Hi!
As Erkki and Bmcj pointed out a sub 70kg airplane/primary glider would not be something very performing. However from the design perspective it represents a very exciting challenge; to be able to do more with less.
Buidling a rectangular covered with fabric, without dope, and 3d printed widgets, like those used by addicted to climbing, seems the most straighforward wing for a three axis airplane. I really like the first version of the Swift flying wing which was tube and fabric.
If considering a parafan engine for a light aircraft design. A tractor engine would make a light aircraft nose heavy for a parafan or weight shift. In my particular case that makes very hard to add an engine in my recumbents. However, I was thinking to take off with a trike fuselage and a paraglider without engine like in the video below.
I do not know if with your experience with parafans Blackburn Mark this would easy? I know the engine helps inflate the wing which makes it more easy to take off. I bet that in the right place with the right wind this would possible.
A possible alternative to use an engine to help taking off with a paraglider, without adding prohibitive weight to the nose, would be to use an big electric RC/drone engine, and place the batteries on the back. Given the high cost of batteries for sustained powered flight, I would probably use some standard drone batteries. this would allow me to take off and perhaps stay below the sub 70Kg limit both using a paraglider, delta wing or even a rigid three axis tube and fabric wing.
Henryk, I know very well from my personal experience, and I bet that all in here agree with that, that being able to carry on with a build is very hard because life goes on. I hope you can work more on your projects!
Given said, that I agree with Aesquire that trying to design an engine/transmission for a homebuilt tends to overcomplicate it a lot. It is much better to adapt your design to an engine that is available on the market rather than the opposite. That being said we are lucky to live in a free world, at the end its our own choice what matters.
OTOH, I too agree with Aesquire that perhaps the theroetical Cl of a Kasperwing is very high but probably in reality is more or less standard.
Sorry I do not remember who mentioned, but I think the Whoopy was never commercially available after a pilot lost his life testing it. I think the accident was due to the wing collapsing in flight.
Thanks a lot everyone for your comments!
Oriol
