How far are we from the perfect electric "homebuilt" ?
stanislavz
Aug 21, 2016
487
Lt
How about this on motors (light electric): https://www.limis.lt/paieska/perziu...80000000307554?s_id=VwQUCvP4dUGWa3I4&s_ind=33
Do you know the weight of it ?
It basic glider, used for studens. The Designer had a long line of them in many shapes. But they are calculated for max 70kg pilot. And have rather poor glide ratio. Here you have full list of his constructions. Columns translation ( yours is bro-18):
Name, targed/category, year, wingspan, wing area, lengh, empty weight, glide ratio, minum descending ? , minimum descending speed, how many builded, whom build it.
12notes
Aug 27, 2014
1,044
Louisville, KY
I posted it to show how a real aviation engineer student solves the issues in aircraft design. 12 notes referred to them.
I did no such thing. That video is complete and utter crap.
You've shunned the opinion of many experienced engineers on here already, people who have actually accomplished things with real aircraft, and somehow you think a video of an inexperienced, just-started-university, student building an aircraft that has never flown is proof everyone else is wrong? Particularly one whose frame is poorly stick welded out of galvanized pipe that he's planning on covering with fiberglass? Built in contravention to pretty much every material guideline and building standard for aircraft out there? With a main spar behind the center of lift, and a front spar that's not attached to the fuselage at all? That wasn't designed, that was kludged together based on what an airplane looks like. No engineer would build, approve, or get anywhere near anything like this. That is a suicide machine, not an aircraft.
Also, it fails to mention ANYTHING related to any of your arguments. Not that it would've helped if it did, the person in the video, while enthusiastic, does not know anything about aviation design.
Seriously, get a clue. You don't know anything about aircraft at all if you think this video is how aircraft design or construction is done. Your opinions are completely uninformed, and worse, you refuse to learn to correct them, but are extremely vocal in regurgitating these incorrect opinions here. Stop making this board worse.
Speedboat100
Nov 8, 2018
1,011
Europe
Is the designer still alive ? Is there any way to get to know what he was after with that wing solution ?
Speedboat100
Nov 8, 2018
1,011
Europe
If I sum it up...I have designed pair of floats that are 10 kg together. Here we see that before innovation of some seriously light materials...gliders were even 35 kilos empty. We now can easily squeeze 10 kilos of one..so we have 25 kg air frame with 10 kg floats. That makes 35 kg...we load engines in it...lets say 3 kg worth electric ones..we still have 32 kg left for batteries and we hit 70 kilos...empty. Ok..let's be reasonable 2 kilos for struts, propeler and mounts etc. 30 kg left for batteries. If we have semiclosed cockpit and glideratio 1:20..it cruises at 2 kw.
Ok I counted using Tesla batteries that it ought to cruise 2 hr 36 minutes with 30 kilos of batteries. Possibly the pilot ought to be under 80 kg to reach this..250 lbs dude may only fly 1 hr 30 minutes.
This is my target !
3,134
I just want to make a aeroplane that is able to take off from snow, water and ground with minimal hp/kw as possible. I also want to see how small amount of expences if anything has to be spent to it. Usually I end up bying tools that cost more than the product at the end.
It sounds like what you need is a gofundme or a Patreon account if you’re just building an airplane for yourself.
Speedboat100
Nov 8, 2018
1,011
Europe
Yes good idea Tim. I am also developing a pitch controlled H-darrieus wind turbine (3rd proto)....and it seems I am getting a big back up for that project....and small plane like this is created with just vapour of the money that goes to a real 4th test model of the turbine.
Speedboat100
Nov 8, 2018
1,011
Europe
Ok...I try to behave. I am slightly ADHD so I cannot always absorb everything everybody is saying...ok ?!
stanislavz
Aug 21, 2016
487
Lt
Nope. RIP
But his ideas of basic gliders will live long.
Anyway - from my point, it is not bedt frame for conversion. Please look better at Rutan designs. Like global flyer etc...
Just long wing span, load distributed across wing span..
Speedboat100
Nov 8, 2018
1,011
Europe
Nope. RIP
Bronius Oskinis is my hero R.I.P. !
I understand the long span efficiency...but I kinda think Bronius was a master of low cost fun for everybody kinda thinking in aviation.
stanislavz
Aug 21, 2016
487
Lt
Not only. Cheap and mass produced by local group of kids to make first step in aviation.
But back to topic - you really are forced to have glide ratio of 15 at least, and high payload ratio. And if not carbon spar - then wooden flying wing, like kasperwing or similar, loaded with you at the center of wingspan, and batteries on wing tips...
litespeed
May 21, 2008
1,557
Sydney
The abomination aircraft is well known down here in Australia.
It was never going to fly nor did he really expect it to.
The young bloke was a refugee and wanted to have a go building and have some fun. He desperately wanted to learn how to fly.
The local flyers organised free lessons for him and and he infected them with his enthusiasm.
At this stage I expect he has his wings and probably at uni.
Speedboat100
Nov 8, 2018
1,011
Europe
Yes...I have to have something here..it is a bit secret. By making it really lite like Bronius...I can achieve pretty good glide ratio with wings that are now only spanning 6.3 meters...I am considering fixed slats...but there is something else too. I have to make a 1/3 scale model to see the efficiency that I am after...and definitely 2 electric engines..if not 4.
I have been rehearsing this now for 12 years.
My themes have been.
1. Ground effect
2. Low drag
3. Lite weight
4. High lift ( and lite ) wing
5. Very cheap to make ( which is relative )
I think I can fit inside..at my 6 ft 3 in torso. Still the plane is with floats is only 3.8 m long and 3.4 m without them on nose wheel configuration.
It has got aggressive looking twin rudders ( but one boom ).
Speedboat100
Nov 8, 2018
1,011
Europe
I have been thinking about that kid...all the things he has been through..it may not be the easiest thing to start building high performance aeroplanes right away.
He possibly never went through the rubberband => r/c control phase in his life.
stanislavz
Aug 21, 2016
487
Lt
1. Ground effect
2. Low drag
3. Lite weight
I am getting old, and not believe in 6.5 span.. 2 and 4 are mutual exclusive, 3 - i'd better lost 30 minutes of flight, than 1 g from rated load :)
It is good idea to try model !
Speedboat100
Nov 8, 2018
1,011
Europe
One thing I have tried in 100s of my sketches to seek is the lift also from the fuselage...and this time I assume I did hit the jackpot....it gives 20 ( 25% ) % more lift to the thing in flight and 30% at take off. So 6.5 m is not bad....as they remain light....and flutter free.
henryk
Mar 8, 2010
5,217
krakow,poland
-see BKB1-A story =low cost, tailless club class glider...
AR=10 , L/D= 30 !
+ super aerobatic possibility (ultralow radius !!!) =
Speedboat100
Nov 8, 2018
1,011
Europe
Since I have morized aeroplane with tapered wings the calculations for performance are a bit difficult.
First and foremost I am concentrated on the range more than flying time as I want to go somewhere.
So my plane has to cruise slightly faster than the part 103 planes top speed is...yet is has to land safely at very low speed..this is a demanding task...with limited power.
https://www.fzt.haw-hamburg.de/pers/Scholz/OPerA/OPerA_PUB_DLRK_12-09-10.pdf
stanislavz
Aug 21, 2016
487
Lt
Ok, i will put your on the ground, but it was done before.
https://en.wikipedia.org/wiki/Westland_Dreadnought
Or this one https://www.secretprojects.co.uk/threads/lisichkin-rentel-lk-1-niai-1-«-fanera-2-».19416/
Later one is more interesting as comparison base, because it used same as Po-2 biplane (empty/max 770/1030) and sh-2 flying boat (680/970). And have highest speed and empty max weight with of 652/1160kg..
Speedboat100
Nov 8, 2018
1,011
Europe
Yes here lies the answer. How to arrange the pods you talk about...wing and the fuselage in a very compact single seat electric aeroplane with SEVERAL engines. I can also assure you I do not have anything like Burnelli or any other lifting body engineer had in the past on my design..it is compact and attractive..in a very modest way like in BrO-18.
