ryanjames170
What UL desighns could be used for my idea of a Twin using 212, 301cc 4 stroke engine?
Home Depot Plane, for 1, at least with the 212's, but I don't know what it's reputation is. I suppose you could put a cross bar on the Sky Pup's engine mount, and reinforce the fuselage a bit for the twisting forces, but the whole installation would have to weigh less than 62 lbs. This could be done, I suppose, with other front engine ultralights, but it would be ugly. I suspect the Lazair was meant only for two 2 strokes and might not be up to the extra weight in that location. Suggest choosing an aircraft that has a relatively long wing if you're going to use the 212's. I've seen pictures of Kolbs with two engines, but I don't know anything about it and I doubt if the span is long enough for the 212's.
Just as a warning as to how ugly things can get, here's a single engine plane that's been converted to a twin by the method I mentioned above.
I can strip one down if you guys like and weigh it.What do 212's weigh? Aircraft weight not out of the box.
YesI can strip one down if you guys like and weigh it.
Are you sure it isn't legal? Because fixing something that doesn't need fixing is a waste of time.The Legal Eagle XL is actually much closer to legal. I think if you gave it flaps over more than half the wing span, it WOULD be legal. Or, at least, the stall speed calculations would make it legal. Plus you have a couple of feet more wing. Flaps, of course, require some structural redesign and add weight. Many people have pointed out that the FAA, so far, hasn't got too excited if an ultralight is a little overweight.
Wonder how the FAA would feel about Gurney flaps? They would be easy and light to add. :gig:Would it have to be flaps? .
How about this?I might do some looking into a stripped 420CC engine as there is a list of things it really don't need on it and might come in close to what would be needed
That might work too. But you'd have to add a lot. And then make the tail bigger, or further aft.. (You'd have to make the tail bigger or further aft for flaps too, most likely.) You MIGHT be able to find an unusual, high lift airfoil that would make up a fair amount of the difference. But then, if the FAA asked, you'd have to test. (I haven't heard of them ever requiring this.) Maybe fixed slats or vortex generators. The latter can be very light and simple, and I suspect fixed slats could be relatively simple. I don't know what they do to the pitching moment, but presumably less than flaps do. Either one would reduce your top speed.Are you sure it isn't legal? Because fixing something that doesn't need fixing is a waste of time.
Would it have to be flaps? Could you make the chord a smidge longer? Less complicated as it doesn't require linkage and hinges and therefore lighter.
I think it would put out the HP but it might not do so well in the weight category though the 420cc engine is a hefty 73lbs stock..How about this?
http://www.vegascarts.com/460cc-go-kart-racing-engine-barebones-builder-kit-p/vrx46-diy.htm
Not sure how it does when constrained to relatively low rpm.
The Cloudster is another relatively long winged ultralight I didn't mention earlier. The original was significantly longer, but the current one is 31 feet or so. Maybe you could get them to cough up plans for the older version. Longer wings mean somewhat smaller engines are needed. The old Le Pelican had a 37 foot wingspan, but I don't know where you're going to find plans for it.
You might find something at vula.org, though you're probably going to have to take the names and check them out elsewhere.
