Kawasaki 340 Voltage reg output
Dirthawker
Jan 23, 2021
Hello all,
I’m new here and new to ultralights and I’m looking for some help concerning voltage regulator outputs on a Kawasaki 340 engine.
I bought this aircraft slightly used and initially had an RPM indication error on my GRT EIS display. At the advise of GRT, I installed a new voltage regulator but that did not fix the problem. Turns out, it was a bad connection on the rpm lead and not related to the regulator. Point is, now ,i have a new voltage regulator.
I installed a LiFE PO4 battery and things operated normally for the next 3-4 hours of taxi time and ground test. This lithium batter has separate charging leads at the top of the battery case and I connected that lead with a quick disconnect plug for ease of removal and charging if needed.
The next day while taxiing, my EIS screen flickered and then went blank. I turned the EIS power off, and taxied back to the hanger and shut the aircraft down. A few minutes later, I powered the EIS and it would come on for a few seconds, showing low voltage and then it power off. I pulled the battery out of the aircraft and it indicated less that 3 volts. Obviously I had just ruined a $200 battery. It appeared the battery was not being charged.
I installed a lead acid battery and connected a volt meter to the out put of the voltage regulator . It indicated 14.4v at idle rpm. Unfortunately, what I did not do, was increase the engine RPM while monitoring the v/r output voltage.
I was under the impression that the lithium battery was equipped with internal charging protection. I had decided that the battery had dropped below a low voltage threshold and the charging circuit opened preventing the battery from charging and that I had continued to use the battery thus totally depleting it. I ordered and installed a new lithium battery and charged it with a LiFe charger. I checked the voltage before and after start and taxied around for about 10 mins. Back at the hangar, I check the voltage after engine shut down and couldn’t below what I saw, 24V and decreasing. That can’t be right. I exited the airplane and checked the voltage with a voltmeter at the terminals, 21v and decreasing. I cleared the area and remained clear of the airplane for about 2 hours. I then removed the battery which was now showing less than 1V , another one bites the dust! I had set a low voltage limit warning in my EIS but I did not set a high rpm limit and the voltage is not displayes in the normal run page after start. Lesson learned!
I installed a lead acid battery again and started the airplane. At this point, the v/r is not connected to the battery but I am monitoring the v/r output with a volt meter. At idle, 14.4V but then as I increase the engine rpm and saw an output over 24V. So what I thought was lack of charging was actually over charging. So I installed the original v/r and still have the lead acid battery installed and now I’m not seeing the voltage output increase with rpm, I’m almost seeing the opposite. After a few minutes (3-5) at low rpm, the voltage will increase to about 17v. If I advance the throttle the voltage output drops quickly to 14.4 and will stay in that 14V range if I stay at around 4500rpm of higher. Is this normal output for the voltage regulator or should it deliver 14v consistently at all rpm ranges?
thank you,
Cody
