Hydrofoils
Discussion in 'Bush / Float flying' started by everyman_flight, Nov 11, 2005.
Thread Status:
Not open for further replies.
  1. Nov 27, 2005 #21
    everyman_flight
    everyman_flight
    everyman_flight
    Nov 2, 2005
    16
    1
    Yes. One simple mechanism of controlling hydrofoil AOA is to deploy a ski ahead of the foil to sense the position of the surface of the water and adjust the AOA using a simple lever system. See the Hobie Trifoiler for an example of this. Having the Hobie system dangling from the bottom of an aircraft would make an excellent candidate for the first, one and only Heath-Robinson heron. Anyway, as the wing starts to lift the plane the ski will sense that the foil is closer to the surface than before and decrease the average foil AOA.
    Regards, Max
  2. Nov 28, 2005 #22
    aquavion
    aquavion
    aquavion
    Nov 15, 2005
    18
    0
    Ajax, Ontario
    Wow...you guys really run with a subject !!
    The Barracuda I referred to was of the fish variety and the "tuck" was as you described Everyman_flight. Those are incredible speeds you quoted for the torpedo...its amazing what you can do to "fool" a projectile into thinking it's moving in air via boundary layer modification !! A similar technique is used to under-water launch an ICBM through a coat of bubbles until it reaches the surface. I wonder how much horsepower is needed to support the boundary layer modification relative to the installed horsepower ? In the case of a rocket this is preumably quite small.
    Ray Richards
  3. Dec 24, 2014 #23
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    china is my home , place of work but was born in N
    has anyone seen how the foil works under the Hysucat boats !! its made to produce lift and plane on the waters surface between two hull so is a completely different approach to foils way under the water .
    I feel people are blinded by the science and not seeing what's already out there that works ! why take something simple and turn I into a complicated nightmare subject ??
  4. Dec 24, 2014 #24
    13,075
    5,006
    Wow !! You only missed that last post by 9 years !!!
  5. Dec 25, 2014 #25
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    and who is doing it ? using wide foils that plane on the surface and work just as well submersed completely !!
  6. Feb 21, 2015 #26
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    ooops again and no answers ! Foils have uses but not applicable to amphibian's I fear !!Long spindly thin legs supporting lots weight and even as small thin foils that have to be and stay fully submerged till the moment of lift off these are the wishes of a crazy person !!
  7. Feb 22, 2015 #27
    akwrencher
    akwrencher
    akwrencher
    Oct 16, 2012
    1,122
    406
    Gustavus, AK
    I suppose these guys must be crazy then ;)
    LISA Airplanes - Pleasure aircraft designer
    bmcj likes this.
  8. Feb 22, 2015 #28
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    they sure are !! now come on be truthful How many planes they sold ? how may planes are in regular service flown by the average Joe on the block ! how many foils did they have to experiment with before they got one pair to stay without breaking bending twisting ! and most important if one foil gets damage is it possible to take off or land on water with just one foil. Id say at a rough guess you would want a bible in one hand and our joy stick in the other , Its pretty plane yes but you'd have to be high to want to buy one !
  9. Feb 22, 2015 #29
    akwrencher
    akwrencher
    akwrencher
    Oct 16, 2012
    1,122
    406
    Gustavus, AK
    No idea on any of those questions. Simply pointing out that it can and has been done. Military did a bunch of testing with different foils back in the day, and didn't end up going that route. Must be a reason. Still, like I said, it has been proven to work, ideal or not.
  10. May 6, 2015 #30
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    you are right even a brick can fly depending which way you looking at it !!!!
  11. May 16, 2015 #31
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    Think !! Is there just one type of foil ?? Is there only one size of foil ?? what is the failures of foils ? what advantages do they have? what are there disadvantages ( and they have plenty ) How do you get over and past those problems ??? everything has problems !! right ? why not combine a few things together and take the good points of each and make them work where each disadvantage leaves off and the next idea takes over and works for you !!
    Foils and ski's ?? ski's and foils ?? could they be made to work together ? or in combination ??
    Box's !! get out of the one your in !!!
  12. May 16, 2015 #32
    Super Moderator Staff Member
    Jul 30, 2005
    13,963
    5,576
    Even just a little use of the search function here on HBA will turn up most of the answers you seek. The topic has been discussed several times.
  13. May 16, 2015 #33
    10,012
    6,763
    OK, just did.
    No.
    No.
    Varies with design, maintenance and usage.
    Some are better.
    Some are prone to over-punctuate.
    Thinking "outside the box!"
    No, not everything.
    Because of stupidity.
    Done properly, they could.
    Rather than get out of the box, I prefer to "take to the next level."
    bmcj and Himat like this.
  14. May 17, 2015 #34
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    Taking it to the next level is still thinking single mindedly and still being in that box ! dispense with the box !!
    Ski's and foil each had advantages over the other now introduce the gull !!wont really work on a foil ! will partially work on a ski but it also has terrible limitations or it would still be used on water ski's!! Sea planes used that shape !! but boat hulls are shocking things with Gull shaped hulls ! so where to from here ??
  15. May 17, 2015 #35
    10,012
    6,763
    Exclamation Points | Punctuation Rules
    bmcj, Topaz and Dana like this.
  16. May 18, 2015 #36
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    stick to the topic !! Funny its always the same few people !!!!!!!!!!
  17. May 18, 2015 #37
    Jul 30, 2005
    13,963
    5,576
    Learning the fundamentals, so that you can build upon them without wasting time and effort. Yours and ours.
    Himat likes this.
  18. May 18, 2015 #38
    13,075
    5,006
    OK, you're thinking outside of the box, but do the men in the white coats know that you got out of your box?
    Sorry, I couldn' t resist! :gig:
  19. May 19, 2015 #39
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    typical !!
  20. May 19, 2015 #40
    WonderousMountain
    WonderousMountain
    WonderousMountain
    Apr 10, 2010
    1,853
    193
    Clatsop, Or
    I take BMCJ with a grain of "Wakka, Wakka-Wakka" ;)
    LuPi
    bmcj and Topaz like this.
Thread Status:
