BlueRidge
Anglin Spacewalker 2 (later called Warner Revolution). Can be scratch built, or pre-welded kit.
Modifying this design slightly would make a good simple airplane for adventure touring.
1. designed as a tandem two seat, fly it from the front seat and convert the rear cockpit and baggage compartment into one large cargo area. c.g. will allow 250lbs of gear.
2. build a taller turtle deck that covers the rear cockpit / cargo area, and add a bubble canopy to the front cockpit.
3. a common modification is wing leading edge tanks that pump fuel to a 15gal(?) fuselage gravity fed tank. add as much fuel as you need. 85-115hp Continental or Lycoming.
4. taking a two person airplane and converting it to one person + gear + extra fuel, allows a lot of flexibility without overloading the airplane.
5. the designer was an accomplished machinist and airplane builder. they just had trouble running a business and keeping up with non-aviation demands. shame really, his planes deserve a
wider following.
6. most Spacewalkers out there are seriously overweight and suffer for it. built simply as designed and kept light, an O-200 would surprise you. it has a thick high lift airfoil, so 100mph is an economical airspeed.
Anglin Aero and Warner are no more, but an unfinished plane or plans could be found.
wider following.
