Lazair on Floats with Rotax 185's needs more power, Ideas?
7,548
I love air die grinders. But only at work, where they have a suitably enormous compressor to run anything I want. 1/4" die grinders need far more air than home size cmpressors kick out. Anyone who's ever tried that would know...
Being a cheapskate dabbler, I use small, cheap 1/4" electric routers with the base removed. Works just like a 'real' die grinder but doesn't need a zillion CFM compressor.
n3puppy
Jun 25, 2019
138
X2 on the air grinders if you have a big enough compressor
One of the nice things about the cable grinders I showed is they have interchangeable heads .
The 45 and 90 degree are really nice for shaping transfer ports. Working on small bores like the 185 the 45 degree is perfect for getting in the bore and putting a chamfered edge on the ports to avoid catching a ring edge.
Obviously the shop had pro versions. But I bought the $80 one pictured to use around the house for almost any grinding chore I used to use a Mototool for. E4149B67-068E-4B59-BC33-A14C0B698586.jpeg
4,565
They have always replied to me in the past
Well I asked non-standard questions.....like "can I run it direct without the reduction, or with the reduction would a wider blade allow me to use a 31" diameter prop.".....But I am not too upset about it , I really do not want to spend that much money.
Armilite
Sep 5, 2011
3,281
AMES, IA USA
Compression Wise
Raising compression as Armilite suggests will yield more HP without any need for change in carb size. The sedate 9.5cr of the 447 buys you about 1hp and the 11.6 of the 377 about 1.5Hp over stock 7cr (if that is actually the starting number)
======> The 447 is 9.6cr not 9.5cr. The 377 has been listed from 9.6cr to 11.6cr!
He will probably dispute this as he wrote in a previous post
He Said Maybe you should READ your own chart. A 100hp Engine with 8.0cr going to 12.5cr = 4.5 Points is 115.5hp or a 15.5 hp GAIN. Your Chart says 8.0cr to 8.5cr = 2.2hp for a +0.5cr for Big Car Engines. For these much Smaller CC Engines, it's more like 1hp Max for a +0.5cr Bump, as I said. How do I know this Info is that Skidoo made the same Single Cylinder Engine one year that used 8.0cr making 18hp@5500rpm and next year used 9.0cr making 20hp@5500rpm! So Max 2.0hp for a +1.0cr.
=====> When you use the same Spec's for a 302 Chevy V8 Engine in Desktop Dyno, but just change the CR used.
302 CHEVY v8 SB 7.0cr 390hp@6500rpm
302 CHEVY v8 SB 7.5cr 405hp@6500rpm +15hp
302 CHEVY v8 SB 8.0cr 418hp@6500rpm +13hp
302 CHEVY v8 SB 8.5cr 431hp@6500rpm +11hp
302 CHEVY v8 SB 9.0cr 442hp@6500rpm +11hp
302 CHEVY v8 SB 9.5cr 452hp@6500rpm +10hp
302 CHEVY v8 SB 10.0cr 461hp@6500rpm +9hp
302 CHEVY v8 SB 10.5cr 470hp@6500rpm +9hp
302 CHEVY v8 SB 11.0cr 478hp@6500rpm +8hp
302 CHEVY v8 SB 11.5cr 485hp@6500rpm +7hp
Going from 7.0cr to 11.5cr = 485hp - 390hp = 95hp Gain!
Unfortunately he did not read the directions for using the chart
The numbers on the chart represent a percentage increase from any HP to a new HP with a new compression ratio for ANY size engine.
From the chart
7 to 9.5 Cr = 2.5 points = 9hp x 109.6% = 9.864 HP
7 to11.5 Cr = 4.5 points = 9hp x 115.5% = 10.395 Hp
There is an online calculator that closely matches this number(certainly within rounding error)
http://bgsoflex.com/crchange.html
It does not ask for engine size
9hp - 7.5 to 11.5 Cr = 10 a 15% increase
=====> Your Cpmpression Calc doesn't hold True!
Computation Results:
  • Engine Horsepower (peak) is 390
  • Old Compression Ratio is 7.0
  • New Compression Ratio is 11.5
  • Computed New Engine HP is 450, a 15 percent change. (485hp).
Basing rule of thumb equations on decades old marketing data is problematic.
1) As he has said in previous posts , those manuals may contain typos
2) In the 60's there were no digital torque measuring devices. Claiming accuracy to 0.5 hp based on analog gauges of the day would be suspect.
3) Marketing guys inflate numbers- Briggs and others recently got sued and lost for inflating HP numbers.
======> Yes it is, but it's all we got to get some Ball Park Numbers! That 2hp difference on the same 335 Engine using 8.0cr(18hp) vs 9.0cr(20hp) might actually have been 1.6hp that was rounded up. I understand that and most other People do also. Your the one looking for an Absolute Number where there isn't any! Using a Smaller 185cc Engine it will probably be less. Just as your Compression Calc doesn't match to show +2hp. Most all of these Old Rotax Singles fall into 184cc to 335cc ranage.
Your Calc, Computation Results:
  • Engine Horsepower (peak) is 18
  • Old Compression Ratio is 8.0
  • New Compression Ratio is 9.0
  • Computed New Engine HP is 19, a 4 percent change. Manual said 20hp!
If you wish to use +1.0cr = 1hp, +0.5cr = .5hp than by all means do so. Till I see a Dyno showing the Numbers, I'll use mine.
If the 185UL is 9.4hp@5000rpm.
7.0cr = 9.4hp
8.0cr = 10.4hp
9.0cr = 11.4hp
10.0cr = 12.4hp
11.0cr = 13.4hp
11.5cr = 13.9hp
12.0cr = 14.4hp
12.5cr = 14.4hp
13.0cr = 15.4hp
The Lazair at MTOW of 450lbs needs 13.7hp for each Engine. That's why the SOLO 210 15hp was so well-liked.
For a gut check - his 2hp per CR rule of thumb would say the 4.5 point CR jump from 7 to 11.5 would yield a 9hp increase. That makes the 9hp 185UL engine 18hp with no other changes
Not very realistic. Plus why all discussion about carbs if you can get 9hp by simply raising compression.
For a good read on CR vs HP - try this article
https://www.hotrod.com/articles/0311em-power-squeeze/
It includes a similar chart and the mathematical equation used to develop itView attachment 93115
I agree 2hp is Max you would see for a +1.0cr Bump on these Small CC Engines using the Manufactures Numbers. Are they 100% correct, nobody knows! Will they be different for Smaller than 335cc Engines, Yes, account you're using different CR's with different Bore & Strokes(CC) with different Size Carbs.
As can be seen on both the Hirth F-33(28hp) 313cc with 34mm Carb and the Rotax 277UL(26hp) 268cc with a 36mm Carb on both Power Charts, they both start losing power at around 5500rpm.
Just a Carb Change from 22mm to 28mm you would see a hp improvement. If you just use the Carb OD's 22mm to 28mm = about 27.5% more Air.
9.4hp + 27.5% = 11.985 hp. If you Bump the 185UL from 7.0cr to 9.5cr as I suggested with a 28mm Carb, using n3puppys rule 7.0 to 9.5 = 2.5 x 1.0 = 2.5hp + 9.4hp = 11.9hp + 27.5% = 15.1725 hp. By my General Rule 7.0 to 9.5 = 2.5 x 2.0 = 5hp + 9.4 = 14.4 + 27.5% = 18.36 hp. So Ball Park with 28mm Carb and 9.5 CR Bump upgrade that's what your looking at 15.1725 hp to 18.36 hp.
The best thing to do is make one of them Club Props for 15hp, hook a Tach up on engine on a Test Stand, and Test to get a Baseline, and then start by taking off the Muffler and see what it does to get a Baseline. Then add a Straight Pipe and Test to get a Baseline. Then add a Bigger 28mm Carb and Test. Picking up an extra 185 Head would be nice account you could Mill it for 9.5cr to do CR Testing, then mill the original for 10.5cr till you meet your goal of 15hp.
If you use the Peak Flow/HP Calc, 50% VE is as low as it goes: 1hp has a variance of 3%. So if only making 9.4hp@5000rpm it's probably around 45-46% VE. My 670 Dynoed 114.7hp@7750rpm = at 93% 114hp, at 94% 115hp, so probably 93.7% VE.
185UL 184cc at 5000rpm at 50% VE = 11hp and makes 16 cfm.
185UL 184cc at 5000rpm at 100% VE = 22hp and makes 32 cfm.
At 6500rpm, 184cc/7cc = 26.2 hp. 184cc at 6500 making 26hp falls into the 91%-94% VE range. The Calc only works with whole numbers. Most 2 Strokes that use 11.5cr, the proper Size Carbs, and turned 6500rpm falls into that 91-94% range.
Armilite
Sep 5, 2011
3,281
AMES, IA USA
From a breathing efficiency stand point - an engines required carb airflow is based on the Volumetric efficiency of the engine. 90% is used in examples below since that is realistic for a MODERN carbed, muffler equipped two stroke. (The 185 is hardly modern...)
=======> First of all the Stock 377F/380F is rated 36hp@7000rpm used on Sleds with a 30mm Carb. 368cc making 36hp@7000rpm = 59-60% VE. The 377UL was rated 35hp@6500rpm using a 36mm Carb which comes in at 62-63% VE. Engines making 90-94% VE are using a Tuned Pipe not a Muffler! <====
Armilite might dispute these numbers based on his previous post
He said 184cc and you always Size a 2 Stroke Carb at least 10% over what you need! on Avg a +1mm Carb = 6-7% more AIR. On these Engines, we have a set Max 6500rpm, and I wouldn't run over 11.8cr so you have a Max CR to use also. These Smaller Engines can only use so Big of Carb probably 38mm Max for 277UL to 503UL. You will never see a 100% VE let alone 110% VE.
See the attached dyno sheets that show 90% is reasonable.
377F @ 82CFM @ 6900 rpm = 91% VE
550F @ 132cfm @ 7005 rpm= 96%VE
======> No your 377 isn't making 91% VE, it's only making 45hp! 368cc making 45hp@6900rpm dials in at 75-76% VE. A Mild Tuned Pipe added to the Stock Engine 36hp + 25%(9hp) = 45hp! The other Dyno Sheet doesn't have a Label, so we don't really know what it was for. If for a 550F it looks like 65.26hp. 553cc at 7005rpm making 65hp is 71% VE. The 550F uses 9.6cr. That sheet is dated 2003, and I talked to a guy who had his New 2004 Dynoed which had 34mm Carbs and he said it made 70hp@7000rpm. Later 550F's used lower rpm and Smaller 30mm Carbs. Aaen sells Tuned Pipes that show a 6-9hp Increase at Stock rpm. If you compare the Stock 380HO 368cc. It was 48hp@7000rpm = 79% VE, and with a better-Tuned Pipe it made 57.26hp@7000rpm = 93% VE. CFM is based off Bore & Stroke & rpm, Hp is based off Toque made, VE is based off Hp made at a Specific rpm. <====
Using Armilites calculator and his +10% rule
185cc @ 90% VE @ 5000 rpm = 29cfm +10% = 31.9
185cc @ 90% VE @ 5500 rpm = 32cfm + 10% = 35.2
Carb. Flow values based on Venturi size
22mm = 32 cfm Ok at 5000rpm. 3.25CFM short at 5500rpm
28mm = 52 cfm/ 35.2 = 48% buffer @ 5500 rpm
30mm = 59 cfm/ 35.2 = 67% buffer @ 5500 rpm
The 22mm HL sized carb on the 185 is borderline @ 5500rpm IF the engine breathing efficiency is really 90% (That is not very likely)
=====> Maybe, I didn't explain myself as clear as I should. 110% is just that.
184 cc at 100% at 5000rpm = 32cfm, Stock 22mm = 32.3cfm so you should Size the Carb for at least 110% which is 36cfm @5000rpm!
You want your Max HP Power at your 5000rpm.
22mm 379.9 0.085 32.3 cfm
23mm 415.3 0.085 35.3 cfm
24mm 452.2 0.085 38.4 cfm
25mm 490.6 0.085 41.7 cfm
26mm 530.7 0.085 45.1 cfm
27mm 572.3 0.085 48.6 cfm
28mm 615.4 0.085 52.3 cfm
29mm 660.2 0.085 56.1 cfm
30mm 706.5 0.085 60.1 cfm
184cc at 100% at 5500rpm = 36cfm, so you want at least 110% = 38cfm Carb. Carbs are usually Sold in even numbers, odd numbers are Special Order. Air Density affects all these numbers!
The 377, 1/2 = 185UL used a 30mm Carb, the 377UL used a 36mm Carb. Newer 380's use a pair of 30mm Carbs.
BHP of 9.4 at sea level and Elevation of 1000 feet is 0.28 HP loss.
BHP of 9.4 at sea level and Elevation of 2000 feet is 0.56 HP loss. <===
But before any time and energy is expended adopting a larger carb, other mods would likely be needed to increase the amount of air the engine can draw to achieve the 90% or more VE.View attachment 93118View attachment 93119
The only way you will ever see a 185UL make 90% VE is a Tuned Pipe and Bigger 28mm+ Carb and raise the CR. It probably has small Ports, so Porting also. The engine has to breathe in and breathe out.
n3puppy
Jun 25, 2019
138
302 CHEVY v8 SB 7.5cr 405hp@6500rpm +15hp.
302 CHEVY v8 SB 8.0cr 418hp@6500rpm +13hp.
302 CHEVY v8 SB 8.5cr 431hp@6500rpm +11hp.
302 CHEVY v8 SB 9.0cr 442hp@6500rpm +11hp.
302 CHEVY v8 SB 9.5cr 452hp@6500rpm +10hp.
302 CHEVY v8 SB 10.0cr 461hp@6500rpm +9hp.
302 CHEVY v8 SB 10.5cr 470hp@6500rpm +9hp.
302 CHEVY v8 SB 11.5cr 485hp@6500rpm +7hp.
Going from 7.0cr to 11.5cr = 485hp - 390hp = 95hp Gain! 1.2436
Thank you for Again proving my point.
HP vs compression ratio changes are dictated by the engineering accepted equation.
E=1-(1/R^K-1)
E=efficiency,R=static(nominal) compression ratio, and K = 1.4
While I have never seen the Desktop Dyno Program it looks like it simply uses a different number for K than the chart. That is quite normal because 1.4 is for a theoretically normal engine. K will vary because of things like Air cooled vs Liquid cooled affecting losses due to different combustion chamber temperatures. (Heat soaking)
The chart I showed uses K=1.25
Your chart still follows the rule of diminishing returns of the Otto Cyle engine. As compression increases, the % change per point of compression decreases.
Using Desktop Dyno's numbers you provided
302 CHEVY v8 SB 7.5cr 405hp@6500rpm = 3.85%
302 CHEVY v8 SB 8.0cr 418hp@6500rpm = 3.21%
302 CHEVY v8 SB 8.5cr 431hp@6500rpm = 3.11%
302 CHEVY v8 SB 9.0cr 442hp@6500rpm = 2.55%
302 CHEVY v8 SB 9.5cr 452hp@6500rpm = 2.26%
302 CHEVY v8 SB 10.0cr 461hp@6500rpm = 1.99%
302 CHEVY v8 SB 10.5cr 470hp@6500rpm = 1.95%
302 CHEVY v8 SB 11.0cr 478hp@6500rpm = 1.70%
302 CHEVY v8 SB 11.5cr 485hp@6500rpm = 1.46%
Per your chart,
390hp@7.0 vs 485@ 11.5cr = 24.36%
For the 185UL @ 4.5 point CR increase
7.0CR = 9.4hp
11.5cr = 9.4x1.2436 = 11.69 hp (Desktop dyno)
11.5cr = 9.4x1.1150 = 10.48 hp (Chart)
Both of those numbers are significantly below your "New Rule of Thumb"
1 hp per point of compression increase
7 to 11.5 = 9.4hp + 4.5hp = 13.9 Hp
If your rule of thumb number were actually correct - we could stop any discussion about carb size because 13.9 hp x 2 = 27.8 hp with 22mm carbs and current exhaust. EF11AE2E-5773-4924-AB0E-B6F0F3AA94A2.jpeg 7A64B2E2-9F3B-434D-A309-53676229B6BA.jpeg
n3puppy
Jun 25, 2019
138
That is a very good idea
From your album I see you have two engines
Rotax 335@ 8.0CR
Rotax 340 Tnt @ 10.5 CR
You could make a club prop -(If it would work at 5500 rpm)
Run the 335 with the 8.0 head.
Then swap the 10.5 TNT onto it to see which method of estimation is closer.
8.0cr = 18 hp stock
10.5cr = 18 x 1.096 = 19.3 hp (chart %)
10.5cr = 18 x 1.124 = 20.2hp (Desktop Dyno %)
10.5cr = 18 + 2.5 = 20.5hp (new 1 pt = 1 hp rule of thumb)
10.5cr = 18 + 5.0 = 23.0 hp (old 1 pt = 2hp rule of thumb)
n3puppy
Jun 25, 2019
138
Once again, you are using the 1.5cfm /Hp number that the author of the program has repeatedly said is inaccurate
It consistently will inflate the HP numbers of a 2 stroke engine
Published Dyno results have shown 2-stroke engines in the range of-
1.7 - 2.0 CFM/HP based on things like pipe vs muffler
2.0 is the number produced by a 550F Trail sled
Using that number of 2.0CFM/HP
185UL 184cc at 5000rpm at 50% VE = 16cfm and makes 8hp.
185UL 184cc at 5000rpm at 100% VE = 32cfm and makes 16hp.
As previously noted the 22mm carb flows 32cfm
Using your rule of thumb that carb must be 10% bigger than required
Means the 22mm carb should be used at only 90% of rated flow
32x 90% = 29cfm
With a 22mm carb @ 2CFM/HP
185UL at 5000rpm at 57%VE = 18cfm and makes 9 hp
185UL at 5000rpm at 90%VE = 29cfm and makes 14.5hp
n3puppy
Jun 25, 2019
138
It appears you must have typed your values in wrong when you used the Peak Flow calculator
Using your carb flow number chart
22mm = 32cfm
28mm = 52.3 cfm
Using the ACCURATE portion of the calculator for VE% at Flow rate
185cc @ 5000 rpm @ 32cfm = 97% VE. (22mm carb)
185cc@ 5000 rpm @ 52cfm = 158% VE (28mm carb)
Porting and a pipe are still likely required for a 185UL to fully utilize the 22mm carbs full flow of 32cfm giving 97% VE.
It would seem unrealistic to believe any amount of porting and piping will fully utilize the 52cfm flow of a 28mm carb and achieve 158%VE
As I previously stated - while a 28mm is oversized for the 185UL, it should be ok in the application. Additionally it provides a starting point for Jetting using the specs for the Skidoo Elan 250 that came equipped with a 28mm carb69CD85AC-BBFD-4553-B890-4D966C8DB089.jpeg7C551845-C93C-4B23-A663-0F48C717D2B7.jpeg
Dave Hodges
Jun 29, 2014
81
Reidsville, GA
Thanks for that information
I have been struggling to figure out how much faster the identical prop will turn when jumping from 9 to 12hp
If I am understanding you correctly -
Cubed root of 1.3333 =1.100642416
5000rpm@9hp x 1.100642416 = 5503 rpm @12 hp using the same prop.
Likewise, 150rpm increase with exhaust change calculates as
5150/5000rpm = 1.03 , Then cubed = 1.092727
9hp x 1.092727 = 9.834543 hp to gain 150 rpm
That's a 9% increase in hp from poking holes in the muffler!
Did I do that all correctly?
That's the way I figure it too.
Dave Hodges
Jun 29, 2014
81
Reidsville, GA
Dave, we're trying to change the rpm, if any maybe +500rpm. The 185UL 7/8" PTO in Direct Drive won't handle much Weight, that's WHY they used such a Small Plastic Prop originally. At 9hp@5000rpm the upgrade was a Carbon 32" x 10.
185UL PTO Failure with Original Crank which was I think Machined wrong, No Filet. Upgraded Crank with Rust doesn't Help either.
I can't tell you anything about this particular set up. But theoretically speaking, 5500 rpm would be a 10% increase above 5000 rpm. Torque is proportional to the square of rpm. So the torque on the propeller shaft would be increased 21% (because 1.1x1.1=1.21). The horsepower needed to increase the rpm 10% would be 1.1x1.1x1.1=1.331 times the original horsepower.
PagoBay
Nov 16, 2013
126
US Territory of Guam
Exchanged a few emails back in March 2017. My emails show that Gene posted a comment to an interview clip filmed with Brian Carpenter during Oshkosh 2019. My emails to Gene after that in late Sept 2019 went without reply. His blog is at Last posting was July 2019.
Dan Johnson featured the Lazair in his "Vintage" series very recently.
EDIT: See JUNE 29 2020
Canadian design coming back, or not? At present, the good news is that Gene Yarbrough, proprietor of Lazair Nouveau is making parts again for the long-out-of-production light aircraft.
Learn more about this popular design and Gene’s enterprise but a glance at the nearby photo shows how distinct this aircraft is compared to any flying machine. Lazair was even more eye-catching back in a time dominated by Quicksilvers and CGS Hawks but even today, its clear coverings, inverted-V tail, and twin engines set this fascinating aircraft apart from most others.
Nearly everything about Lazair was different, but the image shows the central structure clearly and it is easy to imagine how unique this looked when all other ultralight vehicles were so basic… and draggy. Lazair’s smoothness and attention to lower drag made it work well on two tiny engines. Power was originally supplied by two modified Pioneer Chainsaw engines of approximately 5.5 horsepower each though these were later replaced by two, single-cylinder, 9.5-horsepower Rotax engines.
You might reach out to Dan for how to contact Gene.
mullacharjak
Nov 5, 2010
183
Peshawar Pakistan
I think the Lazair was heavily influenced by the Larry Hall Super floater foot launched sailplane.Other than the V tail they both have almost the same structure.One can find free drawings for superfloater on homebuilt hang gliders facebook page.All that is left is to put two chainsaw engines on the wings.
Armilite
Sep 5, 2011
3,281
AMES, IA USA
22mm = 32cfm
28mm = 52.3 cfm
As I previously stated - while a 28mm is oversized for the 185UL, it should be ok in the application. Additionally it provides a starting point for Jetting using the specs for the Skidoo Elan 250 that came equipped with a 28mm carbView attachment 93269View attachment 93270
The 185Ul uses a low CR and a Muffler. I have hp listed at 9.0 hp, 9.4 hp, and 9.6 hp all at 5000rpm. Since 9.4 hp is the most I have seen, will use it.
185cc at 5000rpm at 50% VE = 11hp using the Calc 1.5 and making 16cfm!
16 cfm/1.6 = 10 hp
16 cfm/1.7 = 9.4hp@5000rpm
185cc at 5500rpm at 50% VE = 12 hp using the Calc 1.5 and makes 18cfm!
18 cfm/1.6= 11.25 hp
18 cfm/1.7= 10.6 hp
With a Redrive:
185cc at 6500rpm at 50% VE = 14 hp using Calc 1.5 and makes 21 cfm, now you can see that 22mm (22cfm) Carb is too Small!
Now just change the Low CR 1.0 Point probably +10% Increase which now changes your VE and CFM made!
185cc at 5000rpm at say 60% VE = 13 hp using Calc 1.5 and now makes 20cfm!
20 cfm/1.6= 12.5 hp.
20 cfm/1.7= 11.8 hp.
185cc at 5500rpm at say 60% VE = 14 hp using Calc 1.5 and now makes 22 cfm!
22 cfm/1.6= 13.75 hp.
22 cfm/1.7= 12.9 hp.
So like I said, "The only way you will ever see a 185UL make 90% VE is a Tuned Pipe and Bigger 28mm+ Carb and raise the CR. It probably has small Ports, so Porting also. The engine has to breathe in and breathe out.
Work Backwards, if using 11.5cr, Proper Size Carb, with a Good Tuned Pipe at 6500rpm. 185cc/7cc = 26.4 hp is possible. The 277UL uses a 36mm Carb and 11.8cr!
Using the Calc, 185cc at 6500rpm making 26 hp = 92 % VE making 39 cfm. 2 Strokes Gulp Air, so when Carb Sizing them you add 20-25%.
39 cfm/1.6= 24.4 hp.
39 cfm/1.7= 22.9 hp.
The Lazair has a Max. takeoff weight: 450 lbs (204.1166 kg) / 10 kg = 20.41166 kw needed = 27.37249 hp needed. 27.4/2 = 13.7 hp ea Engine has to make if at MTOW.
A better prop was a great Improvement. Modifying the Muffler for a +200rpm also Helped. The Solo 210 at 15hp each made most people Happy. Just a Carb Change, a CR Bump and a Muffler mod it could make that 15hp easy.
With some extensive mods, Porting, Tuned Pipe, Big Bore, it could make 26+hp which might work for some People.
REVAN
Dec 6, 2016
213
Tucson, Arizona USA
My ideas (from least to most expensive) are to:
1) Add a NOS kit to get more power from the engines to unstick from the water. Use it like a JATO that you can turn on and off. To me, this makes way more sense than nitro fuel.
2) Add a third engine
3) Add a couple electric motors to the wings for extra thrust during takeoff. Set up right, they could be used as generators during cruise.
If you want to re-engine the plane, you might want to consider these with an ACE Re-Drive:
225cc Tillotson Performance Engine
Its a 17 HP, 4-Stroke for $750. Adding the ACE PSRU will about double that. You may want to consider propping it down to 13 or 14 HP for engine longevity. Between the extra power and larger props, it should solve the issue for you.
Armilite
Sep 5, 2011
3,281
AMES, IA USA
=====> NOS kit + Plane = FIRE or Blown Engine at High Altitude!
=====> 3rd Engine is not needed, when you can Upgrade the 185UL's fairly cheap. A New Hirth F-36 (SOLO 210) 2 cycle 15hp is F-36 with Recoil Start & Re-Drive $2364.00 and F-36 with Electric start & Re-Drive $2964.00.
=====> Again More Cost & Weight not needed!
=====> Yes, a re-engine with one of these 20+ Honda/Clone Engines with an ACE Belt Drive $669 works. The Honda/Clone GX200 6.5hp has been used on a few Lazairs already making about 15hp@5000rpm each. A Harbor Freight Predator is 212cc and $99.99 when on Sale, and with the upgrades needed which you can do your self for Plane use, is around $400-$600 depending on what you all do. I would use the Billet Needle Bearing Rocker Arms ($200), most don't. By their Dyno Power Graph at 5000rpm it's making 15hp.
That $750 doesn't include the Header Exhaust.
225cc Tillotson Performance Engine Power Graph below. Probably not the best CAM for Airplane use. The Power Band is too High. You want the Power Band at 3000-5500rpm to look like this one does at 4600-6600rpm Smooth, no Blips.
The Rotax 185UL just needs a Bigger Carb $40 off eBay and a better Muffler System that is less restrictive.
