Human Powered Flight
5,088
Could ground effect be the solution...it is still flying isn't it ?
Has any human powered aircraft ever left ground effect? Given their enormous spans I’d think ground effect already is the solution and always has been.
I’d be curious if the last two Kremer prizes (which I believe are centred around speed) could be won with some sort of hybrid electric rig. For example the first half hour of the marathon would just be pedalling in place to charge a battery or other energy storage device, then release the brake and fly 52mph on the stored energy plus pedals for the last half hour. In my head there ought to be slightly less energy available due to transmission losses but perhaps that could be countered by not having to have an airframe to meet the needs of so little sustained power as we’ve seen to date.
Bob H
Jun 9, 2022
25
When Bryan Allen was pedaling across the Channel, the support crews had boats on the water to pick him up should he lose his ability to power the plane. He was flying at ~30' above the water, calculated to be optimum. As he got around 2/3 across, his energy level decreased and he began to gradually lose altitude. The rescue teams were right under him, ready to grab the plane and get him out. But he found that when he got about 5' above the water, the pedaling got easier because of ground effect and he was able to complete the flight.
The team got help from unexpected sources. The Channel has very busy shipping traffic. As he was half-way thru the flight, spotters for ship traffic saw an oil tanker coming along and figured it would intersect the flight. They somehow managed to contact the ship's Captain and he graciously slowed the ship down so Albatross could pass without wake-turbulence damaging the plane. The success of the project was full of lucky circumstances.
Sraight'nlevel
Nov 4, 2021
464
I remember this incident from the vids...he almost scooped the water.
goney3
May 5, 2021
45
Lompoc, CA
A German company (Schaeffler) created a "ride-by-wire" system that can generate electricity at the pedals and transmit that electricity to a motor. This could open the door to unique design possibilities and cut down on weight from mechanical chains/pulleys. I imagine the electric motor (while not very powerful ~250W) could spin at higher RPM's that are unable by a mechanical motion. Could this help?
From the article below: "5% less efficient than chain drives"
Sraight'nlevel
Nov 4, 2021
464
It is outstanding when using also solar....or batteries...or both.
goney3
May 5, 2021
45
Lompoc, CA
Sraight'nlevel
Nov 4, 2021
464
5% loss ok...but you have to have two electric motors/generators...so there is also a 5 kg weight penalty.
Sraight'nlevel
Nov 4, 2021
464
That is the point exactly...they remain in ground effect, but they look anything but WIG crafts.
speedracer
Feb 4, 2020
390
Brian Allen was also a hang glider pilot. I flew with him at the World Hang Glider Championships at Vancouver BC around 1980. He was a very modest, approachable guy. I should have gotten his autograph.
henryk
Mar 8, 2010
7,412
krakow,poland
-Taras Kiceniuk was invented many modes of soaring ,recovering energy from nonstationary air flowes...
-Witold Kasper was observed another soaring mode="DYNAMIC soaring"
on His tailles glider BEKAS-N .
(possibility of soaring in athermic wheather, long distances on low altitude,
when horisontal gusts exists !)
Bob H
Jun 9, 2022
25
A normal metal bike chain was too heavy for the Albatross so the team came up with a novel idea that used a Kevlar thread and a series of beads attached or knotted to the thread that were pitched to match the sprocket teeth. The Kevlar took the tension loads and was flexible and super light. I never saw the Kevlar chain so I don't know how they knotted the beads or what the beads were made from; just remembered the clever concept was built and worked in 1978.
Sraight'nlevel
Nov 4, 2021
464
I think that statement alone could be brought out any time someone thinks human powered flight could be easy or commonplace.
I think there a fewer HPA pilots than there are astronauts.
There are also very thin chains available today that are lighter.
nerobro
Nov 6, 2011
1,128
Northern Illinois
There may well be... but I think that may be more about the availablity of the airplanes than the number of people who could do it. As noted, the entire peloton of the TdF could fly human powered planes quite well. Horsepower wise.
About chain, not in comparison to kevlar thread there isn't.
I bet there would be a business in having a field where people could sprint little planes up to speed and get useful hops.
