If you want them done professionally, contact Airplane Plastics; I'm a customer, and they do excellent work. They're in the Dayton, Ohio area. Website is WWW.AIRPLANEPLASTICS.COM.
Small pieces of plexiglass are available on Ebay.Scheming out my wingtips and the Plexiglas covers that go over them. So, given that the airplane is a one off, and the tips are compound convex shapes (much like the ones used on RV's). They will be about 10" long, 10" wide, and about 5" deep. So let's get into PROVEN methods of how:
Do we make or buy, and why?
If we are to buy, Please supply recommended shops. Extra points for SE Michigan;
If we are to make:
Do I attempt to simply drape frame over a male mold?
Do I make an over-height male mold, then heat the sheet in a frame and then stretch form?
Do I vacuum assist onto the male mold?
Should I go female mold and vacuum assist into the mold?
What thickness would you use for the sheet?
I am also figuring that I will have to work it out, and when it does work, then I can put in the offset in the tip molds and build tips, then maybe iterate... I would like to reduce the "development" by using PROVEN methods.
So, let's hear it.
