i bought the Europa XS Trigear... is it good???
Discussion in 'Workshop Tips and Secrets / Tools' started by dr.wolf, Apr 5, 2009.
  1. Apr 5, 2009 #1
    dr.wolf
    dr.wolf
    dr.wolf
    Apr 3, 2009
    31
    0
    lebanon
    hellllo
    i finally had an eye on the
    Europa XS Trigear
    is it good for flying in mountain and rough areas?
    i asked the many users of this craft and they said that is excellent
    but i trust this forum users more.....
    specifications :
    Dimensions
    Imperial Metric Wing Span (tip to tip)
    27.133 ft 8.270 Wing Span (inc tip influence) 26.917 ft 8.204 m Wing area (inc tip influence)
    102.11 ft² 9.485 m² Aspect Ratio 7.096 Overall length 19.17 ft 5.843 m Overall height 7.00 ft 2.133 m Baggage space 22.50 ft³ 0.637 m³ Weights and Loading
    Imperial Metric Maximum take-off weight - Note 1
    1370 lb 621.4 kg Empty weight / Useful load (Rotax 912 UL) - Note 2
    832 / 538 lb 377 / 244 kg Empty weight / Useful load (Rotax 912 ULS) - Note 2 853 / 517 lb 387 / 234 kg Empty weight / Useful load (Rotax 914 UL) - Note 2 897 / 473 lb
    407 / 214 kg
    Maximum baggage capacity 80 lb 36 kg Wing loading at max take-off weight 13.42 lb/ft² 65.52 kg/m²
    Stall speed flaps extended 44 51 81 Stall speed clean 52 60 96 Cruise speed 8,000 ft 75 % pwr (Rotax 912 ULS) (TAS) 135 155 250 Max cruise speed 10,000 ft (Rotax 914 UL Turbo)(TAS) 166 191 307 FeetMetres Take-off ground roll at gross weight (Rotax 912 ULS) 590 180 Take-off ground roll at gross weight (Rotax 914 UL Turbo) 500 152 Landing roll 600 183 fpmm/s Rate of climb at 1370 lb gross weight (Rotax 912 ULS) 1000 5.08 Rate of climb at 1370 lb gross weight (Rotax 914 UL Turbo) 1300 6.60
    Imp galUS galLitres Maximum Fuel (Standard Tank) 15 18 68
    Imp Gal/hrUs Gal/hrLitres/hr Fuel consumption at 55% power. Speed 95-100 kts @ SL (Rotax 912 UL)
    2.20 2.65 10.02 Fuel consumption at 55% power. Speed 103 - 108 kts @ SL (Rotax 912 ULS) 3.14 3.77 14.28
    nmsmkm Standard Tank Range at 55% power (Rotax 912 UL). Allows for 10 minutes at maximum TO power and 30 minute reserve 576.2 663.1 1067.2؟؟؟؟؟؟؟؟؟؟؟؟؟؟
