Hurricane Mk103
13,083
The core would prevent skin buckling and that is nice. But does the core cancel the low e to weight ratio? Balsa core plywood might have superior modulus of e to weight ratio.
The Driggs DJ-1 wing was skinned with 3/64" plywood.
I would guess an ultralight might use thinner skin, perhaps 2/64" (1/32").
Aircraft Spruce has 1/32" birch ply for about $2/sq.ft.
I don't know what it weighs.
Might be 3.5 pounds per 4'x8' sheet or .1 pounds per square foot.
7,419
Been putting a spreadsheet together for loadings. Yawn. I can't do much structural design till I know all the loads.
I also had a coro bending experiment running. My first go at tight radius bends. I filled the flutes with salt. I bent it with an outer 'mould' of Al flashing till the fluting failed. I managed about 3/4" radius at that point. It's extra rough on the inside as I initially set the oven too hot and it partially melted. That also meant it was stuck to the flashing, which I didn't discover till I was bending it. Might try a flashing sandwich next time as well as not letting it stick...
lr27
Nov 3, 2007
3,822
You're comparing apples and Ferraris. There's no need to go to carbon to outdo PP. And balsa is generally stiffer for the areal weight than carbon or almost anything else without a core. OTOH, I'm sure foam core board is quite a bit stiffer for the areal weight than Coroplast. Skinning 1/8" or 1/4" of blue foam with 1/64" ply would far exceed the properties of Coroplast. Even skinning with light fiberglass would. Plus glue actually sticks to these materials.
Running a few quick numbers, I expect birch plywood to be comparable to the same weight of coroplast in bending stiffness, but completely superior in shear. That's a very rough estimate, but I'd be flabbergasted if birch ply was much worse. Any lighter plywood should be much better in bending, too. Coroplast is actually inferior in bending stiffness to the same THICKNESS of balsa in one direction, anyway. Two if you make balsa plywood. I guess I should just shut up, though, and let you do the test. I don't have any fresh Coroplast, just some that's been weathering outside.
It's too bad balsa isn't more consistent and cheaper. We could probably just make our aircraft out of balsa, except for the hard points.
Some further noodling around reveals that blue foam would be much stiffer in bending than the same weight of Coroplast, though I think it might not be better in shear. Maybe just cover your plane with thick blue foam sheet and lightly glass the outside. Highload 40 or 60 might be best.
Ther are better spar materials. that's why I have no intention of using it for a spar.
Take a piece of coro and piece of ply of the same weight and see which has the greater bending stiffness.
Modulus is ~180,000. Don't forget that coro is hollow section. I have misc scraps of unknown manufacture, but the webs in 4mm are about 1/4 of the total weight if you want to check the math. Once you factor the hollow core in, it's stiffer in bending than solid carbon of the same areal weight let alone balsa. That means less supporting structure is needed. Yes, I could make a superior sandwich skin from carbon and 1/8 divinylcel, but that would be a lot trickier and way, way more expensive. Have you seen the price of 3k carbon fabric? I also suspect hangar rash would be an issue. The give in coro means that it spreads loads and is very tough stuff.
At least one brand of corrugated plastic is made from this resin
lr27
Nov 3, 2007
3,822
BBerson:
I've seen at least one ultralight design with a 1/32" ply sheeted d-tubes. The VJ-23 rigid wing hang glider used 1/32" ply for the shear web! Also 1/32 "popular ply" (poplar ply?) for the wing d-tube sheeting. The Woodhopper plans seem to show 1" styrofoam for sheeting on the first few inches of the wing.
7,419
I'm not building a Ferrari. I don't need ultimate strength to weight. I don't need a carbon, glass or ply skinned structure. Or a composite sandwich. I want something light with sufficient stiffness and abusability that isn't too hard to build or cost a small fortune in materials and/or tooling. Or that dissolves if you spill fuel on it. Haven't a few Rutans crashed due to unseen fuel damage?
Skinned hiload was one option I wasn't overly keen on before I hit upon coro. To make it suitably light, it needs very thin skins, which will be very prone to hangar rash.
coroplast is lighter than the same thickness of balsa. Balsa is expensive and a lot more fragile. How heavy is balsa once you have sealed both sides? I looked at balasa cores too. Expensive, heavy due its sponge like nature.
Oh solid carbon doesn't out-stiff the same areal weight of Coro. I guess the apples win there.
I'm going back to my design calculations now. Feel free to carry on telling me why you think that my numbers are all nonsense.
13,083
I have been looking at clear Mylar for D-tube wing skin. Mostly because it is clear and see through for drilling rivet holes.
It comes in .002", .005", .007",.010" and .014", I think.
Seems Mylar (polyester) might be the stiffest plastic?
lr27
Nov 3, 2007
3,822
My reference to the Ferrari was that you were talking about carbon when there are many materials which are much better than Coroplast and cheaper than carbon.
You gave a modulus of 180,000 for the polypropylene. Even if you used a solid sheet of the stuff instead of the Coroplast, that's floppier, at least in one direction, than 6 lb balsa. But it weighs more than 11 lb balsa does. (The figure I saw was 0.15 lb/square foot for 4 mm Coroplast.) And the balsa has that modulus all the way through. There are ways to work with balsa without turning it into ballast, otherwise we'd never make model airplanes out of it. I suppose if you have a termite problem in your hangar, and you don't fly often... In any case, I know balsa is expensive and I wasn't necessarily suggesting it.
If you compare solid polypropylene to solid carbon, it's about 1 percent as stiff as carbon in the good direction. So I wouldn't say the "apples" win. If you compare a similar configuration of carbon to Coroplast, it will probably also be, say, 50 or 100 times as stiff for the weight. Solid anything, almost, is inferior to cored construction except maybe in shear if the surface isn't so thin it buckles.
I just checked Boulter Plywood's site. Okuome plywood is maybe 150 percent more expensive than Coroplast, but it's lighter and the physical properties would be far superior.
If you're worried about fuel damage, you could always use urethane foam or something instead of polystyrene foam.
Coroplast is lighter than the same thickness of moderately heavy balsa wood, but I've seen balsa nearly as heavy as spruce, and also usable balsa that weighs as little as 3.5 lbs/ft3.
If you could actually make a part 103 compliant ultralight using a lot of Coroplast, you could make a much lighter one with better materials. With the better materials, you'd get the same performance with less power, requiring a lighter, and perhaps less expensive engine.
I suppose I should probably drop this. You'll probably figure it out as soon as you start testing materials or parts, but then you'll have to redo the design, unless you test now. So I suggest, if you don't believe my numbers, do some fair and careful tests.
7,419
A monocoque 2mm coro H.S. with no internal structure is strong enough in torsion and spanwise bending stress for double figure g, but the bending shear combined with torsional shear will fail the LE at 3.8g with the cp at the LE. That's only 2.5g + safety. Torsional shear is also fine at lots of g so the thin skin can stay. I'll add some truss shear webs once I work out where they will also be most useful for chordwise loading. By truss webs, a cross section of the profile will be a truss. The shear webs will reduce the amount of ribs I need so the weight penalty isn't as large as it first seems. XPS is a possible web material if ti looks better than coro.
I'm a bit rusty on the finer details of structural analysis so I'm spending a fair bit of time working out how to do it again. Hence the slow progress. I was dubious about being able to do the H.S. in coro, but it is looking workable. I don't know how unfavourably the weight will compare to stick and fabric yet. The stress numbers look fine for the elevator. That's good as rigid skinned control surfaces work a whole lot better than fabric ones, thouhg mostly only an issue for ailerons. I'm getting an urge to work out the stresses of the Minimax H.S. and scale that design to a Hurricane H.S. so I can see how Coro compares on paper.
If nothing else, I'll have learned how to design a monocoque lifting surface.
I intend to test some coro parts such as a H.S. to failure to learn how it fails and if practice approximates my theory. Should the numbers tell me it will work.
This is experimental construction!
Now, would Airfix let me rip off their box design for selling 2/3 scale plastic aeroplane kits?
lr27
Nov 3, 2007
3,822
Have you also looked at stiffness and buckling?
That's going to be a very big box if you package the parts the same way Airfix does. ;-)
7,419
I haven't looked at buckling yet as I was expecting to need shear webs. Stiffness is OK.
I had a quick look at the Minimax plans earlier and it's H.S. is unsuitable for a Hurricane shape. But the area is very similar so I can still do a weight and strength comparison. The Legal eagle empennage construction looks a better starting point for a conventional construction.
Yes, a very big box. Since I'll likely be restricted to 8x4 coro sheets, an 9x5x3-ish box may do it. Something that will slot into the back of a fullsize PU even if it did hang out the back a bit seems fine. A giant Airfix box would look very, very cool. especially If I had a stack of them at flyins. They wouldn't be too heavy. 160lbs maybe with everything but the engine and paint. One person per corner would be easy. One person per end would work, too. Failing that, a crudely printed 'Acme Plastic Fighter Aeroplane' stamp on the boxes....
lr27
Nov 3, 2007
3,822
You could make it easier for people by selling the correct color paint in giant, Testor's style jars. Or, I guess, since it's a British airplane, Humbrol. If you used two boxes, 9X5X1.5, they'd look more like model boxes. ;-)
7,419
I'll be testing exterior latex as it is very available, cost effective and I think will work. It'd be daft to mail it. Roundel paint doesn't need much, so a set might be good in pints. Humbrol didn't have accurate matches when I was using it. It was sorta-close-ish.
blane.c
Jun 27, 2015
3,879
capital district NY
Not just through the canopy opening, they did have a little extra help getting in and out.
I wonder if you could "bubble" the canopy and canopy frame, I don't know about you but my fat head is going to get wedged into a scaled down version of that.
blane.c
Jun 27, 2015
3,879
capital district NY
Don't start me on cannons. I was pondering how to make rapid fire propane cannons while cutting the grass earlier...
The Thor is a bit pricey, but it would work. The rad is tiny, shouldn't be too hard to squeeze in somewhere.
If I go aircooled, even a small gap between the 15" spinner and cowl will let plenty of air in. Hot air out through the 'engine' exhausts. Some ducting and the same scheme could work for water cooling. The 'radiator' housing under the wing looks more like a very nice little baggage pod to me. I just need to balance any weight there with enough beer, etc in the LE 'fuel' tanks, which should be sorta accessible with the gear down.
Browning 12 guage auto's solenoid fired.
blane.c
Jun 27, 2015
3,879
capital district NY
Yuck! The FW190 used 5 digit airfoils and was known was for its downright vicious stalls. After the RAF tested one, advice was given to try baiting FWs into stalls during dogfights. There's gun camera footage of a FW190 on youtube on a Mustang's tail. He stalls and does a 3 turn inverted flat spin before recovering... He eventually got the Mustang.
The YH tip airfoil works great at full size and 103 scales. I'll have a hard time finding anything much better so I'll likely stick with it. Simply scaling it to 19% works really badly at both full size and 103 in XFLR5. If the hurricane does indeed have a horrible root airfoil (surely they tested it?) Then I want one that will give similar whole wing stall characteristics, or my 'improvements' could result in nasty stalling. Likewise, I don't want to lose several points of Clmax by using a root airfoil that stalls much sooner than it needs to. I don't want to mismatch tip and root so that stall inception and progression changes.
This isn't about replicating the airfoil, it's about replicating the behaviour of the whole wing. To do that, I need to know the exact airfoils used at full size. I won't be using the 19% YH root as it's awful. There are other airfoils that have similarly low Clmax, Cm, but way lower drag. But maybe the actual Hurricane airfoil isn't quite a 19% YH and is usable. The 19% YH actually works slightly better at 103 RNs than at full size. That is suspicious... Reducing the nose radius makes a huge improvement both large and small size.
I'm nowhere near needing to decide on exact airfoils yet, plenty else to do.
The Hurricane used 12% tip, 19% root airfoils. I'll probably stick with that. That'll be a foot thick at the root of a Mk103.
Hmmm, Actually, this should be the MkCIII?
Well you know this but, at slow speeds aileron effectiveness falls way off and control to turn and or pick up a wing falls upon the rudder.
blane.c
Jun 27, 2015
3,879
capital district NY
I'm thinking of the 627 at 77lb out of the box. 23hp standard. I believe Colomban gets 40hp from his. It's feasible at 5000rpm. I was wincing at the weight of 503s not far back...
I have Legal Eagle and Minimax plans to plagiarise for ideas.
A six cylinder two stroke at six thousand RPM could have the same staccato as a 12 cylinder four stroke at three thousand RPM? With the right tubes.
