HomeBuilt101
Another leak on my engine is the tip of the oil pressure regulator. It is not leaking from the base of the unit (the flange with the copper crush washer) but it is leaking from the very tip...as if the threade are leaking.
Is this something that others have experienced?
If so what is the recommended fix...new unit?
Is an aftermarket design available or is the LeakComing part the best choice?
THANKS!!!
THANKS!!!
