How I built my fuselage table/jig
Discussion in 'Workshop Tips and Secrets / Tools' started by Little Scrapper, Nov 15, 2016.
  1. Nov 15, 2016 #1
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,239
    3,145
    Wisconsin
    Lucrum, Dmitry_SPb, billyvray and 8 others like this.
  2. Nov 15, 2016 #2
    rbrochey
    rbrochey
    rbrochey
    Oct 17, 2010
    1,503
    608
    Gallup, New Mexico USA
    Looks great! Thanks and nice work!! :)
    Little Scrapper likes this.
  3. Nov 15, 2016 #3
    11,121
    3,012
    Interesting that you mounted the top in a cradle. Cool idea. Heck you should have built a Jodel; you spar would be done.
    bmcj and Little Scrapper like this.
  4. Nov 15, 2016 #4
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,239
    3,145
    Wisconsin
    I did that because after shimming the top level the cradle allows me to secure it pretty solid.
  5. Nov 15, 2016 #5
    Mark Z
    Mark Z
    Mark Z
    Aug 29, 2012
    518
    241
    Granbury, Texas USA 0TX0
    You do pretty work!!
  6. Nov 15, 2016 #6
    5,750
    4,620
    Holy cow... the table is a work of art even before the airplane is built.
    If you built jig tables specifically set up for the homebuilt airplanes that still get scratchbuilt frequently (Tailwind, Pietenpol, Baby Ace, Pitts, etc.), you could have a small side business renting out the tables to builders at $500 a pop. Would be a bargain compared to the time/cost/effort/mistake re-do of someone building their own table. Big time saver for them.
    You wouldn't get rich, but you would make a little money, at the same time as being a big hero to the homebuilders.
  7. Nov 15, 2016 #7
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,239
    3,145
    Wisconsin
    The blog post was really long and it gives the impression of taking a long time. I kept track of the hours, even with my 12 year old assembling the top and myself building the legs solo the total hours from start to finish was 3.25. Total cost was $162.
    Of course, this is for a Cassutt so the table is only 13' x 23.5", pretty small.
    I apologize for the lighting in the photos. I had 2 Troffer lights blow. I replaced them today with LED's so my light issues are solved now.
  8. Nov 16, 2016 #8
    Winginit
    Winginit
    Winginit
    Jun 13, 2016
    811
    242
    x
    Very nice, both the table and the presentation.
  9. Nov 16, 2016 #9
    fly2kads
    fly2kads
    fly2kads
    Jan 2, 2010
    1,411
    496
    Justin, TX
    Well done, sir, and thanks for sharing!
  10. Nov 18, 2016 #10
    max_burke
    max_burke
    max_burke
    Sep 10, 2013
    110
    33
    Vancouver, Canada
    Is the table just screwed or is it glued as well?
  11. Nov 18, 2016 #11
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,239
    3,145
    Wisconsin
    Only screws were used in this table
    max_burke likes this.
  12. Nov 18, 2016 #12
    Tom Nalevanko
    Tom Nalevanko
    Tom Nalevanko
    Oct 10, 2007
    1,301
    117
    Camarillo, CA
    Very nice table... Screw and glue however will get you a better table for the long term. Over time, the screws will loosen; it is just their nature with micro-stresses, temperature changes, hard bumps, etc that cause one-way movement even if individually very small. In a screw and glue build, the glue takes all the above and returns to its original state/position. The screws take the heavy loads when they have too. This also applies in joining composites to steel as in the fuselage of my Stallion. Just trying to be constructive.... Thanks
    Blue skies,
    Tom
  13. Nov 18, 2016 #13
    11,121
    3,012
    All screw and he can bust it down to nothing though.
  14. Nov 18, 2016 #14
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,239
    3,145
    Wisconsin
    No they won't. This is my 6th or7th table. It's a temporary jig, not a permanent table.
    Correctly built a table doesn't need glue. It's a matter of design. Once the fuselage sides are tacked the fuselage gets assembled and the table thrown out.
  15. Nov 18, 2016 #15
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,239
    3,145
    Wisconsin
    If you were really concerned about movement a few well placed gussets screwed in the corners would hold that together for a hundred years.
    bmcj likes this.
  16. Nov 18, 2016 #16
    12,558
    4,583
    Or maybe a little glue on each of the screws as they go in to keep them from turning?
  17. Nov 18, 2016 #17
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,239
    3,145
    Wisconsin
    No, not needed and I need to be able to take it apart. It's a jig, not a workshop table. That's why the box structure is important, you can literally throw it on crappy saw horses if you need.
    I built work tables out of steel if they are permanent. I built this for my chopper this summer. It converts to a wood top when not used as a frame table.
    bmcj likes this.
  18. Nov 18, 2016 #18
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,239
    3,145
    Wisconsin
    Here it is freshly painted. If you're building a steel tube airplane welding isn't an issue so a actual workshop table should be welded if you plan on having it for years.
  19. Nov 18, 2016 #19
    8,877
    5,729
    Scrapper, you need to put those other toys out of your mind until you need them to get you to the airport to fly your Cassutt.
  20. Nov 18, 2016 #20
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,239
    3,145
    Wisconsin
    I've been on 2 wheels for 40 years now. That will never stop. I'm up north at our farm for opening deer hunting right now. Been jumping motocross all day. Once it's in your blood...........
