Kuhn's Diagonal Tension Factor
imamac96
May 10, 2018
47
North Texas / South Bay
Chris Heintz's book makes many references to Kuhn's Diagonal Tension Factor. I understand that Kuhn wrote an entire structures textbook. I'm trying to dig through to find any curves that match the one on page 185 in the 3rd edition of Heintz's book. Can anyone tell me where I can locate this formula? I have found the NACA report (https://ntrs.nasa.gov/api/citations/19930082135/downloads/19930082135.pdf) on curved webs (Chris used it for flat webs, e.g. the spar). I have also searched the site and have found many references to Kuhn's book but no direct discussion of the formula. At the moment, I'm interpolating using regression to get me "close enough" for spreadsheet calculations.
plncraze
May 11, 2006
2,262
Heintz sometimes changes formulas for his book. He did the redesign of the Robin wing when it went to metal construction. The H in the HR prefix on Robin aircraft was for him. So sometimes he will have his own formula for structures. I tried looking for the same chart or something close to it in Bruhn and Niu but could not find it. His book title is below.
Stresses in Aircraft and Shell Structures​
plncraze
May 11, 2006
2,262
Here is a graph using this formula from another book. I always try to double-check some of these formulas with an engineering text but Heintz is the only book that tries to get it all in one place.
  • coward page.pdf
imamac96
May 10, 2018
47
plncraze,
Thanks for looking. I really appreciate it. Yes, Heintz rounds... a lot. It can be really hard to follow him because he constantly changes between units (and uses weird ones too sometimes to meet his approximation formulas). These graphs look pretty similar but not quite. I'm looking at inverses, but it's still not lining up. I have an approximation with a log right now, so that's sufficing as an approximation of an approximation at the moment.
SpruceForest
May 23, 2022
236
Kuhn and Griffith TN 1481 (Diagonal Tension in Curved Webs) was published in Nov 1947, while Kuhn, Peterson, and Levin TN 2661 (A Summary of Diagonal Tension - Part 1: Methods of Analysis) followed in May 1952. A quick pass through 2661 looks like both plane and curved webs are presented with numerical examples for each.
plncraze
May 11, 2006
2,262
I wrote a question on Heintz's website for this book when he was alive but there was no reply. I figured it out but I would have like to have used this in a class where he was the teacher so he could explain some of this. I can tell you it is nice to have all of the steps in one book. It is a neck of a lot better than P. E. Bird's book from the early 80's.
imamac96
May 10, 2018
47
Figure 7 of report 1364 was what I was looking for. Thanks! Now, I need to read the whole report.
Yes, it’s a cluttered book, but it’s really a nice, comprehensive coverage.
Chris Young
Feb 19, 2013
94
France
I remember a lot of Kuhn's work made it into Bruhn's textbook in the chapter about diagonal tension (chapter C11 IIRC). It was also completed by an addendum/errata published later. You might find more readily applicable explanations there.
