinder set up with the sanding disc is one of the best tools for coping tubing.
  3. Mar 12, 2018 #23
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Yesterday after our EAA Chapter 280 meeting we did some welding and tacked in the wing attach fittings.
    We also checked out some foam for seat cushions.
    nzdavmo, jmt1991, Joe Fisher and 2 others like this.
  4. Mar 19, 2018 #24
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Yesterday we cleaned and welded on the frame. Jim sprayed a little rattle can Rustoleum.
    nzdavmo, Joe Fisher, BJC and 3 others like this.
  5. Mar 25, 2018 #25
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we continued cleaning and welding.
  6. Apr 22, 2018 #26
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we started building our landing gear, lift strut attach fitting jig. We're making poster board patterns for our fittings.
    nzdavmo, Joe Fisher, Propman and 3 others like this.
  7. May 21, 2018 #27
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we worked on our poster board patterns and cut the first two fittings. We added a lengthened tab on the front fitting that after bending eliminated a fitting to frame gap.
    We've tested side by side the Milwaukee and Diablo 12" metal cutting blades in our recipricating saw. They both perform great and are equal in performance. The 12" blades make cutting very straight lines easy. We used a small triangular file to cut a notch in the metal before cutting easing the start of the cut. We still have a little adjusting to do on these before moving to the next set. It's worth the extra effort!
    We have also tried several types of commercial rust preventatives over the years. We now use cheap vegetable oil applied with a rag. The oil can be thinned and or cleaned off the tubing with acetone. It works great.
    nzdavmo, Joe Fisher, jmt1991 and 2 others like this.
  8. Jun 5, 2018 #28
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we cut drilled filed and fit, the remaining six landing gear fittings.
    nzdavmo, Joe Fisher, Marc W and 2 others like this.
  9. Jun 12, 2018 #29
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we continued bending, shaping and fitting the landing gear fittings.
    nzdavmo, Joe Fisher and mcrae0104 like this.
  10. Jun 18, 2018 #30
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    We had some nice cloud cover today keeping the shop cooler and we made some great progress. First we finished bending and fitting the fittings, then we filed all the edges smooth. Starting with a coarse file then using a medium file then finishing with a fine file. Then we polished them with emery cloth. We still have much work left to do on these fittings.
    This reply continues to reply 31
    nzdavmo and Joe Fisher like this.
  11. Jun 18, 2018 #31
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
  12. Jun 25, 2018 #32
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we removed our wooden landing gear fitting jig, and built a new one from one inch square steel tubing.
    We started building a drill guide to locate the bolt holes in the fittings.
    I decided to measure once and cut twice several times, and Jim tack welded the drill guide with the TIG welder.
    nzdavmo, FritzW, cdlwingnut and 3 others like this.
  13. Jul 2, 2018 #33
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    It was a delightful 104 degrees in Joshua Texas today. We continued working on our bolt hole locating fixture.
    I'm too exhausted to explain much about our drill guide. The pictures should show our process.
    In the next to last picture it is clear that something went wrong. We think our steel rod deformed at bit.
    Jim has some nice lawn art, a Dormoy Bathtub and an original design autogyro.
    nzdavmo, FritzW and Joe Fisher like this.
  14. Jul 9, 2018 #34
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    This morning, Jim cut out the crooked bushings and then put radius's on all our landing gear fittings. We then re jigged everything, and used 1/4" music wire to line up our new bushing in our drill guide.
  15. Oct 22, 2018 #35
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we were able to complete the welding of the cabin section, and then we cut fit and tacked in the seat back gussets.
    nzdavmo, FritzW, Joe Fisher and 3 others like this.
  16. Oct 29, 2018 #36
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we completed more welding and Jim modified our drill guide.
    nzdavmo, FritzW, cdlwingnut and 4 others like this.
  17. Nov 17, 2018 #37
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    We had great weather today and made some good progress. We changed the last single diagonal at the tail post to two diagonals. We're using a Harbor Freight propane torch to pre heat our clusters prior to welding, and are currently welding the tail section.
  18. Nov 25, 2018 #38
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we had more good weather with temperatures in the mid seventy's. We continued welding though the tail section. Using the propane torch to preheat the clusters works really well. The propane torch is also used after welding to cool the joint down slowly.
    nzdavmo, FritzW, mcrae0104 and 5 others like this.
  19. Dec 1, 2018 #39
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    Today we were lucky to have another warm day in the mid seventy's. Thinking that this might be the last warm day before winter, we decided to get as much welding done as possible. We welded for fourteen hours straight stopping once to eat pizza while standing. We finish welded the tail section and then tacked in the two diagonals at the fire wall.
  20. Dec 18, 2018 #40
    steveair2
    steveair2
    steveair2
    Jun 2, 2007
    975
    684
    Dallas Texas
    After our last welding session, Jim primed and painted the tail section. He also rough cut the engine mount gussets. Today we finished shaping the gussets and installed them into the firewall. Then we laid out and drilled the 1 1/8" holes and installed the engine mount bushings.
