Impulse IF-1
FoamyDM
Sep 16, 2021
22
Awesome Video Red. Where is the Website Link showing the progress? up... I see it in post 1, Pardon me. My speed reading needs work
FoamyDM
Sep 16, 2021
22
Any examples of the all cable mixers? I don't think I've ever seen one.
Red
This post as a Mixer that looks lightweight but effective enough. it is for a Dyke's Delta.
11,129
Judy at Aircraft Windshield does a great job, she absolutely knows her stuff, and has a tremendous history of making canopies for aircraft. She's the top dog in the custom canopy world, with all possible respects to the handful of other people in that industry.
Red Jensen
Jan 1, 2018
90
Palmdale, CA
I'm nearly finished fitting the splitter plates to the fuselage so I can make the left and right mold halves. I took a bit of a break but I'm back at it now. This will be last of the molds I have to make. Wing and landing gear are machined molds. I'm looking forward to making real parts.
Red
pylon500
Dec 26, 2003
590
Taree Airport Australia
Cable mixer.
This is probably an answer to a problem, but I see assorted compromises within, what with floating pulleys, possible harmonics in the cables and overall flex.
The solid pushrod mixer here is probably a better bet.
That said (and I'll point out I'm not a huge fan of V tails), if you could hinge a large enough rudder on your underfin to hold against torque on take-off, then just have elevators, knowing you will never have to worry about the tail being caught up in the wake from the wing at any time.
Maybe a lot of differential in the ailerons to negate much need for rudder.
Red Jensen
Jan 1, 2018
90
Palmdale, CA
A pushrod mixer is the plan and what I have designed. I'll stick with normal V tail function, I don't think there will be any need for an independent sub rudder.
Red
