Is there a way to calculate the lift curve slope vs aspect ratio?
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by rtfm, Sep 26, 2018.
  1. Sep 26, 2018 #1
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,155
    558
    Brisbane, Australia
    Hi,
    I am trying to find a way to calculate the lift curve slope of a wing depending on its aspect ratio. Is there such a beast? Basically the slope value * some factor based on AR.
    Duncan
  2. Sep 26, 2018 #2
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,216
    463
    Ok. A tiny bit of algebra on a formula found in Hoerner* for "lift angle" gives:
    dCl/d alpha = 1/ (10 + (20/A))
    This is supposed to be a rough approximation for straight wings of at least moderate aspect ratio, and may still be a little different depending on planform shape. Units are degrees.
    *Fluid Dynamic Lift Don't know if you can still get it.
  3. Sep 26, 2018 #3
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,216
    463
    Was poking around the web about something else and found a reference to a way of calculating lift curve that's supposed to be in NACA TR-665. You can probably find that on NASA's technical report server or on the Magic NACA Archive. Appears to be more complicated.
  4. Sep 26, 2018 #4
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,155
    558
    Brisbane, Australia
    Thanks mate
  5. Sep 26, 2018 #5
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,216
    463
    BTW, I bet if it's for a Pou, it's more complicated.
  6. Sep 26, 2018 #6
    dwreck
    dwreck
    dwreck
    Jan 24, 2014
    32
    1
    Abu Dhabi, UAE
    General Aviation Aircraft Design by Snorri Gudmundsson has a short section in Chapter 9 listing various methods for estimating wing lift-curve slope. Inbox me if you want screenshots.
  7. Sep 26, 2018 #7
    5,869
    1,488
    1/(pi*(1+(2/A)*(1/e)))
    where e is span efficiency. Angle in radians
  8. Sep 30, 2018 #8
    Pete Plumb
    Pete Plumb
    Pete Plumb
    Oct 23, 2014
    175
    249
    SHAFTER, CA
    The one I use is a simple old Department of Commerce formula: .0725 x 4 over 3+(6/ARe).
