I'd be interested in the "vague rumblings" that are out there.
As far as weight .. the Corvair is heavy. It's a bit lighter than an O-200 but the factory is not happy about the use of them. But mine has been extremely reliable, smooth, and makes great power. There certainly are heavier choices that have been used on this airframe but I digress.
The CG on my plane is excellent. I did mount the battery in the tail to counter the heavier FWF weight. My current CG requires a single pilot with full fuel & no baggage to be at least 180 lbs. But with it set up this way there is no loading scenario that puts the CG close to or over the rear limit (obvioulsy respecting the gross limit of the plane). If a pilot of less than 180 lbs. were to fly the plane the CG would have to be changed by adding weight to the pilot seat, adding luggage, or not filling the fuel tank.
Dunno if this helps ...
